Heap allocation for libbsd overwrites IMFS
Sebastian Huber
Wed Jun 23 09:47:05 UTC 2021
On 23/06/2021 10:32, Jan.Sommer at dlr.de wrote:
> One of our applications for the Zedboard fails with fatal error after the setup of the network stack in libbsd.
> So far I traced it down to the point that the memory allocation for libbsd overwrites parts of the IMFS of rtems.
> When opening device files later this will lead to the crash.
> The backtrace looks like this for the bad allocation looks like this:
> _Heap_Block_split ../../../../../c/src/../../cpukit/score/src/heap.c:313 0x10dd58
> _Heap_Block_allocate_from_begin ../../../../../c/src/../../cpukit/score/src/heap.c:378 0x10dfd6
> _Heap_Block_allocate ../../../../../c/src/../../cpukit/score/src/heap.c:465 0x10dfd6
> _Heap_Allocate_aligned_with_boundary ../../../../../c/src/../../cpukit/score/src/heapallocate.c:265 0x10e19c
> rtems_heap_allocate_aligned_with_boundary ../../../../../c/src/../../cpukit/libcsupport/src/malloc_deferred.c:92 0x10962e
> malloc ../../../../../c/src/../../cpukit/libcsupport/src/malloc.c:39 0x10950e
> _bsd_malloc ../../rtemsbsd/rtems/rtems-kernel-malloc.c:80 0x170048
> [more libbsd]
> ifconfig ../../freebsd/sbin/ifconfig/ifconfig.c:1024 0x1724fa
You probably have a general memory corruption issue. As a first step I
would enable RTEMS_DEBUG = True to enable the heap protection. This
could help to debug the issue.
> With 1 GiB of RAM, available memory shouldn't be a problem.
> At the moment we have configured the system with CONFIGURE_UNLIMITED_OBJECTS and CONFIGURE_UNIFIED_WORK_AREAS.
This is fine.
> Maybe that is not right in this case. Are there any suggestions how to better configure the system?
> I found CONFIGURE_MEMORY_OVERHEAD in the docs, but I am not so sure how to use it or if it would help.
No, it would not help.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
