RTEMS 5 how to run "hello" example
Olga Syrbachova
syrba4eva28 at gmail.com
Tue Mar 16 18:40:18 UTC 2021
Thank you very much for your reply and for your concern!
Actually I'd like to create my own application and test some mechanisms,
provided by RTEMS. This is a part of my Bachelor Thesis. I'd like,
for example, to create two/three tasks and make them communicate with each
other via queues, schedule them by priority etc. I have some experience
with FreeRTOS. It is run via Visual Studio, which is quite simple. And now
with RTEMS I am a bit frustrated and don't know where to start. That's why
I followed the tutorial on the Website. "Hello World" program worked just
fine, so I decided to try some more complicated applications before I start
with my own, that's why I decided to build "ticker" with waf. Unfortunately
I didn't find any helpful (for me) tutorial on how to create applications
in RTEMS. I mean I can handle writing the App's code, but I don't get it
how to compile and run it. So I was just going to do the same as in the
tutorial, but with my own application. Is it the right way to proceed or is
there another way ?
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
Virenfrei.
www.avast.com
<#m_6778778117170402098_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
On Tue, 16 Mar 2021 at 16:29, Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> On Tue, Mar 16, 2021 at 4:07 AM Olga Syrbachova <syrba4eva28 at gmail.com>
> wrote:
> > Thank you very much for your reply!
> > I've added
> > includes =
> '/home/olga/development/rtems/rtems-5/testsuites/support/include/tmacros.h',
> It takes the relative address to the directory where the header file
> is. For example, if you're building from the
> "/home/olga/development/rtems" directory the includes argument would
> be:
> `includes = './rtems-5/testsuites/support/include/'`
> BTW, your first email at the start of the thread says that you just
> want to run the samples, the samples get built as a part of the rtems
> and you'll be able to see the *.exe files in the build directory. Is
> there any reason that you're trying to build it in a separate
> directory with waf? Experimenting with the build system is a good
> reason though, just making sure that we're not pushing you in the
> wrong direction and your objective is indeed to try waf on your own
> and not just running RTEMS hello app.
> Best regards,
> Vijay
> > it still says "No such file or directory". I'm pretty sure the path is
> write, though there is now another path to "tmacros.h" (the first one
> below), it's a folder named "tmacros.h" and it's empty.
> > olga at olga-H270M-DS3H:~$ locate tmacros.h
> /home/olga/development/app/ticker/build/sparc-rtems5-erc32/$HOME/developement/rtems/rtems-5/testsuites/support/include/tmacros.h
> > On Mon, 15 Mar 2021 at 21:00, Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
> >> On Mon, Mar 15, 2021 at 1:53 PM Olga Syrbachova <syrba4eva28 at gmail.com>
> wrote:
> >> > Sure! https://github.com/syrba4eva/RTEMS/blob/main/wscript
> >> Thanks. In this line:
> https://github.com/syrba4eva/RTEMS/blob/main/wscript#L33
> >> After cflags parameter, add "includes", for example:
> >> bld(features = 'c cprogram',
> >> target = 'ticker.exe',
> >> cflags = '-g -O2',
> >> includes='. .. ./original/path/to/tmacros.h',
> >> source = ['init.c', 'tasks.c'])
> >> you don't need to copy tmacros.h or any headers from rtems, just add
> >> the path to includes.
> >> Best regards,
> >> Vijay
> >> > On Mon, 15 Mar 2021 at 20:36, Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
> >> >> On Mon, Mar 15, 2021 at 1:30 PM Olga Syrbachova <
> >> >> > Unfortunately I'm still a bit confused and don't quite understand
> what to do. Where do I need to modify the "include" parameter? In the
> wscript file from the "hello" example there is no "include" parameter. I
> also tried to find a tutorial on how to write a wscript, but didn't find
> any (Could you suggest any please?). So I tried to copy the file
> "tmacros.h" from testsuites/support/include to app/ticker. Now after
> running ./waf I get an error, which tells me that "buffer_test_io.h" wasn't
> found. When I copied it to my app/ticker directory it didn't work and I
> still have the same error.
> >> >> Would it be possible for you to paste your wscript somewhere (like
> >> >> gist.github.com) and share it here so that we can have a look and
> help
> >> >> you with that?
> >> >> Best regards,
> >> >> Vijay
> >> >> > Waf: Entering directory
> `/home/olga/development/app/ticker/build/sparc-rtems5-erc32'
> >> >> > [1/3] Compiling tasks.c
> >> >> > [2/3] Compiling init.c
> >> >> > In file included from ../../system.h:17:0,
> >> >> > from ../../init.c:15:
> >> >> > ../../tmacros.h:32:10: fatal error: buffer_test_io.h: No such file
> or directory
> >> >> > #include <buffer_test_io.h>
> >> >> > compilation terminated.
> >> >> > from ../../tasks.c:22:
> or directory
> >> >> > Waf: Leaving directory
> >> >> > Build failed
> >> >> > -> task in 'ticker.exe' failed with exit status 1 (run with -v to
> display more information)
> >> >> > On Mon, 15 Mar 2021 at 16:21, Vijay Kumar Banerjee <
> >> >> >> Hi Olga,
> >> >> >> On Mon, Mar 15, 2021 at 8:29 AM Olga Syrbachova <
> >> >> >> > I've built the RTEMS Kernel for erc32. Then I followed this
> tutorial https://docs.rtems.org/branches/master/user/start/app.html to
> build a "Hello World" application and it works just fine. Then I've tried
> to create another application following the steps in the tutorial.
> >> >> >> > 1. In $HOME/development/app/ I created a directory "ticker".
> >> >> >> > 2. cd ticker
> >> >> >> > 3. curl https://waf.io/waf-2.0.19 > waf
> >> >> >> > chmod +x waf
> >> >> >> > git init
> >> >> >> > git submodule add git://git.rtems.org/rtems_waf.git
> rtems_waf
> >> >> >> > 4. I've copied the files "init.c", "tasks.c", "system.h" from
> testsuites/samples
> >> >> >> > 5. In the "wscript" I've changed the lines 32 and 34 to target
> = 'ticker.exe', source = ['init.c', 'tasks.c']
> >> >> >> > 6. ./waf configure --rtems=$HOME/development/rtems/5
> --rtems-bsp=sparc/erc32
> >> >> >> > 7. and running ./waf next, I get an error. It looks like the
> file "tmacros.h", which is included in "system.h", cannot be found.
> >> >> >> You have changed the "target" and "source" parameters in your
> wscript.
> >> >> >> You'd also need to modify the "include" parameter and add relative
> >> >> >> path to tmacros.h. For multiple headers, you'll have to add the
> paths
> >> >> >> as a string with space-separated values or a list like this:
> >> >> >> `includes='./ ../ ./path/to/include/'`
> >> >> >> > What am I doing wrong? Is the way to run other examples exactly
> the same as to run a "Hello World" example?
> >> >> >> The other examples will also follow a similar wscript structure
> but
> >> >> >> hello world is the simple one with fewer includes so it's a good
> place
> >> >> >> to start if you're trying to learn how to make a separate project
> with
> >> >> >> RTEMS applications using waf.
> >> >> >> Best regards,
> >> >> >> Vijay
> >> >> >> > _______________________________________________
> >> >> >> > users mailing list
> >> >> >> > users at rtems.org
> >> >> >> > http://lists.rtems.org/mailman/listinfo/users
Virenfrei.
www.avast.com
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
URL: <http://lists.rtems.org/pipermail/users/attachments/20210316/effd8e46/attachment.html>
