libbsd network on an mvme2500
Chandler, Brendan
bchandler at anl.gov
Tue Aug 17 16:09:39 UTC 2021
Hi rtems-users,
I'm trying to set up a simple RTEMS 5 program to get my mvme2500 board up and running with a static network configuration using libbsd. I took the hello.c example from the getting started guide, and modified it to use libbsd and configure the network. My problem is I get a runtime error when loading my binary when I call rtems_bsd_initialize():
## Booting kernel from Legacy Image at 10000000 ...
Image Name: RTEMS
Created: 2021-08-17 15:32:55 UTC
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 968695 Bytes = 946 KiB
Load Address: 00004000
Entry Point: 00004000
Verifying Checksum ... OK
## Flattened Device Tree blob at 20000000
Booting using the fdt blob at 0x20000000
Uncompressing Kernel Image ... OK
Loading Device Tree to 00ff9000, end 00fff04a ... OK
emerg: rtems_bsd_threads_init_early: cannot create extension
This seems to be coming from rtems-libbsd/rtemsbsd/rtems/rtems-kernel-thread.c where the call to rtems_extension_create() fails.
I've posted my code at github here:
https://github.com/brendanchandler/test-rtems5
Can anyone help get around this error? I'm probably missing some configuration or setup, but haven't been able to determine what it is.
Thanks in advance for any help,
Brendan
