Issues with configuring BSP with waf
Ida Delphine idadelm at gmail.com
Fri Mar 12 21:53:46 UTC 2021
Hello,
I did follow the instructions in
https://docs.rtems.org/branches/master/user/start/app.html, added init.c,
modified hello.c and added wscript. I ran the command:
./waf configure --rtems=$HOME/quick-start/rtems/6 --rtems-bsp=sparc/erc32
But still ended with same error like before. I don't know what I am
missing. I don't think I have skipped any step.
Still got this error:
Setting top to                           :
/home/idadel/quick-start/app/hello
Setting out to                           :
/home/idadel/quick-start/app/hello/build
RTEMS path is not valid, "/home/idadel/quick-start/rtems/6/share/rtems5"
not found.
(complete log in /home/idadel/quick-start/app/hello/build/config.log)
On Fri, Mar 12, 2021 at 5:43 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Mar 11, 2021 at 10:55 PM Ida Delphine <idadelm at gmail.com> wrote:
> > Hello,
> > Please I need some help. Following the GSoC getting started guide(
> https://docs.rtems.org/branches/master/user/start/gsoc.html),everything
> went well to the point I had to do an offline download. I used this command
> > ../source-builder/sb-set-builder --source-only-download 5/rtems-sparc
> > Seems like there was a mismatch. I got this error:
> > RTEMS Source Builder - Set Builder, 6 (5e449fb5c2cb)
> > Build Set: 5/rtems-sparc
> > error: no build set file found: 5/rtems-sparc.bset
> > Build Set: Time 0:00:00.000205
> > Build FAILED
> > I then replaced 5/rtems in the command with 6/rtems and everything
> worked. I was able to install the suite, build the board support package,
> and test my BSP though along the way I had to replace "5" with "6" in
> certain commands. Everything went well until I wanted to prove I can work
> on RTEMS. I followed the instructions to create my hello application and
> added the necessary .c files. The problem was when I tried configuring this
> application using waf with the command:
> This is really great and you are very close. We definitely do want you
> to be using '6' and not '5' for GSoC.
> > ./waf configure --rtems=$HOME/quick-start/rtems/5 --rtems-bsp=sparc/erc32
> Although you can create a standalone hello application, and that would
> be an excellent way to show some progress, for the GSoC "proof" we
> actually want you to modify the hello that gets built as part of
> rtems. Its source is located in rtems.git/testsuites/samples/hello
> Then you will rebuild rtems and it should recompile your modified hello
> sample.
> > I got this error:
> > Setting top to                           :
> > Setting out to                           :
> > RTEMS path is not valid, "/home/idadel/quick-start/rtems/5/share/rtems5"
> not found.
> > I thought I showld startover but and work with rtems.git/5 instead of
> rtems.git/master. Same with rsb. So I got the sources and did a "git
> checkout"  from the master to the "5" branch. Everything went well with me
> not not having to change any "5" to "6" in some commands. I didn't make it
> as far as testing my BSP. I had issues with configuring my BSP with the
> command:
> > I got this:
> > bash: ./waf: No such file or directory
> > I'm confused and don't know what I missed or where I went wrong.
> > Ida.
> > On Thu, Mar 11, 2021 at 6:03 PM Ida Delphine <idadelm at gmail.com> wrote:
> >> Okay. Thank you :)
> >> On Thu, 11 Mar 2021, 5:57 pm Gedare Bloom, <gedare at rtems.org> wrote:
> >>> On Thu, Mar 11, 2021 at 9:48 AM Ida Delphine <idadelm at gmail.com>
> wrote:
> >>> > Thank you for your response. I am not working on the
> rtems.git/master branch. I'm not using it because earlier I tried
> downloading sources with it but I got this error
> >>> > error: shell macro failed:
> /home/idadel/quick-start/src/rsb/source-builder/sb/rtems-build-dep -c gcc
> -l : 2: error: no library (-l) provided
> >>> > So I decided to use the other alternative(get the sources from
> releases)
> >>> > Since I'm a GSoC applicant should I wait till the issue at the
> master branch is resolved?
> >>> Yes, that issue has been resolved so please try again. Hopefully,
> >>> things work a bit better. We try not to break things, but unexpected
> >>> problems come up from time to time, especially based on host OS
> >>> dependencies.
> >>> > Cheers,
> >>> > Ida.
> >>> > On Thu, Mar 11, 2021 at 4:18 PM Gedare Bloom <gedare at rtems.org>
> wrote:
> >>> >> On Thu, Mar 11, 2021 at 7:33 AM Ida Delphine <idadelm at gmail.com>
> wrote:
> >>> >> > Hello everyone,
> >>> >> > Was following the quick build documentation and had issues around
> where I have to do a manual BSP build.  In the last step of configuring the
> BSP, I ran this command:
> >>> >> > ./waf configure --prefix=$HOME/quick-start/rtems/5
> >>> >> Are you working on rtems.git/master branch or /5 branch? Note that
> you
> >>> >> need to be sure to use a consistent compiler toolchain based on the
> >>> >> version of RTEMS that you use.
> >>> >> In rtems/5 branch we don't have waf support integrated yet. The
> >>> >> upgrade to waf is happening currently on the master branch, which
> will
> >>> >> eventually become the RTEMS version 6 release.
> >>> >> For GSoC students we expect development to happen on the development
> >>> >> head and not a release, so please make sure that you have the
> >>> >> toolchain built from rtems-source-builder.git/master and the rtems
> >>> >> source tree from rtems.git/master.
> >>> >> > It didn't produce the expected output. I instead got:
> >>> >> > As a result I downloaded it with the command:
> >>> >> > curl https://waf.io/waf-2.0.19 > waf
> >>> >> https://git.rtems.org/rtems/tree/waf
> >>> >> Currently, the waf-based build of rtems only supports "in tree"
> >>> >> builds, which means you need to run waf from within the rtems.git/
> >>> >> root of your source. This is a limitation of the waf build.
> >>> >> FWIW, waf build improvements could also fall under GSoC effort,
> >>> >> although no one has written it up as a task yet. It would be mostly
> >>> >> Python.
> >>> >> > I ran  the last command to configure the BSP again but still did
> not get the expected  output. I got this rather:
> >>> >> > Waf: Run from a folder containing a 'wscript' file (or try -h for
> the generic options)
> >>> >> > Please how do I fix this? What am I missing?
> >>> >> > I have tried looking for solutions but to no avail.
> >>> >> Sometimes the solutions only exist inside other people's heads, so
> >>> >> asking questions is encouraged.
> >>> >> > Thanks,
> >>> >> > Ida.
> >>> >> > _______________________________________________
> >>> >> > users mailing list
> >>> >> > users at rtems.org
> >>> >> > http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20210312/b73e0452/attachment-0001.html>
