[EXTERNAL] rtems_semaphore routines on SMP systems
Tue Sep 28 16:42:41 UTC 2021
On 28/09/2021 17:11, Johnson, Andrew N. wrote:
>> sc = rtems_semaphore_create (rtems_build_name ('B', c3, c2, c1),
>>     initialState,
>>     RTEMS_FIFO | RTEMS_SIMPLE_BINARY_SEMAPHORE |
>>         RTEMS_NO_INHERIT_PRIORITY | RTEMS_NO_PRIORITY_CEILING |
>> RTEMS_LOCAL,
>> 0,
>>     &sid);
> We will want to use the same code on both SMP and UP systems and from
> earlier posts it sounds like they would need different flags. Does RTEMS
> define a macro that tells us which we’re compiling for, or will we have
> to add our own?
You don't need different flags. The earlier post mentioned a new locking
protocol (MrsP) which is specifically added for SMP systems. This is not
relevant for this event stuff here.
You can use the RTEMS_SMP define to figure out if RTEMS was built with
SMP support enabled:
https://docs.rtems.org/branches/master/c-user/symmetric_multiprocessing_services.html#application-configuration
>> Which RTEMS semaphore classes do you use in EPICS and in particular
>> which classes do you use in interrupt context?
> An epicsEvent must be able to be triggered from interrupt context, and
> in the above implementation epicsEventTrigger() calls
> rtems_semaphore_release(). That’s the only routine we need AFAIK.
The RTEMS_SIMPLE_BINARY_SEMAPHORE semaphores can be used from within
interrupt context. An alternative are:
https://docs.rtems.org/branches/master/c-user/self_contained_objects.html#binary-semaphores
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
