libbsd network on an mvme2500
Wed Aug 18 00:00:11 UTC 2021
On 18/8/21 5:19 am, Chandler, Brendan wrote:
> I think I found the answer to my own issue.  I needed this configuration option:
> #define CONFIGURE_MAXIMUM_USER_EXTENSIONS       5
> With that, the error "cannot create extension" goes away and I can boot.
Great to see you managed to solve the problem and thank you for letting us know.
> ________________________________________
> From: Chandler, Brendan <bchandler at anl.gov>
> Sent: Tuesday, August 17, 2021 11:09
> To: users at rtems.org
> Subject: libbsd network on an mvme2500
> Hi rtems-users,
> I'm trying to set up a simple RTEMS 5 program to get my mvme2500 board up and running with a static network configuration using libbsd.  I took the hello.c example from the getting started guide, and modified it to use libbsd and configure the network.  My problem is I get a runtime error when loading my binary when I call rtems_bsd_initialize():
> ## Booting kernel from Legacy Image at 10000000 ...
>    Image Name:   RTEMS
>    Created:      2021-08-17  15:32:55 UTC
>    Image Type:   PowerPC Linux Kernel Image (gzip compressed)
>    Data Size:    968695 Bytes = 946 KiB
>    Load Address: 00004000
>    Entry Point:  00004000
>    Verifying Checksum ... OK
> ## Flattened Device Tree blob at 20000000
>    Booting using the fdt blob at 0x20000000
>    Uncompressing Kernel Image ... OK
>    Loading Device Tree to 00ff9000, end 00fff04a ... OK
> emerg: rtems_bsd_threads_init_early: cannot create extension
> This seems to be coming from rtems-libbsd/rtemsbsd/rtems/rtems-kernel-thread.c where the call to rtems_extension_create() fails.
> I've posted my code at github here:
> https://github.com/brendanchandler/test-rtems5
> Can anyone help get around this error?  I'm probably missing some configuration or setup, but haven't been able to determine what it is.
> Thanks in advance for any help,
> Brendan
> users mailing list
> users at rtems.org
