How can I add LDFLAGS for bsp build?
Sebastian Huber
Mon Jul 25 14:52:31 UTC 2022
On 25/07/2022 16:47, Y. HB wrote:
> ['/home/hongbo/Developer/Embedded/rtems/5/bin/arm-rtems5-gcc',
> '-qrtems', '-B/home/hongbo/Developer/Embedded/rtems/5/arm-rtems5/lib/',
> '-B/home/hongbo/Developer/Embedded/rtems/5/arm-rtems5/tms570lc4357_launchxl/lib/',
> '--specs', 'bsp_specs', '-march=armv7-r', '-mthumb', '-mbig-endian',
> '-mfpu=vfpv3-d16', '-mfloat-abi=hard', '-ffunction-sections',
> '-fdata-sections', '-MMD', 'test.c.1.o',
> '-o/home/hongbo/Developer/Embedded/rtems/app/hello/build/.conf_check_261484d99ea5da27480d47dee9a30c04/testbuild/testprog',
> '-Wl,-Bstatic', '-Wl,-Bdynamic', '-Bstatic -lm']
> err:
> /home/hongbo/Developer/Embedded/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld:
> /home/hongbo/Developer/Embedded/rtems/5/arm-rtems5/tms570lc4357_launchxl/lib/librtemsbsp.a(HL_sci.o):
> in function `sciSetBaudrate':
> /home/hongbo/Developer/Embedded/rtems/build/tms570lc4357/arm-rtems5/c/tms570lc4357_launchxl/lib/libbsp/arm/tms570/../../../../../../../../../rtems-master/c/src/lib/libbsp/arm/tms570/../../../../../../bsps/arm/tms570/start/tms570lc4357/source/HL_sci.c:284:
> undefined reference to `floor'
> collect2: error: ld returned 1 exit status
This is a problem with the search order of the libraries. The -lrtemsbsp
is implicitly given by the --specs bsp_specs. You can try this:
-lrtemsbsp -lm
Alternatively, avoid the use of floating point operations and the
floor() function.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
