Installing rtems on 32 bit windows host machine
Alireza Banejad
alibanejad1376 at gmail.com
Sat Mar 20 19:57:46 UTC 2021
i managed to fix the issue and install rtems with msys2. I didnt continue
it any further with cygwin.
i did the following:
1) I changed the machsize line under 'i686' from '32' to '64' in
source-builder/sb/windows.py since the toolchain downloaded for msys2
is as mingw-w64-i686-toolchain
not mingw-w32-i686-toolchain
def load():
# Default to the native Windows Python.
uname = 'win32'
if 'PROCESSOR_ARCHITECTURE' in os.environ:
if os.environ['PROCESSOR_ARCHITECTURE'] == 'AMD64':
hosttype = 'x86_64'
machsize = '64'
else:
hosttype = 'i686'
machsize = '64' #'32'
else:
hosttype = 'x86_64'
machsize = '32'
2) i tried installing the rtems 6 arm tools and gave me this:
C:/msys32/mingw32/bin/../lib/gcc/i686-w64-mingw32/10.2.0/../../../../i686-w64-mingw32/bin/ld.exe:
../gnulib/import/libgnu.a(getrandom.o): in function `getrandom':
C:\opt\rtems\rsb\rtems\build\arg6iwm1\build\gnulib\import/../../../sourceware-mirror-binutils-gdb-6427605/gnulib/import/getrandom.c:129:
undefined reference to `BCryptGenRandom at 16'
3) finally i just installed the rtems 5 arm tools and it built successfully
now that i have rtems tools installed I want to use eclipse and be able to
build and install bsps on eclipse, i followed the eclipse manual.
but when i reconfigure the project it returns:
sh -c "/C/opt/rtems/rtemsnew/configure --host=i686-w64-mingw32
--build=i686-w64-mingw32 --target=arm-rtems5
--prefix=C:\\\\\\\\opt\\\\\\\\rtems\\\\\\\\5 --enable-rtemsbsp=xen_virtual
--disable-tests"
checking for gmake... no
checking for make... make
checking for RTEMS Version... 5.0.0
checking build system type... i686-w64-mingw32
checking host system type... i686-w64-mingw32
checking target system type... arm-unknown-rtems5
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
File not found - *.cfg
configure: error: BSP 'xen_virtual' not found, run 'rtems-bsps' (in the top
of the source tree) for a valid BSP list
Configuration failed with error
even though i already installed the bsp with msys2 without any issues, i
dont know why running configure from eclipse tells me the bsp is not found.
i also tried this for other bsps and it gave me the same error
On Tue, Mar 23, 2021 at 5:57 AM Chris Johns <chrisj at rtems.org> wrote:
> On 12/3/21 9:47 pm, Alireza Banejad wrote:
> > any thoughts?
> What are the names of the compilers that have been installed?
> Chris
> > On Fri, Mar 12, 2021 at 4:00 AM Alireza Banejad <
> > <mailto:alibanejad1376 at gmail.com>> wrote:
> > thanks again,
> > this time I installed Cygwin and run the sb-check and returned that
> the
> > environment is ok, but when installing rtems with the source
> builder it
> > results in an error, checking out the log file tells me the
> following:
> > checking whether to use python... /usr/bin/python2
> > checking for python... no
> > configure: error: no usable python found at /usr/bin/python2
> > make[1]: *** [Makefile:9705: configure-gdb] Error 1
> > make[1]: Leaving directory
> '/cygdrive/c/opt/rtems/rsb/rtems/build/arm-rtems6-gdb-6427605-i686-pc-cygwin-1/build'
> > make: *** [Makefile:857: all] Error 2
> > shell cmd failed: sh -ex
> /cygdrive/c/opt/rtems/rsb/rtems/build/arm-rtems6-gdb-6427605-i686-pc-cygwin-1/do-build
> > error: building arm-rtems6-gdb-6427605-i686-pc-cygwin-1
> > i don't know why this happens even though python exists in this
> path?. I
> > also have the python-devel and python3-devel packages installed
> > On Fri, Mar 12, 2021 at 2:22 AM Joel Sherrill <joel at rtems.org
> > <mailto:joel at rtems.org>> wrote:
> > Re-adding devel@ to keep things recorded.
> > On Thu, Mar 11, 2021 at 1:23 PM Alireza Banejad
> > <alibanejad1376 at gmail.com <mailto:alibanejad1376 at gmail.com>>
> wrote:
> > Hello Joel,
> > thank you for responding,
> > so basically I installed the msys2 i686 and downloaded the
> packages
> > and finally downloaded themingw-w64-i686-toolchain, after
> exporting
> > the proper path of the compiler I ran the
> > gcc -dumpmachine command, it returned i686-w64-mingw32 yet
> the
> > sb-check of rsb wants a i686-w32-mingw32-gcc compiler.
> > Chris Johns will hopefully jump in shortly.
> > On Thu, Mar 11, 2021 at 10:42 PM Joel Sherrill <
> joel at rtems.org
> > On Thu, Mar 11, 2021 at 1:05 PM Alireza Banejad
> > Hello everyone,
> > I was wondering whether I could install RTEMS on a
> 32-bit
> > Windows 7 host machine using either msys2 or Cygwin.
> > I already tried installing it on msys2 i686 but when
> running
> > sb-check it returns:
> > |error: exe: not found: (__cc) i686-w32-mingw32-gcc
> error:
> > exe: not found: (__cxx) |i686-w32-mingw32-g++
> > Environment is not correctly set up.
> > It seems there is no such compiler as
> i686-w32-mingw32-gcc to add in the first place.
> > Assuming you have installed the gcc package, what is the
> > compiler called?
> > I don't think any of the core developers have seen
> Windows 7
> > especially 32-bit in a while.
> > The file that sets the expectations based on host is
> > source-builder/sb/windows.py. It may require some
> tinkering to
> > match a 32-bit environment.
> > We'd love to have a patch to that file (don't break
> 64-bit) and,
> > if needed, documentation.
> > --joel
> > users mailing list
> > users at rtems.org <mailto:users at rtems.org>
> > http://lists.rtems.org/mailman/listinfo/users
> > <http://lists.rtems.org/mailman/listinfo/users>
> > users mailing list
> > users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210320/903060d9/attachment-0001.html>
