Barrier Manager cross-node behaviour
Jerzy J yuralogplus at gmail.com
Fri Jan 28 13:15:24 UTC 2022
Hi Joel,
Thank you for your help and clarification, this is exactly what i needed!
In terms of submitting this to the community, the situation is exactly as
mentioned by Andrew.
>If that statement and any others like it were deleted,
>would this issue go away?
I think if it's consistent and either doesn't mention nodes at all or does
so on all of the directives it would definitely be more clear!
>Please point out all the places where the barrier documentation
>uses language from a distributed multiprocessing and shouldn't.
As far as I'm aware, I've only seen nodes mentioned in Classic API Guide,
in Barrier Manager Directives section:
https://docs.rtems.org/branches/master/c-user/barrier/directives.html#rtems-barrier-create
https://docs.rtems.org/branches/master/c-user/barrier/directives.html#rtems-barrier-ident
https://docs.rtems.org/branches/master/c-user/barrier/directives.html#rtems-barrier-delete
Hope that helps and all the best,
Jerzy
pt., 28 sty 2022 o 12:00 Andrew.Butterfield at scss.tcd.ie <
Andrew.Butterfield at scss.tcd.ie> napisał(a):
> Hi Joel,
>   Jerzy is doing a Dissertation on this topic, and we have every plan to
> feed this back into the community. The is an academic spin-off from the ESA
> sponsored activity that ran for the last two years or so.
> I know that the precise way we integrate this stuff back into the
> community needs to be figured out, and discussion is underway about aspects
> of this on the devel mailing list.
> Sebastian and I hope to come to you all with a proposal regarding the
> Formal Methods part - I'll let him lead that as he has a better feel for
> what would fit best with community guidelines.
> Regards,
>   Andrew
> Andrew Butterfield     Tel: +353-1-896-2517     Fax: +353-1-677-2204
> Lero at TCD, Head of Software Foundations & Verification Research Group
> School of Computer Science and Statistics,
> Room G.39, O'Reilly Institute, Trinity College, University of Dublin
>                          http://www.scss.tcd.ie/Andrew.Butterfield/
> -----Original Message-----
> From: users <users-bounces at rtems.org> on behalf of Joel Sherrill <
> joel at rtems.org>
> Reply to: "joel at rtems.org" <joel at rtems.org>
> Date: Thursday 27 January 2022 at 23:39
> To: Jerzy J <yuralogplus at gmail.com>
> Cc: "rtems-users at rtems.org" <users at rtems.org>
> Subject: Re: Barrier Manager cross-node behaviour
>     On Thu, Jan 27, 2022 at 5:04 PM Jerzy J <yuralogplus at gmail.com> wrote:
>     > Hi,
>     > I'm using RTEMS 6 and I'm trying to model the Barrier Manager
> behaviour
>     > using Promela.
>     Cool! Have you modeled anything else? Is this something which could be
>     submitted to the community and used openly?
>     Just thinking anything that grows formal verification for RTEMS
> hopefully
>     helps if there is the potential for more input. Not that I am likely
> the one to
>     build the formal model.
>     > However, there's one unclear thing to me which I couldn't find an
> exact
>     > explanation of in the documentation.
>     > While the `rtems_barrier_ident` directive can only search on the
> local
>     > node, if a task already had an id of the barrier from a different
> node,
>     > would it be able to call the `rtems_barrier_wait` directive on that
>     > barrier, or would it get INVALID_ID return code?
>     > In other words, can a task from one node, call directives on a
> barrier from
>     > another node if it had an id of the barrier?
>     The concept of node only applies when RTEMS is built for
>     distributed multiprocessing. This is completely different from
>     the SMP support.
>     For distributed multiprocessing, the system model is multiple
>     CPUs cards on a shared bus like VMEbus with an area
>     of shared memory. In a distributed multiprocessing configuration,
>     each node is a complete RTEMS executable with an assigned
>     node number in the system.
>     For SMP, the cores are tightly integrated, share a memory
>     image, etc. This is considered one "node".
>     There is no mixing of models.
>     With the distributed multiprocessing, a subset of Classic API
>     services allow an object instance to be created with global visibility.
>     If global, then the ident service can be used to look up the id
>     for a name. For example, a task can be global. If created on
>     node 1, a task on node 2 can change its priority.
>     I doubt you really care about the distributed multiprocessing
>     configuration but even if you did, barriers are local only and
>     can't be accessed by other nodes in a distributed
>     processing configuration.
>     > I would also assume that behaviour would be consistent for `delete`
> and
>     > `release` directives as well? Although it is mentioned in the
> `delete`
>     > directive constraints that only local tasks can delete a barrier, in
> other
>     > directives it is not listed as a constraint.
>     That is probably just an artifact of copying the starting point for
>     the documentation from another API class that did support
>     being global.
>     Thanks.
>     --joel
>     > Thanks you in advance and all the best,
>     > Jerzy
>     > _______________________________________________
>     > users mailing list
>     > users at rtems.org
>     > http://lists.rtems.org/mailman/listinfo/users
>     users mailing list
>     users at rtems.org
