Can't build application
Ida Delphine idadelm at gmail.com
Sun Jun 13 01:10:04 UTC 2021
Thank you :)
On Sun, Jun 13, 2021 at 12:45 AM Jan Sommer <soja-lists at aries.uberspace.de>
wrote:
> Am Sonntag, 13. Juni 2021, 01:06:02 CEST schrieb Ida Delphine:
> > Hello,
> > I've spent all week trying to build this application and figure out what
> I
> > am missing, I carefully followed the steps in the quickstart guide
> > repeatedly but I keep running into the same error. Some time ago, I built
> > an application as part of my GSoC proof I can work with RTEMS and it
> > worked. Even when I run
> > > find build -name hello.exe
> > It tells me the file hello.exe is present.
> Yes, it tells that the file is located in
> build/sparc-rtems6-erc32/hello.exe
> > If the problem is I probably
> > have a missing "6" somewhere that means the documentation is missing
> > something.
> Yes, there seems to be a typo in the documentation.
> > Here is the screenshot of what I get. If anybody has recently
> > done this successfully with the most recent changes I will really
> > appreciate some help. Been this stuck for a while...
> > [image: Screenshot from 2021-06-12 17-10-34.png]
> This command from the quick start guide essentially tells to run the
> hello.exe.
> $HOME/quick-start/rtems/6/bin/rtems-run --rtems-bsps=erc32-sis
> build/sparc-rtems-erc32/hello.exe
> As you can see from the above find command the hello.exe is located in
> build/sparc-rtems6-erc32/hello.exe, but rtems-run is told that the file is
> in build/sparc-rtems-erc32/hello.exe (notice the missing "6" after "rtems")
>  I really missed this...
> Please try to run
> This should fix your problem.
> Best regards,
> Jan
> > On Mon, Jun 7, 2021 at 6:14 PM Gedare Bloom <gedare at rtems.org> wrote:
> > > On Mon, Jun 7, 2021 at 9:58 AM Ida Delphine <idadelm at gmail.com> wrote:
> > > > Hello everyone,
> > > > I've been following the quick start tutorial and followed the steps
> to
> > > build my application on this link -
> > > https://docs.rtems.org/branches/master/user/start/app.html
> > > > Upon running the executable
> > > on the command line try:
> > > $> find build -name hello.exe
> > > See what comes up. the error message suggests you aren't providing a
> > > file, so maybe you got the path to the executable wrong, assuming the
> > > build succeeded.
> > > My guess is there's a missing 6 somewhere.
> > > > I get this error message
> > > > RTEMS Testing - Run, 6.0.not_released
> > > > Command Line: /home/idadel/quick-start/rtems/6/bin/rtems-run
> > > --rtems-bsps=erc32-sis build/sparc-rtems-erc32/hello.exe
> > > > Host: Linux ida-pc 5.8.0-53-generic #60~20.04.1-Ubuntu SMP Thu May 6
> > > 09:52:46 UTC 2021 x86_64
> > > > Python: 3.8.5 (default, Sep 4 2020, 07:30:14) [GCC 7.3.0]
> > > > Host: Linux-5.8.0-53-generic-x86_64-with-glibc2.10 (Linux ida-pc
> > > 5.8.0-53-generic #60~20.04.1-Ubuntu SMP Thu May 6 09:52:46 UTC 2021
> x86_64
> > > x86_64)
> > > > error: executable is not a file: build/sparc-rtems-erc32/hello.exe
> > > > I followed the same tutorial some time ago and everything went well.
> I
> > > can't seem to wrap my head around where I am going wrong.
> > > > _______________________________________________
> > > > users mailing list
> > > > users at rtems.org
> > > > http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20210613/ff1aef2f/attachment.html>
