wkspace failed allocations with heap protection enabled
Joel Sherrill
joel at rtems.org
Wed Apr 13 16:51:08 UTC 2022
On Wed, Apr 13, 2022 at 10:51 AM Matthew J Fletcher <amimjf at gmail.com>
wrote:
> Hi Joel,
> Works fine without debug, its the deferred free doing _Heap_Allocate with
> the negative size thats causing it.
Glad that workaround gets you by it. Please do file a ticket though. :)
--joel
> On Wed, 13 Apr 2022 at 16:09, Joel Sherrill <joel at rtems.org> wrote:
>> This appears to be a bad side-effect of the way the deferred free is
>> implemented
>> when the memory protection/fence is enabled. This is turned on by
>> enabling
>> rtems debug.
>> I'd recommend filing a ticket and assigning it to Sebastian for a real
>> fix.
>> In the meantime, see if building RTEMS without debug enabled helps.
>> --joel
>> On Wed, Apr 13, 2022 at 4:30 AM Matthew J Fletcher <amimjf at gmail.com>
>> wrote:
>>> Hi,
>>> Investigating the "Total number of failed allocations:" from the
>>> wkspace cmd i see that;
>>> /* Statistics */
>>> ++stats->failed_allocs;
>>> Are incremented when _Heap_Allocate_aligned_with_boundary fails, however
>>> it
>>> seems this will routinely fail due to;
>>> _Heap_Protection_free_all_delayed_blocks seemingly on purpose creating an
>>> impossibly large allocation.
>>> uintptr_t large = 0
>>> - (uintptr_t) HEAP_BLOCK_HEADER_SIZE
>>> - (uintptr_t) HEAP_ALLOC_BONUS
>>> - (uintptr_t) 1;
>>> void *p = _Heap_Allocate( heap, large );
>>> This makes it difficult to place a breakpoint on failed_allocs to
>>> investigate true low memory situations with heap protection enabled.
>>> regards
>>> Matthew J Fletcher
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
> regards
> Matthew J Fletcher
