RTEMS 5 how to run "hello" example
Olga Syrbachova
syrba4eva28 at gmail.com
Thu Mar 18 16:30:25 UTC 2021
Thanks a lot, one step further :)
'configure' finished successfully (8.331s)
And again an error.
olga at olga-H270M-DS3H:~/development/rtems-examples$ ./waf
Waf: Entering directory
`/home/olga/development/rtems-examples/build/sparc-rtems5-erc32'
[ 1/14] Compiling hello/hello_world_c/test.c
[ 2/14] Compiling hello/posix_hello_world/test.c
[ 3/14] Compiling hello/both_hello/test.c
[ 4/14] Compiling hello/both_hello/test.c
[ 5/14] Compiling hello/both_hello/test.c
[ 6/14] Linking build/sparc-rtems5-erc32/hello/hello_world_c/hello.exe
[ 7/14] Linking
build/sparc-rtems5-erc32/hello/posix_hello_world/posix_hello.exe
[ 8/14] Compiling build/sparc-rtems5-erc32/hello/both_hello/test.c.1.o
error: sparc/erc32: RTEMS BSP not found
Waf: Leaving directory
Build failed
-> task in 'both_hello.texe' failed with exit status 10 (run with -v to
display more information)
$HOME/development/rtems/5/bin/sparc-rtems5-run \
> ./build/sparc-rtems5-erc32/hello
bash: /home/olga/development/rtems/5/bin/sparc-rtems5-run: No such file or
directory
And I also have another question: why is only "hello" example built? I've
been doing all the steps in the "rtems-examples" directory and thought that
every example will be built. Do I have to build and run an example in the
directory of the example?
On Thu, 18 Mar 2021 at 17:06, Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Mar 18, 2021 at 3:22 AM Olga Syrbachova <syrba4eva28 at gmail.com>
> wrote:
>> Thank you very much for your reply! I really appreciate that someone is
>> still trying to help me after so many questions from me :)
>> I've got an error again, so I will describe here all my steps in case I'm
>> doing something wrong and you can see where the problem could be.
>> 1.
>> olga at olga-H270M-DS3H:~/development$ git clone git://
>> git.rtems.org/rtems-examples.git
>> 2.
>> olga at olga-H270M-DS3H:~/development$ cd rtems-examples
>> 3.
>> olga at olga-H270M-DS3H:~/development/rtems-examples$ git submodule init
>> Submodule 'rtems_waf' (git://git.rtems.org/rtems_waf.git) registered for
>> path 'rtems_waf'
>> olga at olga-H270M-DS3H:~/development/rtems-examples$ git submodule update
>> Cloning into '/home/olga/development/rtems-examples/rtems_waf'...
>> Submodule path 'rtems_waf': checked out 'ad0890
>> 4.
>> olga at olga-H270M-DS3H:~/development/rtems-examples$ ./waf configure
>> --rtems=$HOME/development/rtems/5 --rtems-tools=$HOME/development/rtems/5
>> --rtems-bsps=sparc/erc32
> Here, you need to add --rtems-version or it defaults to 6:
> ./waf configure --rtems=$HOME/development/rtems/5
> --rtems-tools=$HOME/development/rtems/5 --rtems-bsps=sparc/erc32
> --rtems-version=5
>> Setting top to :
>> Setting out to :
>> RTEMS path is not valid, "/home/olga/development/rtems/5/share/rtems6"
>> not found.
>> (complete log in /home/olga/development/rtems-examples/build/config.log)
>> 8c452c6a9bbb3bf7bbbcc9fc03fe46cc7f'
>> As it was suggested by Gedare Bloom before: "We do encourage to try to
>> use waf to build the examples though, so let's focus on that direction." I
>> would really like to understand how to build the examples and later my own
>> apps using waf :)
>> Great. It should also work to build applications with Makefile or any
> other kind of build system, but the trick is how to extract the build
> configuration/variables that were used for RTEMS. We are (slowly) moving
> toward an interface to get at those variables, with the rtems_waf module
> providing the state-of-the-art and best developed method.
>> On Wed, 17 Mar 2021 at 22:49, Gedare Bloom <gedare at rtems.org> wrote:
>>> On Wed, Mar 17, 2021 at 2:23 PM Olga Syrbachova <syrba4eva28 at gmail.com>
>>> wrote:
>>>> Thank you very much for your reply! I'm still confused about all the
>>>> prefixes and PATHs. In the README.waf it is said to run
>>>> $ waf configure --rtems=$HOME/Development/rtems/5 \
>>>> --rtems-tools=$HOME/Development/rtems/5 \
>>>> where $HOME/Development/rtems/build/5 is the path to tools and
>>>> $HOME/Development/rtems/build/5 is the path to RTEMS Board Support
>>>> Packages.
>>>> I followed this tutorial
>>>> https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
>>>> installing RTEMS and building BSP. So in my case I built the tool suit in development/rtems/src/rsb/rtems
>>>> $ ../source-builder/sb-set-builder --prefix=$HOME/development/rtems/5 5/rtems-sparc
>>>> So the path to tools development/rtems/src/rsb/rtems, is it right? And
>>>> I'm not sure what is a path to RTEMS Board Support Packages.
>>> All paths referenced by README.waf are installed paths, i.e., the prefix
>>> that you used. It looks like that would be $HOME/development/rtems/5 for
>>> your case, for the tools (as passed to sb-set-builder) and for rtems (if
>>> you followed that blog post, it specifies the prefix to configure).
>>>> On Wed, 17 Mar 2021 at 18:48, Gedare Bloom <gedare at rtems.org> wrote:
>>>>> On Wed, Mar 17, 2021 at 10:22 AM Olga Syrbachova <
>>>>> syrba4eva28 at gmail.com> wrote:
>>>>>> What do you mean "regular README file"? There are 3 of them: README,
>>>>>> README.Makefile and README.waf. In README there is just a list of examples.
>>>>>> I tried to follow the README.Makefile instructions, and after running:
>>>>> Thanks I forgot we put those instructions into README.Makefile.
>>>>>> olga at olga-H270M-DS3H:~/development/rtems-examples/hello/hello_world_c$
>>>>>> RTEMS_MAKEFILE_PATH=${HOME}/development/rtems/5/sparc-rtems5/erc32 make
>>>>>> clean
>>>>>> and
>>>>>> there appeared an empty folder "o-optimize" in the examples's
>>>>>> directory. What's next?
>>>>>> Weird, I'll take a look. We do encourage to try to use waf to build
>>>> BTW: This worked for me. If you like, you can show what is the terminal
>>> output from the second line
>>> `RTEMS_MAKEFILE_PATH=${HOME}/development/rtems/5/sparc-rtems5/erc32 make`?
>>>> And what do you mean "use ./waf"? When I run ./waf in
>>>>>> "rtems-examples", it says
>>>>>> The project was not configured: run "waf configure" first!
>>>>>> olga at olga-H270M-DS3H:~/development/rtems-examples$ waf configure --rtems=$HOME/development/rtems/build/5 \--rtems-tools=$HOME/development/rtems/5 \--rtems-bsps=sparc/erc32
>>>>> ./waf configure --rtems=$HOME/development/rtems/build/5
>>>>>> Command 'waf' not found, did you mean: ...
>>>>>> command 'paf' from deb libpod-abstract-perl
>>>>>> command 'wdf' from deb wit
>>>>>> On Wed, 17 Mar 2021 at 16:51, Gedare Bloom <gedare at rtems.org> wrote:
>>>>>>> On Wed, Mar 17, 2021 at 9:11 AM Olga Syrbachova <
>>>>>>>> Thanks a lot! I have one more stupid question. How do I run
>>>>>>>> examples from git? I've cloned rtems-examples and tried to follow the
>>>>>>>> instructions from "README.waf", but it doesn't work. When I enter
>>>>>>>> $ waf configure --rtems=$HOME/development/rtems/bsps/5 \
>>>>>>>> I get this error:
>>>>>>>> Use ./waf
>>>>>>>> I probably do something wrong. Do I need to do the instructions from "README.waf" at all? Or do I need to proceed as in this tutorial https://docs.rtems.org/branches/master/user/start/app.html with every example's directory? I would really appreciate some step-by-step tutorial or instructions as I'm totally frustrated right now and don't understand what to do.
>>>>>>>> Btw there is a makefile in every example's directory. Can I use it instead of waf to compile the applications? If this is the case how do I do it?
>>>>>>>> You can do either way of building the examples, see the regular
>>>>>>> README file for directions on the Makefile approach.
>>>>>>>> Many thanks in advance for any help!!!
>>>>>>>> On Tue, 16 Mar 2021 at 20:07, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>>>> On Tue, Mar 16, 2021 at 1:40 PM Olga Syrbachova <
>>>>>>>>>> Thank you very much for your reply and for your concern!
>>>>>>>>>> Actually I'd like to create my own application and test some
>>>>>>>>>> mechanisms, provided by RTEMS. This is a part of my Bachelor Thesis. I'd
>>>>>>>>>> like, for example, to create two/three tasks and make them communicate
>>>>>>>>>> with each other via queues, schedule them by priority etc. I have some
>>>>>>>>>> experience with FreeRTOS. It is run via Visual Studio, which is quite
>>>>>>>>>> simple. And now with RTEMS I am a bit frustrated and don't know where to
>>>>>>>>>> start. That's why I followed the tutorial on the Website. "Hello World"
>>>>>>>>>> program worked just fine, so I decided to try some more complicated
>>>>>>>>>> applications before I start with my own, that's why I decided to build
>>>>>>>>>> "ticker" with waf. Unfortunately I didn't find any helpful (for me)
>>>>>>>>>> tutorial on how to create applications in RTEMS. I mean I can handle
>>>>>>>>>> writing the App's code, but I don't get it how to compile and run it. So I
>>>>>>>>>> was just going to do the same as in the tutorial, but with my own
>>>>>>>>>> application. Is it the right way to proceed or is there another way ?
>>>>>>>>> The tests in RTEMS are just that tests. They depend on things that
>>>>>>>>> shouldn't be installed or used by user applications.
>>>>>>>>> I would recommend cloning rtems-examples and going from one of
>>>>>>>>> those. There is a directory with variations on ticker and I suspect the
>>>>>>>>> base one is a better one to start from.
>>>>>>>>> If you want to write POSIX code, one of the POSIX examples there
>>>>>>>>> would serve you ok
>>>>>>>>> --joel
>>>>>>>>>> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> Virenfrei.
>>>>>>>>>> www.avast.com
>>>>>>>>>> <#m_7917335146911979221_m_-3453968078082772622_m_-4707991134687881431_m_2587329209695249861_m_-6228330996423727151_m_-6868087392309282603_m_-8071420466793372504_m_971219196135651785_m_277508452244861825_m_-8462729502950921950_m_6778778117170402098_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>>>>>>>>>> On Tue, 16 Mar 2021 at 16:29, Vijay Kumar Banerjee <
>>>>>>>>>> vijay at rtems.org> wrote:
>>>>>>>>>>> On Tue, Mar 16, 2021 at 4:07 AM Olga Syrbachova <
>>>>>>>>>>> > I've added
>>>>>>>>>>> > includes =
>>>>>>>>>>> '/home/olga/development/rtems/rtems-5/testsuites/support/include/tmacros.h',
>>>>>>>>>>> It takes the relative address to the directory where the header
>>>>>>>>>>> file
>>>>>>>>>>> is. For example, if you're building from the
>>>>>>>>>>> "/home/olga/development/rtems" directory the includes argument
>>>>>>>>>>> would
>>>>>>>>>>> be:
>>>>>>>>>>> `includes = './rtems-5/testsuites/support/include/'`
>>>>>>>>>>> BTW, your first email at the start of the thread says that you
>>>>>>>>>>> just
>>>>>>>>>>> want to run the samples, the samples get built as a part of the
>>>>>>>>>>> rtems
>>>>>>>>>>> and you'll be able to see the *.exe files in the build
>>>>>>>>>>> directory. Is
>>>>>>>>>>> there any reason that you're trying to build it in a separate
>>>>>>>>>>> directory with waf? Experimenting with the build system is a good
>>>>>>>>>>> reason though, just making sure that we're not pushing you in the
>>>>>>>>>>> wrong direction and your objective is indeed to try waf on your
>>>>>>>>>>> own
>>>>>>>>>>> and not just running RTEMS hello app.
>>>>>>>>>>> Best regards,
>>>>>>>>>>> Vijay
>>>>>>>>>>> > it still says "No such file or directory". I'm pretty sure the
>>>>>>>>>>> path is write, though there is now another path to "tmacros.h" (the first
>>>>>>>>>>> one below), it's a folder named "tmacros.h" and it's empty.
>>>>>>>>>>> > olga at olga-H270M-DS3H:~$ locate tmacros.h
>>>>>>>>>>> /home/olga/development/app/ticker/build/sparc-rtems5-erc32/$HOME/developement/rtems/rtems-5/testsuites/support/include/tmacros.h
>>>>>>>>>>> > On Mon, 15 Mar 2021 at 21:00, Vijay Kumar Banerjee <
>>>>>>>>>>> >> On Mon, Mar 15, 2021 at 1:53 PM Olga Syrbachova <
>>>>>>>>>>> >> > Sure! https://github.com/syrba4eva/RTEMS/blob/main/wscript
>>>>>>>>>>> >> Thanks. In this line:
>>>>>>>>>>> https://github.com/syrba4eva/RTEMS/blob/main/wscript#L33
>>>>>>>>>>> >> After cflags parameter, add "includes", for example:
>>>>>>>>>>> >> bld(features = 'c cprogram',
>>>>>>>>>>> >> target = 'ticker.exe',
>>>>>>>>>>> >> cflags = '-g -O2',
>>>>>>>>>>> >> includes='. .. ./original/path/to/tmacros.h',
>>>>>>>>>>> >> source = ['init.c', 'tasks.c'])
>>>>>>>>>>> >> you don't need to copy tmacros.h or any headers from rtems,
>>>>>>>>>>> just add
>>>>>>>>>>> >> the path to includes.
>>>>>>>>>>> >> Best regards,
>>>>>>>>>>> >> Vijay
>>>>>>>>>>> >> > On Mon, 15 Mar 2021 at 20:36, Vijay Kumar Banerjee <
>>>>>>>>>>> >> >> On Mon, Mar 15, 2021 at 1:30 PM Olga Syrbachova <
>>>>>>>>>>> >> >> > Unfortunately I'm still a bit confused and don't quite
>>>>>>>>>>> understand what to do. Where do I need to modify the "include" parameter?
>>>>>>>>>>> In the wscript file from the "hello" example there is no "include"
>>>>>>>>>>> parameter. I also tried to find a tutorial on how to write a wscript, but
>>>>>>>>>>> didn't find any (Could you suggest any please?). So I tried to copy the
>>>>>>>>>>> file "tmacros.h" from testsuites/support/include to app/ticker. Now after
>>>>>>>>>>> running ./waf I get an error, which tells me that "buffer_test_io.h" wasn't
>>>>>>>>>>> found. When I copied it to my app/ticker directory it didn't work and I
>>>>>>>>>>> still have the same error.
>>>>>>>>>>> >> >> Would it be possible for you to paste your wscript
>>>>>>>>>>> somewhere (like
>>>>>>>>>>> >> >> gist.github.com) and share it here so that we can have a
>>>>>>>>>>> look and help
>>>>>>>>>>> >> >> you with that?
>>>>>>>>>>> >> >> Best regards,
>>>>>>>>>>> >> >> Vijay
>>>>>>>>>>> `/home/olga/development/app/ticker/build/sparc-rtems5-erc32'
>>>>>>>>>>> >> >> > [1/3] Compiling tasks.c
>>>>>>>>>>> >> >> > [2/3] Compiling init.c
>>>>>>>>>>> >> >> > In file included from ../../system.h:17:0,
>>>>>>>>>>> >> >> > from ../../init.c:15:
>>>>>>>>>>> >> >> > ../../tmacros.h:32:10: fatal error: buffer_test_io.h: No
>>>>>>>>>>> >> >> > #include <buffer_test_io.h>
>>>>>>>>>>> >> >> > compilation terminated.
>>>>>>>>>>> >> >> > from ../../tasks.c:22:
>>>>>>>>>>> >> >> > Build failed
>>>>>>>>>>> >> >> > -> task in 'ticker.exe' failed with exit status 1 (run
>>>>>>>>>>> with -v to display more information)
>>>>>>>>>>> >> >> > On Mon, 15 Mar 2021 at 16:21, Vijay Kumar Banerjee <
>>>>>>>>>>> >> >> >> Hi Olga,
>>>>>>>>>>> >> >> >> On Mon, Mar 15, 2021 at 8:29 AM Olga Syrbachova <
>>>>>>>>>>> >> >> >> > I've built the RTEMS Kernel for erc32. Then I
>>>>>>>>>>> https://docs.rtems.org/branches/master/user/start/app.html to
>>>>>>>>>>> build a "Hello World" application and it works just fine. Then I've tried
>>>>>>>>>>> to create another application following the steps in the tutorial.
>>>>>>>>>>> >> >> >> > 1. In $HOME/development/app/ I created a directory
>>>>>>>>>>> "ticker".
>>>>>>>>>>> >> >> >> > 2. cd ticker
>>>>>>>>>>> >> >> >> > 3. curl https://waf.io/waf-2.0.19 > waf
>>>>>>>>>>> >> >> >> > chmod +x waf
>>>>>>>>>>> >> >> >> > git init
>>>>>>>>>>> >> >> >> > git submodule add git://
>>>>>>>>>>> git.rtems.org/rtems_waf.git rtems_waf
>>>>>>>>>>> >> >> >> > 4. I've copied the files "init.c", "tasks.c",
>>>>>>>>>>> "system.h" from testsuites/samples
>>>>>>>>>>> >> >> >> > 5. In the "wscript" I've changed the lines 32 and 34
>>>>>>>>>>> to target = 'ticker.exe', source = ['init.c', 'tasks.c']
>>>>>>>>>>> >> >> >> > 6. ./waf configure --rtems=$HOME/development/rtems/5
>>>>>>>>>>> --rtems-bsp=sparc/erc32
>>>>>>>>>>> >> >> >> > 7. and running ./waf next, I get an error. It looks
>>>>>>>>>>> like the file "tmacros.h", which is included in "system.h", cannot be found.
>>>>>>>>>>> >> >> >> You have changed the "target" and "source" parameters
>>>>>>>>>>> in your wscript.
>>>>>>>>>>> >> >> >> You'd also need to modify the "include" parameter and
>>>>>>>>>>> add relative
>>>>>>>>>>> >> >> >> path to tmacros.h. For multiple headers, you'll have to
>>>>>>>>>>> add the paths
>>>>>>>>>>> >> >> >> as a string with space-separated values or a list like
>>>>>>>>>>> this:
>>>>>>>>>>> >> >> >> `includes='./ ../ ./path/to/include/'`
>>>>>>>>>>> >> >> >> > What am I doing wrong? Is the way to run other
>>>>>>>>>>> examples exactly the same as to run a "Hello World" example?
>>>>>>>>>>> >> >> >> The other examples will also follow a similar wscript
>>>>>>>>>>> structure but
>>>>>>>>>>> >> >> >> hello world is the simple one with fewer includes so
>>>>>>>>>>> it's a good place
>>>>>>>>>>> >> >> >> to start if you're trying to learn how to make a
>>>>>>>>>>> separate project with
>>>>>>>>>>> >> >> >> RTEMS applications using waf.
>>>>>>>>>>> >> >> >> Best regards,
>>>>>>>>>>> >> >> >> Vijay
>>>>>>>>>>> >> >> >> > _______________________________________________
>>>>>>>>>>> >> >> >> > users mailing list
>>>>>>>>>>> >> >> >> > users at rtems.org
>>>>>>>>>>> >> >> >> > http://lists.rtems.org/mailman/listinfo/users
>>>>>>>>>> www.avast.com
>>>>>>>>>> <#m_7917335146911979221_m_-3453968078082772622_m_-4707991134687881431_m_2587329209695249861_m_-6228330996423727151_m_-6868087392309282603_m_-8071420466793372504_m_971219196135651785_m_277508452244861825_m_-8462729502950921950_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>>>>>>>>>> users mailing list
>>>>>>>>>> users at rtems.org
>>>>>>>> users mailing list
>>>>>>>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210318/64527adb/attachment-0001.html>
