[EXTERNAL] rtems_semaphore routines on SMP systems
Johnson, Andrew N.
anj at anl.gov
Tue Sep 28 15:11:56 UTC 2021
On Sep 28, 2021, at 5:02 AM, Sebastian Huber <sebastian.huber at embedded-brains.de<mailto:sebastian.huber at embedded-brains.de>> wrote:
On 28/09/2021 11:46, Heinz Junkes wrote:
Unfortunately we found out that EPICS uses the mutex handling also in the interrupt context
and this leads to core-dumps in RTEMS :-(
Yes, using any kind of mutexes in interrupt context is undefined behaviour. Mutexes may only be used from threads.
Heinz' reply about our osdMutex may be irrelevant. I suspect the issue is what if any changes we’d need to make to our implementation of the epicsEvent found here
https://github.com/epics-base/epics-base/blob/7.0/modules/libcom/src/osi/os/RTEMS-score/osdEvent.c
for a modified version of this to work on an RTEMS-5 or later SMP system. It creates a semaphore as follows:
sc = rtems_semaphore_create (rtems_build_name ('B', c3, c2, c1),
initialState,
RTEMS_FIFO | RTEMS_SIMPLE_BINARY_SEMAPHORE |
RTEMS_NO_INHERIT_PRIORITY | RTEMS_NO_PRIORITY_CEILING | RTEMS_LOCAL,
0,
&sid);
We will want to use the same code on both SMP and UP systems and from earlier posts it sounds like they would need different flags. Does RTEMS define a macro that tells us which we’re compiling for, or will we have to add our own?
Which RTEMS semaphore classes do you use in EPICS and in particular which classes do you use in interrupt context?
An epicsEvent must be able to be triggered from interrupt context, and in the above implementation epicsEventTrigger() calls rtems_semaphore_release(). That’s the only routine we need AFAIK.
- Andrew
Complexity comes for free, simplicity you have to work for.
