RTEMS 5 how to run "hello" example
Vijay Kumar Banerjee vijay at rtems.org
Mon Mar 15 19:59:53 UTC 2021
On Mon, Mar 15, 2021 at 1:53 PM Olga Syrbachova <syrba4eva28 at gmail.com> wrote:
> Sure! https://github.com/syrba4eva/RTEMS/blob/main/wscript
Thanks. In this line: https://github.com/syrba4eva/RTEMS/blob/main/wscript#L33
After cflags parameter, add "includes", for example:
bld(features = 'c cprogram',
      target = 'ticker.exe',
      cflags = '-g -O2',
      includes='. .. ./original/path/to/tmacros.h',
      source = ['init.c', 'tasks.c'])
you don't need to copy tmacros.h or any headers from rtems, just add
the path to includes.
Best regards,
Vijay
> On Mon, 15 Mar 2021 at 20:36, Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>> On Mon, Mar 15, 2021 at 1:30 PM Olga Syrbachova <syrba4eva28 at gmail.com> wrote:
>> > Thank you very much for your reply!
>> > Unfortunately I'm still a bit confused and don't quite understand what to do. Where do I need to modify the "include" parameter? In the wscript file from the "hello" example there is no "include" parameter. I also tried to find a tutorial on how to write a wscript, but didn't find any (Could you suggest any please?). So I tried to copy the file "tmacros.h" from testsuites/support/include to app/ticker. Now after running ./waf I get an error, which tells me that "buffer_test_io.h" wasn't found. When I copied it to my app/ticker directory it didn't work and I still have the same error.
>> Would it be possible for you to paste your wscript somewhere (like
>> gist.github.com) and share it here so that we can have a look and help
>> you with that?
>> Best regards,
>> Vijay
>> > Waf: Entering directory `/home/olga/development/app/ticker/build/sparc-rtems5-erc32'
>> > [1/3] Compiling tasks.c
>> > [2/3] Compiling init.c
>> > In file included from ../../system.h:17:0,
>> >                  from ../../init.c:15:
>> > ../../tmacros.h:32:10: fatal error: buffer_test_io.h: No such file or directory
>> >  #include <buffer_test_io.h>
>> > compilation terminated.
>> >                  from ../../tasks.c:22:
>> > Waf: Leaving directory `/home/olga/development/app/ticker/build/sparc-rtems5-erc32'
>> > Build failed
>> >  -> task in 'ticker.exe' failed with exit status 1 (run with -v to display more information)
>> > On Mon, 15 Mar 2021 at 16:21, Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>> >> Hi Olga,
>> >> On Mon, Mar 15, 2021 at 8:29 AM Olga Syrbachova <syrba4eva28 at gmail.com> wrote:
>> >> > I've built the RTEMS Kernel for erc32. Then I followed this tutorial https://docs.rtems.org/branches/master/user/start/app.html to build a "Hello World" application and it works just fine. Then I've tried to create another application following the steps in the tutorial.
>> >> > 1. In $HOME/development/app/ I created a directory "ticker".
>> >> > 2. cd ticker
>> >> > 3. curl https://waf.io/waf-2.0.19 > waf
>> >> >     chmod +x waf
>> >> >     git init
>> >> >     git submodule add git://git.rtems.org/rtems_waf.git rtems_waf
>> >> > 4. I've copied the files "init.c", "tasks.c", "system.h" from testsuites/samples
>> >> > 5. In the "wscript" I've changed the lines 32 and 34 to target = 'ticker.exe', source = ['init.c', 'tasks.c']
>> >> > 6. ./waf configure --rtems=$HOME/development/rtems/5 --rtems-bsp=sparc/erc32
>> >> > 7. and running ./waf next, I get an error. It looks like the file "tmacros.h", which is included in "system.h", cannot be found.
>> >> You have changed the "target" and "source" parameters in your wscript.
>> >> You'd also need to modify the "include" parameter and add relative
>> >> path to tmacros.h. For multiple headers, you'll have to add the paths
>> >> as a string with space-separated values or a list like this:
>> >> `includes='./ ../ ./path/to/include/'`
>> >> > What am I doing wrong? Is the way to run other examples exactly the same as to run a "Hello World" example?
>> >> The other examples will also follow a similar wscript structure but
>> >> hello world is the simple one with fewer includes so it's a good place
>> >> to start if you're trying to learn how to make a separate project with
>> >> RTEMS applications using waf.
>> >> Best regards,
>> >> Vijay
>> >> > _______________________________________________
>> >> > users mailing list
>> >> > users at rtems.org
>> >> > http://lists.rtems.org/mailman/listinfo/users
