Fatal source exception in loopback sample on powerpc/qoriq_e6500_64
Clukey (US), Steven A
steven.a.clukey at boeing.com
Mon Sep 14 17:11:16 UTC 2020
Hi,
I am attempting to run the `loopback.exe` sample application provided with RTEMS on the PowerPC qoriq_e6500_64 BSP, but unfortunately it is crashing.
The crash seems to be coming from here: `cpukit/libnetworking/rtems/rtems_glue.c` line 230. It appears to be due to the fact that the `routedomain` object is being placed in the `.data.rel.ro` section which is read-only, so writing to it causes the crash.
$ powerpc-rtems5-objdump -x loopback.exe | grep routedomain
000000000404dd70 g O .data.rel.ro 0000000000000050 routedomain
Has anyone seen this issue before, or know how to fix it? Maybe I'm missing a compiler argument or something?
I've included the console output below.
Thanks!
Steven
*** BEGIN OF TEST LOOPBACK ***
*** TEST VERSION: 5.1.0-rc1.e2026cd4e66206a19eb445642fcc96418b007607
*** TEST STATE: EXPECTED_PASS
*** TEST BUILD: RTEMS_DEBUG RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
*** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB 5.1.0-rc1, Newlib 7947581) "Network" initializing!
*** FATAL ***
fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION) exception vector 2 (0x2)
next PC or address of fault = 0x00045a78
saved MSR = 0x8200a200
context = task, ISR nest level = 0
thread dispatch disable level = 0
R0 = 0x00045998 R1 = 0x0502d010 R2 = 0x04055d00 R3 = 0x050cbb70
R4 = 0x00000000 R5 = 0x00000003 R6 = 0x00000000 R7 = 0x00000001
R8 = 0x05025d00 R9 = 0x0404dd70 R10 = 0x00000000 R11 = 0xffffffffffffffe9
R12 = 0x0001e91c R13 = 0x00000000 R14 = 0x00000000 R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
R24 = 0x00000000 R25 = 0x00000000 R26 = 0x00000000 R27 = 0x00000000
R28 = 0x00000000 R29 = 0x00000000 R30 = 0x05005d00 R31 = 0x0502d6a0
CR = 0x20000402
CTR = 0x00000000
XER = 0x00000000
LR = 0x00045998
DEAR = 0x0404dda8
ESR = 0x00800000
MCSR = 0x00000000
VSCR = 0x00000000
VRSAVE = 0x00000000
V00 = 0x00000000000000000000000000000000
V01 = 0x00000000000000000000000000000000
V02 = 0x00000000000000000000000000000000
V03 = 0x00000000000000000000000000000000
V04 = 0x00000000000000000000000000000000
V05 = 0x00000000000000000000000000000000
V06 = 0x00000000000000000000000000000000
V07 = 0x00000000000000000000000000000000
V08 = 0x00000000000000000000000000000000
V09 = 0x00000000000000000000000000000000
V10 = 0x00000000000000000000000000000000
V11 = 0x00000000000000000000000000000000
V12 = 0x00000000000000000000000000000000
V13 = 0x00000000000000000000000000000000
V14 = 0x00000000000000000000000000000000
V15 = 0x00000000000000000000000000000000
V16 = 0x00000000000000000000000000000000
V17 = 0x00000000000000000000000000000000
V18 = 0x00000000000000000000000000000000
V19 = 0x00000000000000000000000000000000
V20 = 0x00000000000000000000000000000000
V21 = 0x00000000000000000000000000000000
V22 = 0x00000000000000000000000000000000
V23 = 0x00000000000000000000000000000000
V24 = 0x00000000000000000000000000000000
V25 = 0x00000000000000000000000000000000
V26 = 0x00000000000000000000000000000000
V27 = 0x00000000000000000000000000000000
V28 = 0x00000000000000000000000000000000
V29 = 0x00000000000000000000000000000000
V30 = 0x00000000000000000000000000000000
V31 = 0x00000000000000000000000000000000
FPSCR = 0x00000000
F00 = 0x0000000000000000
F01 = 0x0000000000000000
F02 = 0x0000000000000000
F03 = 0x0000000000000000
F04 = 0x0000000000000000
F05 = 0x0000000000000000
F06 = 0x0000000000000000
F07 = 0x0000000000000000
F08 = 0x0000000000000000
F09 = 0x0000000000000000
F10 = 0x0000000000000000
F11 = 0x0000000000000000
F12 = 0x0000000000000000
F13 = 0x0000000000000000
F14 = 0x0000000000000000
F15 = 0x0000000000000000
F16 = 0x0000000000000000
F17 = 0x0000000000000000
F18 = 0x0000000000000000
F19 = 0x0000000000000000
F20 = 0x0000000000000000
F21 = 0x0000000000000000
F22 = 0x0000000000000000
F23 = 0x0000000000000000
F24 = 0x0000000000000000
F25 = 0x0000000000000000
F26 = 0x0000000000000000
F27 = 0x0000000000000000
F28 = 0x0000000000000000
F29 = 0x0000000000000000
F30 = 0x0000000000000000
F31 = 0x0000000000000000
executing thread ID = 0x0a010001, name = UI1 Stack Trace:
IP: 0x00045a78, LR: 0x00045998
--^ 0x0502d6b0--^ 0x0502d6f0--^ 0x0502ccd0--^ 0x00000000--^ 0x0502d7a0 --^ 0x00000000--^ 0x00000000 RTEMS version: 5.1.0-rc1.e2026cd4e66206a19eb445642fcc96418b007607
RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5.1.0-rc1, Newlib 7947581) executing thread ID: 0x08a010001 executing thread name: UI1 ```
