Offline download of sources fails
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Thu Mar 11 11:32:51 UTC 2021
> -----Original Message-----
> From: users <users-bounces at rtems.org> On Behalf Of Chris Johns
> Sent: Thursday, March 11, 2021 6:07 AM
> To: Ida Delphine <idadelm at gmail.com>
> Cc: rtems-users at rtems.org <users at rtems.org>
> Subject: Re: Offline download of sources fails
> On 11/3/21 3:34 pm, Ida Delphine wrote:
> > Hello again,
> > So I started over and downloaded all the required packages for my host
> > (Ubuntu
> > 20.04) and still have offline download issues...
> > Please take a look at the error message:
> > RTEMS Source Builder - Set Builder, 6 (fe2d13b6daf3) Build Set:
> > 6/rtems-sparc Build Set: 6/rtems-autotools.bset Build Set:
> > 6/rtems-autotools-internal.bset
> > config: tools/rtems-autoconf-2.69-1.cfg
> > config: tools/rtems-automake-1.12.6-1.cfg Build Sizes: usage: 0.000B
> > total: 19.014KB (sources: 0.000B, patches: 19.014KB, installed 0.000B)
> > Build Set: Time 0:00:00.933172 Build Set: 6/rtems-autotools-base.bset
> > Build Set: Time 0:00:00.840448 Build Set: Time 0:00:01.777350
> > config: devel/expat-2.1.0-1.cfg
> > package: expat-2.1.0-x86_64-linux-gnu-1 Creating source directory:
> > sources
> > download:
> > https://github.com/libexpat/libexpat/releases/download/R_2_1_0/expat-
> 2
> > .1.0.tar.gz
> <https://github.com/libexpat/libexpat/releases/download/R_2_1_0/expat-
> > 2.1.0.tar.gz>
> > -> sources/expat-2.1.0.tar.gz
> >  redirect:
> > https://github-releases.githubusercontent.com/80314213/0186bc60-b675-
> 11e7-83c0-13aced4..
> > <https://github-releases.githubusercontent.com/80314213/0186bc60-
> b675-
> > 11e7-83c0-13aced4..>.<see
> > log>
> > downloading: sources/expat-2.1.0.tar.gz - 549.4kB of 549.4kB (100%)
> > reporting: devel/expat-2.1.0-1.cfg ->
> > expat-2.1.0-x86_64-linux-gnu-1.txt
> > expat-2.1.0-x86_64-linux-gnu-1.xml
> > config: devel/gmp-6.1.0.cfg
> > package: gmp-6.1.0-x86_64-linux-gnu-1
> > download: https://gcc.gnu.org/pub/gcc/infrastructure/gmp-6.1.0.tar.bz2
> > <https://gcc.gnu.org/pub/gcc/infrastructure/gmp-6.1.0.tar.bz2> ->
> > sources/gmp-6.1.0.tar.bz2
> > downloading: sources/gmp-6.1.0.tar.bz2 - 2.3MB of 2.3MB (100%)
> > reporting: devel/gmp-6.1.0.cfg -> gmp-6.1.0-x86_64-linux-gnu-1.txt
> > reporting: devel/gmp-6.1.0.cfg -> gmp-6.1.0-x86_64-linux-gnu-1.xml
> > config: tools/rtems-gdb-10.cfg
> > error: shell macro failed:
> > /home/idadel/quick-start/src/rsb/source-builder/sb/rtems-build-dep -c
> gcc  -l :
> > 2: error: no library (-l) provided
> I think this looks like something with Windows and the shell.
Our nightly test build ran into the same problem.
The runner uses Ubuntu 18.04.
I ran again with the trace option and the error source in question seems to be here:
config: source-builder/config/gdb-common-1.cfg: 118:>%define gdb-python-lib-check %(%{_sbdir}/sb/rtems-build-dep -c %{__cc} %{gdb-host-libs} -l %{gdb-python-config-libs}) [True]
exe: shell: /tmp/rtems-source-builder/source-builder/sb/rtems-build-dep -c gcc  -l
exe: /tmp/rtems-source-builder/source-builder/sb/rtems-build-dep -c gcc  -l
shell-output: 2 error: no library (-l) provided
error: shell macro failed: /tmp/rtems-source-builder/source-builder/sb/rtems-build-dep -c gcc  -l : 2: error: no library (-l) provided
Build Set: Time 0:00:35.508777
I also tried a few earlier commits.
The last working commit for me is
47d540e - (2 days ago) 7: Update tool chain - Sebastian Huber
I don't know very much about the rsb internals, but hope this might help someone who does.
Best regards,
    Jan
> Could you please run with --trace and then search the log file for this the
> above line. The shell macro should be present that failed.
> > Build FAILED
> > Build Set: Time 0:00:12.713688
> > Build FAILED
> > Also for some reason when I run "sb-check" it tells me "command not
> found"
> This looks like a Windows issue.
> Chris
> users mailing list
> users at rtems.org
