Delay until in Ada seems not to work
Andrew Butterfield
Andrew.Butterfield at scss.tcd.ie
Wed Jan 27 17:22:49 UTC 2021
Hi Mattia,
this is very interesting.
Previous work I did for ESA using formal methods was looking at separation kernel verification,
with XtratuM code as an example. I remember that common use case was where one
of the seperation kernel partitions contained an instance of RTEMS - I understand a demonstration system was
built. Now I am looking at verification of key managers within RTEMS-SMP.
Regards,
Andrew Butterfield
> On 27 Jan 2021, at 14:27, Mattia Bottaro <mattiabottaro9 at gmail.com> wrote:
> I've not specified it because I'm in a "non-conventional" situation: I'm running RTEMS over XtratuM: <https://fentiss.com/products/hypervisor/ <https://fentiss.com/products/hypervisor/>>.
> I'm using a BSP developed by FentISS. The hardware is the zynq7000.
> Il giorno mer 27 gen 2021 alle ore 14:25 Sebastian Huber <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>> ha scritto:
> On 27/01/2021 11:54, Mattia Bottaro wrote:
> > If you look at rtems_init.c file in that folder
> > (<https://git.rtems.org/ada-examples/snapshot/ada-examples-4-10-2.tar.bz2 <https://git.rtems.org/ada-examples/snapshot/ada-examples-4-10-2.tar.bz2>
> > <https://git.rtems.org/ada-examples/snapshot/ada-examples-4-10-2.tar.bz2 <https://git.rtems.org/ada-examples/snapshot/ada-examples-4-10-2.tar.bz2>>>),
> > you can see that there is no time of day. I thought it was ok since
> > I'm running an example.
> > Anyway, I've added time of day in rtems_init.c with these values:
> > https://github.com/RTEMS/rtems-examples/blob/master/classic_api/triple_period/init.c#L39 <https://github.com/RTEMS/rtems-examples/blob/master/classic_api/triple_period/init.c#L39>
> > <https://github.com/RTEMS/rtems-examples/blob/master/classic_api/triple_period/init.c#L39 <https://github.com/RTEMS/rtems-examples/blob/master/classic_api/triple_period/init.c#L39>>.
> > I've also set it with status = rtems_clock_set( &time) , but the
> > behaviour does not change.
> On which BSP and hardware did you try this out?
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/ <https://embedded-brains.de/datenschutzerklaerung/>
> users mailing list
> users at rtems.org
Andrew Butterfield Tel: +353-1-896-2517 Fax: +353-1-677-2204
Lero at TCD, Head of Software Foundations & Verification Research Group
School of Computer Science and Statistics,
Room G.39, O'Reilly Institute, Trinity College, University of Dublin
http://www.scss.tcd.ie/Andrew.Butterfield/
URL: <http://lists.rtems.org/pipermail/users/attachments/20210127/268385d4/attachment-0001.html>
