problem while trying converting c program from rtems4 to rtems5
Sebastian Huber
Sun Jan 3 18:26:51 UTC 2021
Hello,
On 03/01/2021 13:20, Rotem Dror MTH wrote:
> we also updated the linkcmds file according to linkcmds.base
does this indicate that you use a custom BSP? I would first try to run
the RTEMS test suite (start with ticker.exe). If the test results are
all right, then I would start migrating the application.
There is a new configuration option
https://docs.rtems.org/branches/master/c-user/config/general.html#configure-verbose-system-initialization
which may help to debug system initialization issues.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
