libbsd network on an mvme2500
Brendan Chandler
bchandler at anl.gov
Thu Aug 19 13:57:01 UTC 2021
On 8/17/21 7:42 PM, Joel Sherrill wrote:
> On Tue, Aug 17, 2021, 7:00 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 18/8/21 5:19 am, Chandler, Brendan wrote:
> > I think I found the answer to my own issue. I needed this
> configuration option:
> > #define CONFIGURE_MAXIMUM_USER_EXTENSIONS 5
> > With that, the error "cannot create extension" goes away and I
> can boot.
> Great to see you managed to solve the problem and thank you for
> letting us know.
> Do you have something like CONFIGURE_UNLIMITED and
> CONFIGURE_UNIFIED_WORKSPACE?
> With those (spelled correctly) you should be able to create objects
> until memory runs out.
> Also configuring the minimum thread stack size to give some breathing
> space is often handy.
I've added those things now, thanks for the tip!
> --joel
> Chris
> > ________________________________________
> > From: Chandler, Brendan <bchandler at anl.gov
> <mailto:bchandler at anl.gov>>
> > Sent: Tuesday, August 17, 2021 11:09
> > To: users at rtems.org <mailto:users at rtems.org>
> > Subject: libbsd network on an mvme2500
> > Hi rtems-users,
> > I'm trying to set up a simple RTEMS 5 program to get my mvme2500
> board up and running with a static network configuration using
> libbsd. I took the hello.c example from the getting started
> guide, and modified it to use libbsd and configure the network.
> My problem is I get a runtime error when loading my binary when I
> call rtems_bsd_initialize():
> > ## Booting kernel from Legacy Image at 10000000 ...
> > Image Name: RTEMS
> > Created: 2021-08-17 15:32:55 UTC
> > Image Type: PowerPC Linux Kernel Image (gzip compressed)
> > Data Size: 968695 Bytes = 946 KiB
> > Load Address: 00004000
> > Entry Point: 00004000
> > Verifying Checksum ... OK
> > ## Flattened Device Tree blob at 20000000
> > Booting using the fdt blob at 0x20000000
> > Uncompressing Kernel Image ... OK
> > Loading Device Tree to 00ff9000, end 00fff04a ... OK
> > emerg: rtems_bsd_threads_init_early: cannot create extension
> > This seems to be coming from
> rtems-libbsd/rtemsbsd/rtems/rtems-kernel-thread.c where the call
> to rtems_extension_create() fails.
> > I've posted my code at github here:
> > https://github.com/brendanchandler/test-rtems5
> <https://github.com/brendanchandler/test-rtems5>
> > Can anyone help get around this error? I'm probably missing
> some configuration or setup, but haven't been able to determine
> what it is.
> > Thanks in advance for any help,
> > Brendan
> > users mailing list
> > http://lists.rtems.org/mailman/listinfo/users
> <http://lists.rtems.org/mailman/listinfo/users>
> users mailing list
URL: <http://lists.rtems.org/pipermail/users/attachments/20210819/9e210946/attachment.html>
