rtems_bsd_initialize() in POSIX_Init and qemu-system-i386
junkes junkes at fhi-berlin.mpg.de
Mon Sep 28 19:43:41 UTC 2020
I have a problem with rtems_bsd_initialize() in POSIX_Init() and qemu.
call of
     sc = rtems_bsd_initialize();
     assert(sc == RTEMS_SUCCESSFUL);
always takes about 45 seconds until it is finished.
The output of
nexus0: <RTEMS Nexus device>
pcib0 pcibus 0 on motherboard
pci0: <PCI bus> on pcib0
pci0: <bridge, HOST-PCI> at device 0.0 (no driver attached)
pci0: <bridge, PCI-ISA> at device 1.0 (no driver attached)
pci0: <mass storage, ATA> at device 1.1 (no driver attached)
pci0: <bridge> at device 1.3 (no driver attached)
pci0: <display, VGA> at device 2.0 (no driver attached)
em0: <Intel(R) PRO/1000 Network Connection> port 0xc000-0xc03f mem
0xfebc0000-0xfebdffff irq 11 at device 3.0 on pci0
comes very fast, but then the system is "frozen" for about 45 seconds.
Then this output appears:
info: em0: Ethernet address: 0e:b0:ba:5e:ba:11
cpu0 on motherboard
The setting of
     default_network_set_self_prio(RTEMS_MAXIMUM_PRIORITY - 1U);
seems to have no influence. I also did not understand the setting of
priorities.
                               CPU USAGE BY THREAD
  ID         | NAME                                   | SECONDS       |
PERCENT
  0x09010001 | IDLE                                   |     46.042360 |
98.800
  0x0a010001 | TIME                                   |      0.000067 |
0.000
  0x0a010002 | IRQS                                   |      0.000969 |
0.002
  0x0a010003 | swi6: task queu                        |      0.000000 |
0.000
  0x0a010004 | config_0                               |      0.000000 |
0.000
  0x0a010005 | swi5: fast task                        |      0.000000 |
0.000
  0x0a010006 | kqueue_ctx task                        |      0.000000 |
0.000
  0x0a010007 | thread taskq                           |      0.000000 |
0.000
  0x0a010008 | swi6: Giant tas                        |      0.000000 |
0.000
  0x0a010009 | swi1: netisr 0                         |      0.000000 |
0.000
  0x0a01000a | if_io_tqg_0                            |      0.000000 |
0.000
  0x0a01000b | if_config_tqg_0                        |      0.000000 |
0.000
  0x0a01000c | softirq_0                              |      0.000000 |
0.000
  0x0b010001 |                                        |      0.561695 |
1.205
  0x0b010003 |                                        |      0.001552 |
0.003
  TIME SINCE LAST CPU USAGE RESET IN SECONDS:
46.608912
Task control block(Nr.: 1)
task control block at 0x006b33c0
task ID: 0x09010001
name_32: -- ELDI --
ID=0x09010001 name=IDLE
--Info (hpj)-- task Nr: 1
  id=151060481, name=IDLE, prio = 255
Task control block(Nr.: 2)
task control block at 0x006ab8a0
task ID: 0x0a010001
name_32: -- EMIT --
ID=0x0a010001 name=TIME
--Info (hpj)-- task Nr: 2
  id=167837697, name=TIME, prio = 98
Task control block(Nr.: 3)
task control block at 0x006abc38
task ID: 0x0a010002
name_32: -- SQRI --
ID=0x0a010002 name=IRQS
--Info (hpj)-- task Nr: 3
  id=167837698, name=IRQS, prio = 96
Task control block(Nr.: 4)
task control block at 0x006abfd0
task ID: 0x0a010003
name_32: -- DSB_ --
ID=0x0a010003 name=_BSD
--Info (hpj)-- task Nr: 4
  id=167837699, name=swi6: task queu, prio = 100
Task control block(Nr.: 5)
task control block at 0x006ac368
task ID: 0x0a010004
name_32: -- DSB_ --
ID=0x0a010004 name=_BSD
--Info (hpj)-- task Nr: 5
  id=167837700, name=config_0, prio = 100
Task control block(Nr.: 6)
task control block at 0x006ac700
task ID: 0x0a010005
name_32: -- DSB_ --
ID=0x0a010005 name=_BSD
--Info (hpj)-- task Nr: 6
  id=167837701, name=swi5: fast task, prio = 100
Task control block(Nr.: 7)
task control block at 0x006aca98
task ID: 0x0a010006
name_32: -- DSB_ --
ID=0x0a010006 name=_BSD
--Info (hpj)-- task Nr: 7
  id=167837702, name=kqueue_ctx task, prio = 100
Task control block(Nr.: 8)
task control block at 0x006ace30
task ID: 0x0a010007
name_32: -- DSB_ --
ID=0x0a010007 name=_BSD
--Info (hpj)-- task Nr: 8
  id=167837703, name=thread taskq, prio = 100
Task control block(Nr.: 9)
task control block at 0x006ad1c8
task ID: 0x0a010008
name_32: -- DSB_ --
ID=0x0a010008 name=_BSD
--Info (hpj)-- task Nr: 9
  id=167837704, name=swi6: Giant tas, prio = 100
Task control block(Nr.: 10)
task control block at 0x006ad560
task ID: 0x0a010009
name_32: -- DSB_ --
ID=0x0a010009 name=_BSD
--Info (hpj)-- task Nr: 10
  id=167837705, name=swi1: netisr 0, prio = 100
Task control block(Nr.: 11)
task control block at 0x006ad8f8
task ID: 0x0a01000a
name_32: -- DSB_ --
ID=0x0a01000a name=_BSD
--Info (hpj)-- task Nr: 11
  id=167837706, name=if_io_tqg_0, prio = 100
Task control block(Nr.: 12)
task control block at 0x006adc90
task ID: 0x0a01000b
name_32: -- DSB_ --
ID=0x0a01000b name=_BSD
--Info (hpj)-- task Nr: 12
  id=167837707, name=if_config_tqg_0, prio = 100
Task control block(Nr.: 13)
task control block at 0x006ae028
task ID: 0x0a01000c
name_32: -- DSB_ --
ID=0x0a01000c name=_BSD
--Info (hpj)-- task Nr: 13
  id=167837708, name=softirq_0, prio = 100
Task control block(Nr.: 14)
task control block at 0x006a3d20
task ID: 0x0b010001
name_32: --  --
ID=0x0b010001 name=
--Info (hpj)-- task Nr: 14
  id=184614913, name=, prio = 30
Task control block(Nr.: 15)
task control block at 0x006a4450
task ID: 0x0b010003
name_32: --  --
ID=0x0b010003 name=
--Info (hpj)-- task Nr: 15
  id=184614915, name=, prio = 229
qemu is called with:
qemu-system-i386 -m 64 -no-reboot -serial stdio -display none -net
nic,model=e1000,macaddr=0e:b0:ba:5e:ba:11 -net user,restrict=yes -append
"--video=off --console=/dev/com1" -kernel libComTestHarness
Heinz
