Issue Compiling the Tool Suite on Windows 10
Luke Halberstadt lhalbers at mathworks.com
Thu Sep 23 16:37:53 UTC 2021
Dear Sir/Madam,
I am working on compiling the RTEMS toolchain on a Windows machine following the instructions provided here:
https://docs.rtems.org/branches/master/user/hosts/windows.html#cygwin
Both Cygwin and MSYS2 are installed along with most of the recommended packages, however, I could not find the gcc4* or python packages. Instead, I installed similar gcc* and python2 packages.
When I compile using the following command,
../source-builder/sb-set-builder --prefix=/cygdrive/c/opt/rtmes/5.1 5/rtems-sparc --jobs=none
The build makes it up to building gdb and then fails with a python error.
building: sparc-rtems5-gdb-9.1-x86_64-pc-cygwin-1
error: building sparc-rtems5-gdb-9.1-x86_64-pc-cygwin-1
I have attached the rsb-report and log files The key issue seems to be in the following lines of the report:
checking whether to use python... /usr/bin/python2
checking for python... no
configure: error: no usable python found at /usr/bin/python2
make[1]: *** [Makefile:8869: configure-gdb] Error 1
make[1]: Leaving directory '/cygdrive/c/opt/rtems/5.1/rtems/build/sparc-rtems5-gdb-9.1-x86_64-pc-cygwin-1/build'
make: *** [Makefile:855: all] Error 2
shell cmd failed: sh -ex  /cygdrive/c/opt/rtems/5.1/rtems/build/sparc-rtems5-gdb-9.1-x86_64-pc-cygwin-1/do-build
By default, Python is installed at /bin, not /usr/bin, so I tried copying the python files from /bin to /usr/bin, but that did not resolve the issue. I attached a screenshot showing the contents of /usr/bin when this failure occurred.
Any ideas how to get around this problem so that gcc recognizes the python installation? Thank you for your input.
Sincerely,
Luke Halberstadt
Senior Associate Training Engineer
Natick, MA USA
(508) 647-0196
lhalbers at mathworks.com<mailto:lhalbers at mathworks.com>
