回复: can't find "pthread_barrier_t"
382535941 382535941 at qq.com
Sat Mar 27 14:30:01 UTC 2021
I figure out what happened. Thank you very much!
------------------ 原始邮件 ------------------
发件人: "joel"<joel at rtems.org>;
发送时间: 2021年3月27日(星期六) 晚上10:26
收件人: "382535941"<382535941 at qq.com>;
抄送: "users"<users at rtems.org>;
主题: Re: can't find "pthread_barrier_t"
On Sat, Mar 27, 2021, 4:39 AM 382535941 <382535941 at qq.com> wrote:
    I would like to compile rtems on my C6678 board. I have changed some code and when I wanted to compile it, I find it doesn't define pthread_barrier_t in \cpukit\include\rtems\posix\pthread.h. Is there other place to put it or I should install a pthread library?
That is an internal support file for the implementation of pthreads. The actual header file you want to include was installed with the RTEMS tool chain.
Did you build an items tool chain and is that what you are using?
--joel
 users mailing list
 users at rtems.org
 http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20210327/9e6239d4/attachment.html>
