Offline download of sources fails
Wed Mar 10 22:29:09 UTC 2021
On Wed, Mar 10, 2021 at 5:57 AM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Mar 10, 2021, 6:42 AM Ida Delphine <idadelm at gmail.com> wrote:
>> Hello,
>> On trying to download my sources using this command stated in the documentation:
>> ../source-builder/sb-set-builder --source-only-download 5/rtems-sparc
>> Unfortunately, I get some errors and the build fails:
>> RTEMS Source Builder - Set Builder, 6 (47d540e7f9fe)
>> error: exe: not found: (__bison) /usr/bin/bison
>> error: exe: not found: (__flex) /usr/bin/flex
>> error: host build environment is not set up correctly
>> Build FAILED
>> Please what's the way out? I've been trying to resolve this for hours.
> You are missing some programs on your development host.
> There is sb-check which will do a more thorough review of what you should have installed.
> I do not see your host listed but the Users Manual has a section for most host operating systems with detailed instructions for installing the dependencies. You need to use their package manager to install at least bison and flex. You are likely also missing some development libraries needed.
> Check the users guide.
If you're on a  Linux,
https://docs.rtems.org/branches/master/user/hosts/posix.html#linux
Or look nearby, depending on what your host operating system may be
> --joel
>> Cheers,
>> Ida.
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
