RTEMS 5 how to run "hello" example
Vijay Kumar Banerjee
vijay at rtems.org
Mon Mar 15 19:36:31 UTC 2021
On Mon, Mar 15, 2021 at 1:30 PM Olga Syrbachova <syrba4eva28 at gmail.com> wrote:
> Thank you very much for your reply!
> Unfortunately I'm still a bit confused and don't quite understand what to do. Where do I need to modify the "include" parameter? In the wscript file from the "hello" example there is no "include" parameter. I also tried to find a tutorial on how to write a wscript, but didn't find any (Could you suggest any please?). So I tried to copy the file "tmacros.h" from testsuites/support/include to app/ticker. Now after running ./waf I get an error, which tells me that "buffer_test_io.h" wasn't found. When I copied it to my app/ticker directory it didn't work and I still have the same error.
Would it be possible for you to paste your wscript somewhere (like
gist.github.com) and share it here so that we can have a look and help
you with that?
Best regards,
Vijay
> Waf: Entering directory `/home/olga/development/app/ticker/build/sparc-rtems5-erc32'
> [1/3] Compiling tasks.c
> [2/3] Compiling init.c
> In file included from ../../system.h:17:0,
> from ../../init.c:15:
> ../../tmacros.h:32:10: fatal error: buffer_test_io.h: No such file or directory
> #include <buffer_test_io.h>
> compilation terminated.
> from ../../tasks.c:22:
> Waf: Leaving directory `/home/olga/development/app/ticker/build/sparc-rtems5-erc32'
> Build failed
> -> task in 'ticker.exe' failed with exit status 1 (run with -v to display more information)
> On Mon, 15 Mar 2021 at 16:21, Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>> Hi Olga,
>> On Mon, Mar 15, 2021 at 8:29 AM Olga Syrbachova <syrba4eva28 at gmail.com> wrote:
>> > I've built the RTEMS Kernel for erc32. Then I followed this tutorial https://docs.rtems.org/branches/master/user/start/app.html to build a "Hello World" application and it works just fine. Then I've tried to create another application following the steps in the tutorial.
>> > 1. In $HOME/development/app/ I created a directory "ticker".
>> > 2. cd ticker
>> > 3. curl https://waf.io/waf-2.0.19 > waf
>> > chmod +x waf
>> > git init
>> > git submodule add git://git.rtems.org/rtems_waf.git rtems_waf
>> > 4. I've copied the files "init.c", "tasks.c", "system.h" from testsuites/samples
>> > 5. In the "wscript" I've changed the lines 32 and 34 to target = 'ticker.exe', source = ['init.c', 'tasks.c']
>> > 6. ./waf configure --rtems=$HOME/development/rtems/5 --rtems-bsp=sparc/erc32
>> > 7. and running ./waf next, I get an error. It looks like the file "tmacros.h", which is included in "system.h", cannot be found.
>> You have changed the "target" and "source" parameters in your wscript.
>> You'd also need to modify the "include" parameter and add relative
>> path to tmacros.h. For multiple headers, you'll have to add the paths
>> as a string with space-separated values or a list like this:
>> `includes='./ ../ ./path/to/include/'`
>> > What am I doing wrong? Is the way to run other examples exactly the same as to run a "Hello World" example?
>> The other examples will also follow a similar wscript structure but
>> hello world is the simple one with fewer includes so it's a good place
>> to start if you're trying to learn how to make a separate project with
>> RTEMS applications using waf.
>> Best regards,
>> Vijay
>> > _______________________________________________
>> > users mailing list
>> > users at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/users
