RTEMS 5 how to run "hello" example
Olga Syrbachova syrba4eva28 at gmail.com
Thu Mar 18 09:21:57 UTC 2021
Thank you very much for your reply! I really appreciate that someone is
still trying to help me after so many questions from me :)
I've got an error again, so I will describe here all my steps in case I'm
doing something wrong and you can see where the problem could be.
1.
olga at olga-H270M-DS3H:~/development$ git clone git://
git.rtems.org/rtems-examples.git
2.
olga at olga-H270M-DS3H:~/development$ cd rtems-examples
3.
olga at olga-H270M-DS3H:~/development/rtems-examples$ git submodule init
Submodule 'rtems_waf' (git://git.rtems.org/rtems_waf.git) registered for
path 'rtems_waf'
olga at olga-H270M-DS3H:~/development/rtems-examples$ git submodule update
Cloning into '/home/olga/development/rtems-examples/rtems_waf'...
Submodule path 'rtems_waf': checked out 'ad0890
4.
olga at olga-H270M-DS3H:~/development/rtems-examples$ ./waf configure
--rtems=$HOME/development/rtems/5 --rtems-tools=$HOME/development/rtems/5
--rtems-bsps=sparc/erc32
Setting top to                           :
Setting out to                           :
/home/olga/development/rtems-examples/build
RTEMS path is not valid, "/home/olga/development/rtems/5/share/rtems6" not
found.
(complete log in /home/olga/development/rtems-examples/build/config.log)
8c452c6a9bbb3bf7bbbcc9fc03fe46cc7f'
As it was suggested by Gedare Bloom before: "We do encourage to try to use
waf to build the examples though, so let's focus on that direction." I
would really like to understand how to build the examples and later my own
apps using waf :)
On Wed, 17 Mar 2021 at 22:49, Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Mar 17, 2021 at 2:23 PM Olga Syrbachova <syrba4eva28 at gmail.com>
> wrote:
>> Thank you very much for your reply! I'm still confused about all the
>> prefixes and PATHs. In the README.waf it is said to run
>> $ waf configure --rtems=$HOME/Development/rtems/5 \
>> --rtems-tools=$HOME/Development/rtems/5 \
>> where $HOME/Development/rtems/build/5 is the path to tools and
>> $HOME/Development/rtems/build/5 is the path to RTEMS Board Support
>> Packages.
>> I followed this tutorial
>> https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
>> installing RTEMS and building BSP. So in my case I built the tool suit in development/rtems/src/rsb/rtems
>> $ ../source-builder/sb-set-builder --prefix=$HOME/development/rtems/5 5/rtems-sparc
>> So the path to tools development/rtems/src/rsb/rtems, is it right? And
>> I'm not sure what is a path to RTEMS Board Support Packages.
> All paths referenced by README.waf are installed paths, i.e., the prefix
> that you used. It looks like that would be $HOME/development/rtems/5 for
> your case, for the tools (as passed to sb-set-builder) and for rtems (if
> you followed that blog post, it specifies the prefix to configure).
>> On Wed, 17 Mar 2021 at 18:48, Gedare Bloom <gedare at rtems.org> wrote:
>>> On Wed, Mar 17, 2021 at 10:22 AM Olga Syrbachova <syrba4eva28 at gmail.com>
>>> wrote:
>>>> What do you mean "regular README file"? There are 3 of them: README,
>>>> README.Makefile and README.waf. In README there is just a list of examples.
>>>> I tried to follow the README.Makefile instructions, and after running:
>>> Thanks I forgot we put those instructions into README.Makefile.
>>>> olga at olga-H270M-DS3H:~/development/rtems-examples/hello/hello_world_c$
>>>> RTEMS_MAKEFILE_PATH=${HOME}/development/rtems/5/sparc-rtems5/erc32 make
>>>> clean
>>>> and
>>>> there appeared an empty folder "o-optimize" in the examples's
>>>> directory. What's next?
>>>> Weird, I'll take a look. We do encourage to try to use waf to build the
>> BTW: This worked for me. If you like, you can show what is the terminal
> output from the second line
> `RTEMS_MAKEFILE_PATH=${HOME}/development/rtems/5/sparc-rtems5/erc32 make`?
>> And what do you mean "use ./waf"? When I run ./waf in "rtems-examples",
>>>> it says
>>>> The project was not configured: run "waf configure" first!
>>>> olga at olga-H270M-DS3H:~/development/rtems-examples$ waf configure --rtems=$HOME/development/rtems/build/5 \--rtems-tools=$HOME/development/rtems/5 \--rtems-bsps=sparc/erc32
>>>  ./waf configure --rtems=$HOME/development/rtems/build/5
>>>> Command 'waf' not found, did you mean: ...
>>>>   command 'paf' from deb libpod-abstract-perl
>>>>   command 'wdf' from deb wit
>>>> On Wed, 17 Mar 2021 at 16:51, Gedare Bloom <gedare at rtems.org> wrote:
>>>>> On Wed, Mar 17, 2021 at 9:11 AM Olga Syrbachova <syrba4eva28 at gmail.com>
>>>>> wrote:
>>>>>> Thanks a lot! I have one more stupid question. How do I run examples
>>>>>> from git? I've cloned rtems-examples and tried to follow the instructions
>>>>>> from "README.waf", but it doesn't work. When I enter
>>>>>>     $ waf configure --rtems=$HOME/development/rtems/bsps/5 \
>>>>>> I get this error:
>>>>>> Use ./waf
>>>>>> I probably do something wrong. Do I need to do the instructions from "README.waf" at all? Or do I need to proceed as in this tutorial https://docs.rtems.org/branches/master/user/start/app.html with every example's directory? I would really appreciate some step-by-step tutorial or instructions as I'm totally frustrated right now and don't understand what to do.
>>>>>> Btw there is a makefile in every example's directory. Can I use it instead of waf to compile the applications? If this is the case how do I do it?
>>>>>> You can do either way of building the examples, see the regular
>>>>> README file for directions on the Makefile approach.
>>>>>> Many thanks in advance for any help!!!
>>>>>> On Tue, 16 Mar 2021 at 20:07, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>> On Tue, Mar 16, 2021 at 1:40 PM Olga Syrbachova <
>>>>>>> syrba4eva28 at gmail.com> wrote:
>>>>>>>> Thank you very much for your reply and for your concern!
>>>>>>>> Actually I'd like to create my own application and test some
>>>>>>>> mechanisms, provided by RTEMS. This is a part of my Bachelor Thesis. I'd
>>>>>>>> like, for example, to create two/three tasks and make them communicate
>>>>>>>> with each other via queues, schedule them by priority etc. I have some
>>>>>>>> experience with FreeRTOS. It is run via Visual Studio, which is quite
>>>>>>>> simple. And now with RTEMS I am a bit frustrated and don't know where to
>>>>>>>> start. That's why I followed the tutorial on the Website. "Hello World"
>>>>>>>> program worked just fine, so I decided to try some more complicated
>>>>>>>> applications before I start with my own, that's why I decided to build
>>>>>>>> "ticker" with waf. Unfortunately I didn't find any helpful (for me)
>>>>>>>> tutorial on how to create applications in RTEMS. I mean I can handle
>>>>>>>> writing the App's code, but I don't get it how to compile and run it. So I
>>>>>>>> was just going to do the same as in the tutorial, but with my own
>>>>>>>> application. Is it the right way to proceed or is there another way ?
>>>>>>> The tests in RTEMS are just that tests. They depend on things that
>>>>>>> shouldn't be installed or used by user applications.
>>>>>>> I would recommend cloning rtems-examples and going from one of
>>>>>>> those. There is a directory with variations on ticker and I suspect the
>>>>>>> base one is a better one to start from.
>>>>>>> If you want to write POSIX code, one of the POSIX examples there
>>>>>>> would serve you ok
>>>>>>> --joel
>>>>>>>> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> Virenfrei.
>>>>>>>> www.avast.com
>>>>>>>> <#m_-4707991134687881431_m_2587329209695249861_m_-6228330996423727151_m_-6868087392309282603_m_-8071420466793372504_m_971219196135651785_m_277508452244861825_m_-8462729502950921950_m_6778778117170402098_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>>>>>>>> On Tue, 16 Mar 2021 at 16:29, Vijay Kumar Banerjee <vijay at rtems.org>
>>>>>>>> wrote:
>>>>>>>>> On Tue, Mar 16, 2021 at 4:07 AM Olga Syrbachova <
>>>>>>>>> > I've added
>>>>>>>>> > includes =
>>>>>>>>> '/home/olga/development/rtems/rtems-5/testsuites/support/include/tmacros.h',
>>>>>>>>> It takes the relative address to the directory where the header
>>>>>>>>> file
>>>>>>>>> is. For example, if you're building from the
>>>>>>>>> "/home/olga/development/rtems" directory the includes argument
>>>>>>>>> would
>>>>>>>>> be:
>>>>>>>>> `includes = './rtems-5/testsuites/support/include/'`
>>>>>>>>> BTW, your first email at the start of the thread says that you just
>>>>>>>>> want to run the samples, the samples get built as a part of the
>>>>>>>>> rtems
>>>>>>>>> and you'll be able to see the *.exe files in the build directory.
>>>>>>>>> Is
>>>>>>>>> there any reason that you're trying to build it in a separate
>>>>>>>>> directory with waf? Experimenting with the build system is a good
>>>>>>>>> reason though, just making sure that we're not pushing you in the
>>>>>>>>> wrong direction and your objective is indeed to try waf on your own
>>>>>>>>> and not just running RTEMS hello app.
>>>>>>>>> Best regards,
>>>>>>>>> Vijay
>>>>>>>>> > it still says "No such file or directory". I'm pretty sure the
>>>>>>>>> path is write, though there is now another path to "tmacros.h" (the first
>>>>>>>>> one below), it's a folder named "tmacros.h" and it's empty.
>>>>>>>>> > olga at olga-H270M-DS3H:~$ locate tmacros.h
>>>>>>>>> /home/olga/development/app/ticker/build/sparc-rtems5-erc32/$HOME/developement/rtems/rtems-5/testsuites/support/include/tmacros.h
>>>>>>>>> > On Mon, 15 Mar 2021 at 21:00, Vijay Kumar Banerjee <
>>>>>>>>> vijay at rtems.org> wrote:
>>>>>>>>> >> On Mon, Mar 15, 2021 at 1:53 PM Olga Syrbachova <
>>>>>>>>> >> > Sure! https://github.com/syrba4eva/RTEMS/blob/main/wscript
>>>>>>>>> >> Thanks. In this line:
>>>>>>>>> https://github.com/syrba4eva/RTEMS/blob/main/wscript#L33
>>>>>>>>> >> After cflags parameter, add "includes", for example:
>>>>>>>>> >> bld(features = 'c cprogram',
>>>>>>>>> >>       target = 'ticker.exe',
>>>>>>>>> >>       cflags = '-g -O2',
>>>>>>>>> >>       includes='. .. ./original/path/to/tmacros.h',
>>>>>>>>> >>       source = ['init.c', 'tasks.c'])
>>>>>>>>> >> you don't need to copy tmacros.h or any headers from rtems,
>>>>>>>>> just add
>>>>>>>>> >> the path to includes.
>>>>>>>>> >> Best regards,
>>>>>>>>> >> Vijay
>>>>>>>>> >> > On Mon, 15 Mar 2021 at 20:36, Vijay Kumar Banerjee <
>>>>>>>>> >> >> On Mon, Mar 15, 2021 at 1:30 PM Olga Syrbachova <
>>>>>>>>> >> >> > Unfortunately I'm still a bit confused and don't quite
>>>>>>>>> understand what to do. Where do I need to modify the "include" parameter?
>>>>>>>>> In the wscript file from the "hello" example there is no "include"
>>>>>>>>> parameter. I also tried to find a tutorial on how to write a wscript, but
>>>>>>>>> didn't find any (Could you suggest any please?). So I tried to copy the
>>>>>>>>> file "tmacros.h" from testsuites/support/include to app/ticker. Now after
>>>>>>>>> running ./waf I get an error, which tells me that "buffer_test_io.h" wasn't
>>>>>>>>> found. When I copied it to my app/ticker directory it didn't work and I
>>>>>>>>> still have the same error.
>>>>>>>>> >> >> Would it be possible for you to paste your wscript somewhere
>>>>>>>>> (like
>>>>>>>>> >> >> gist.github.com) and share it here so that we can have a
>>>>>>>>> look and help
>>>>>>>>> >> >> you with that?
>>>>>>>>> >> >> Best regards,
>>>>>>>>> >> >> Vijay
>>>>>>>>> >> >> > Waf: Entering directory
>>>>>>>>> `/home/olga/development/app/ticker/build/sparc-rtems5-erc32'
>>>>>>>>> >> >> > [1/3] Compiling tasks.c
>>>>>>>>> >> >> > [2/3] Compiling init.c
>>>>>>>>> >> >> > In file included from ../../system.h:17:0,
>>>>>>>>> >> >> >                  from ../../init.c:15:
>>>>>>>>> >> >> > ../../tmacros.h:32:10: fatal error: buffer_test_io.h: No
>>>>>>>>> >> >> >  #include <buffer_test_io.h>
>>>>>>>>> >> >> > compilation terminated.
>>>>>>>>> >> >> >                  from ../../tasks.c:22:
>>>>>>>>> >> >> > Waf: Leaving directory
>>>>>>>>> >> >> > Build failed
>>>>>>>>> >> >> >  -> task in 'ticker.exe' failed with exit status 1 (run
>>>>>>>>> with -v to display more information)
>>>>>>>>> >> >> > On Mon, 15 Mar 2021 at 16:21, Vijay Kumar Banerjee <
>>>>>>>>> >> >> >> Hi Olga,
>>>>>>>>> >> >> >> On Mon, Mar 15, 2021 at 8:29 AM Olga Syrbachova <
>>>>>>>>> >> >> >> > I've built the RTEMS Kernel for erc32. Then I followed
>>>>>>>>> this tutorial
>>>>>>>>> https://docs.rtems.org/branches/master/user/start/app.html to
>>>>>>>>> build a "Hello World" application and it works just fine. Then I've tried
>>>>>>>>> to create another application following the steps in the tutorial.
>>>>>>>>> >> >> >> > 1. In $HOME/development/app/ I created a directory
>>>>>>>>> "ticker".
>>>>>>>>> >> >> >> > 2. cd ticker
>>>>>>>>> >> >> >> > 3. curl https://waf.io/waf-2.0.19 > waf
>>>>>>>>> >> >> >> >     chmod +x waf
>>>>>>>>> >> >> >> >     git init
>>>>>>>>> >> >> >> >     git submodule add git://git.rtems.org/rtems_waf.git
>>>>>>>>> rtems_waf
>>>>>>>>> >> >> >> > 4. I've copied the files "init.c", "tasks.c",
>>>>>>>>> "system.h" from testsuites/samples
>>>>>>>>> >> >> >> > 5. In the "wscript" I've changed the lines 32 and 34 to
>>>>>>>>> target = 'ticker.exe', source = ['init.c', 'tasks.c']
>>>>>>>>> >> >> >> > 6. ./waf configure --rtems=$HOME/development/rtems/5
>>>>>>>>> --rtems-bsp=sparc/erc32
>>>>>>>>> >> >> >> > 7. and running ./waf next, I get an error. It looks
>>>>>>>>> like the file "tmacros.h", which is included in "system.h", cannot be found.
>>>>>>>>> >> >> >> You have changed the "target" and "source" parameters in
>>>>>>>>> your wscript.
>>>>>>>>> >> >> >> You'd also need to modify the "include" parameter and add
>>>>>>>>> relative
>>>>>>>>> >> >> >> path to tmacros.h. For multiple headers, you'll have to
>>>>>>>>> add the paths
>>>>>>>>> >> >> >> as a string with space-separated values or a list like
>>>>>>>>> this:
>>>>>>>>> >> >> >> `includes='./ ../ ./path/to/include/'`
>>>>>>>>> >> >> >> > What am I doing wrong? Is the way to run other examples
>>>>>>>>> exactly the same as to run a "Hello World" example?
>>>>>>>>> >> >> >> The other examples will also follow a similar wscript
>>>>>>>>> structure but
>>>>>>>>> >> >> >> hello world is the simple one with fewer includes so it's
>>>>>>>>> a good place
>>>>>>>>> >> >> >> to start if you're trying to learn how to make a separate
>>>>>>>>> project with
>>>>>>>>> >> >> >> RTEMS applications using waf.
>>>>>>>>> >> >> >> Best regards,
>>>>>>>>> >> >> >> Vijay
>>>>>>>>> >> >> >> > _______________________________________________
>>>>>>>>> >> >> >> > users mailing list
>>>>>>>>> >> >> >> > users at rtems.org
>>>>>>>>> >> >> >> > http://lists.rtems.org/mailman/listinfo/users
>>>>>>>> www.avast.com
>>>>>>>> <#m_-4707991134687881431_m_2587329209695249861_m_-6228330996423727151_m_-6868087392309282603_m_-8071420466793372504_m_971219196135651785_m_277508452244861825_m_-8462729502950921950_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>>>>>>>> users mailing list
>>>>>>>> users at rtems.org
>>>>>> users mailing list
>>>>>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210318/8104667b/attachment-0001.html>
