RTEMS5 pc686 and unplaced orphan section "error"
Michael Davidsaver
mdavidsaver at gmail.com
Tue Jul 6 19:02:19 UTC 2021
In winding my way through various checks and test of RTEMS 5, I tried linking
some of my executables with '-Wl,--orphan-handling=error'. I've been bitten
in the past by the (imo. unfortunate) default behavior in combination with
an incomplete linker script, so this is on my list of things to try.
The generated pc686 executables seem to boot and run correctly in QEMU.
>From the link map ("-Wl,-Map,...") these sections are all empty, so the default
wherever placement rules don't break anything. I'm not sure if there are
circumstances where this would not be the case for a static executable.
> error: unplaced orphan section `.iplt' from `/home/travis/.rtems/5/i386-rtems5/pc686/lib//start.o'
> error: unplaced orphan section `.rel.iplt' from `/home/travis/.rtems/5/i386-rtems5/pc686/lib//start.o'
> error: unplaced orphan section `.igot.plt' from `/home/travis/.rtems/5/i386-rtems5/pc686/lib//start.o'
> error: unplaced orphan section `.rel.gcc_except_table.main' from `/home/travis/.rtems/5/i386-rtems5/pc686/lib//start.o'
There are some other '.rel.gcc_except_table.*' coming from my code.
> error: unplaced orphan section `.rel.rtemsroset._Sysinit.content.0.0x00030080' from `/home/travis/.rtems/5/i386-rtems5/pc686/lib//start.o'
> error: unplaced orphan section `.tm_clone_table' from `/home/travis/.rtems/5/lib/gcc/i386-rtems5/7.5.0/mpentium/crtbegin.o'
> error: unplaced orphan section `.tm_clone_table' from `/home/travis/.rtems/5/lib/gcc/i386-rtems5/7.5.0/mpentium/crtend.o
