Hello + Mixed-criticality + Questions + Problems
Aymeric PLOTON
aymeric.ploton at telecom-paris.fr
Thu Jun 30 14:00:52 UTC 2022
Hello,
* Context : My name is Aymeric and I'm new in the RTEMS operating
system, and in general in the open source contribution. But I will do my
best.
* Subject : I'm currently doing an academic internship at Télécom-Paris,
on the subject : Distributed platform with mixed criticality for swarm
of heterogeneous robots (UAV, UGV, USV).
We are interested in the implementation of the mixed-criticality (MCS)
in RTEMS, and run micro-ROS applications.
For this I would have some questions and issues.
* Questions :
1) During the state of the art we realized that there was an
implementation of a mixed criticality scheduler on RTEMS done by another
student earlier for a project.
Are you interested in it?
If so, how can I submit it properly to credit the other student ? (I am
currently proofreading to correct the coding style, other minor
corrections, and port it to a newer version of RTEMS hence my second
question).
2) Do you know when RTEMS 6 will be released, and when RTEMS 5.1 will be
stop, so we know which version to move our implementation to ?
3) We realized that the RTEMS 5/5.1 doc is not available on the website
[https://docs.rtems.org/all.html], is this normal? Is it deprecated ?
4) We saw that there was a port of micro-ROS to RTEMS 5 by Patrick
Roncagliolo (github/ROS: @roncapat). I guess I'd better turn to ROS for
more information, because it's not one of your projects, but if you have
any I'm a taker.
* Problems :
Ubuntu 20.04 - Linux-5.18.2-051802-generic-x86_64-with-glibc2.29
RTEMS 5.1 git : 8d54187a19f6e6d2849066f80254730302482934
RSB 5 git : 7f6cfad445d02393507b392a249fa1e64dadc041
RTEMS 6 git : 00f39770cae43db5b2f96cf9b6b1f8573cc694b7
RSB 6 git : 6c2351ce6158617afbdc3b2d74facb8dec3f0e62
1) Minor : By training me on the site
[https://ftp.rtems.org/pub/rtems/releases/5/5.1/docs/html/user/start/rsb-packages.html]
in the section : **2.9.3. Package Build**, I can't compile the example
it seems that the file 'freetype-2.4.10' is missing, looking on the site
[https://bigsearcher.com/mirrors/nongnu/freetype/] the oldest version
available seems to be 'freetype-2.7.1.tar.X'.
2.1) I tried to find the origin of the problem by myself and in the
mailing list but I didn't find the solution, sorry to bother you with
this but I can't compile for the **2.5.1. RSB BSP Build**
[https://docs.rtems.org/branches/master/user/start/bsp-build.html#rsb-bsp-build],
here is the terminal output and attached is the log
'rsb-report-sparc-rtems6-kernel-erc32-1.txt' :
```bash
~/dev/quick-start/src/rsb/6/rtems $ ../source-builder/sb-set-builder
--prefix=$HOME/dev/quick-start/rtems/6 --target=sparc-rtems6
--with-rtems-bsp=erc32 --with-rtems-tests=yes 6/rtems-kernel
RTEMS Source Builder - Set Builder, 6 (6c2351ce6158)
Build Set: 6/rtems-kernel
config: tools/rtems-kernel-6.cfg
package: sparc-rtems6-kernel-erc32-1
warning: rtems-kernel-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3.tar.bz2:
no hash found
building: sparc-rtems6-kernel-erc32-1
error: building sparc-rtems6-kernel-erc32-1
Build FAILED
See error report: rsb-report-sparc-rtems6-kernel-erc32-1.txt
Build Set: Time 0:00:06.058917
Build FAILED
2.2) But I can do it with the manual build section **2.5.2. Manual BSP
Build**
[https://docs.rtems.org/branches/master/user/start/bsp-build.html#manual-bsp-build],
however during the test phase I get 3 fails:
```bash
~/dev/quick-start/src/rtems/6 $ rtems-test --rtems-bsp=erc32-sis
build/sparc/erc32
RTEMS Testing - Tester, 6.0.not_released
Command Line: /home/play/dev/quick-start/rtems/6/bin/rtems-test
--rtems-bsp=erc32-sis build/sparc/erc32
Host: Linux frea 5.18.2-051802-generic #202206060740 SMP
PREEMPT_DYNAMIC Mon Jun 6 07:46:45 UTC 2022 x86_64
Python: 2.7.18 (default, Mar 8 2021, 13:02:45) [GCC 9.3.0]
Host: Linux-5.18.2-051802-generic-x86_64-with-Ubuntu-20.04-focal (Linux
frea 5.18.2-051802-generic #202206060740 SMP PREEMPT_DYNAMIC Mon Jun 6
07:46:45 UTC 2022 x86_64 x86_64)
[ 2/593] p:0 f:0 u:0 e:0 I:0 B:0 t:0 L:0 i:0 W:0 |
sparc/erc32: linpack.exe
[ 83/593] p:68 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 |
sparc/erc32: crypt01.exe
Result: failed
Time: 0:01:42.497482 crypt01.exe
=> exe: /home/play/dev/quick-start/rtems/6/bin/sparc-rtems6-sis
-nouartrx -r -tlim 600 s build/sparc/erc32/testsuites/libtests/crypt01.exe
] SIS - SPARC/RISCV instruction simulator 2.29, copyright Jiri Gaisler
2020
] Bug-reports to jiri at gaisler.se
] ERC32 emulation enabled
] Loaded build/sparc/erc32/testsuites/libtests/crypt01.exe, entry
0x02000000
=> test start: CRYPT 1
] *** BEGIN OF TEST CRYPT 1 ***
] *** TEST VERSION: 6.0.0.00f39770cae43db5b2f96cf9b6b1f8573cc694b7
] *** TEST STATE: EXPECTED_PASS
] *** TEST BUILD:
] *** TEST TOOLS: 12.1.1 20220622 (RTEMS 6, RSB
6c2351ce6158617afbdc3b2d74facb8dec3f0e62, Newlib e7ffbdb)
] test crypt_md5_r()
] test crypt_sha256_r()
] input: Hello world!
] salt: $5$saltstring
] expected: $5$saltstring$5B8vYYiY.CVt1RlTTf8KbXBH3hsxY/GNooZaBBGWEc5
] actual: $5$saltstring$5B8vYYiY.CVt1RlTTf8KbXBH3hsxY/GNooZaBBGWEc5
] salt: $5$rounds=10000$saltstringsaltstring
] expected:
$5$rounds=10000$saltstringsaltst$3xv.VbSHBb41AL9AvLeujZkZRBAwqFMz2.opqey6IcA
] actual:
] input: This is just a test
] salt: $5$rounds=5000$toolongsaltstring
] expected:
$5$rounds=5000$toolongsaltstrin$Un/5jzAHMgOGZ5.mWJpuVolil07guHPvOW8mGRcvxa5
] actual:
] input: a very much longer text to encrypt. This one even stretches
over morethan one line.
] salt: $5$rounds=1400$anotherlongsaltstring
] expected:
$5$rounds=1400$anotherlongsalts$Rx.j8H.h8HjEDGomFU8bDkXm3XIUnzyxf12oP84Bnq1
] actual:
] input: we have a short salt string but not a short password
] salt: $5$rounds=77777$short
] expected:
$5$rounds=77777$short$JiO1O3ZpDAxGJeaDIuqCoEFysAe1mZNJRs3pw0KQRd/
] actual:
] input: a short string
] salt: $5$rounds=123456$asaltof16chars..
] expected:
$5$rounds=123456$asaltof16chars..$gP3VQ/6X7UUEW3HkBn2w1/Ptq2jxPyzV/cZKmF/wJvD
] actual:
] input: the minimum number is still observed
] salt: $5$rounds=10$roundstoolow
] expected:
$5$rounds=1000$roundstoolow$yfvwcWrQ8l/K0DAWyuPMDNHpIVlTQebY9l/gL972bIC
] actual:
] test crypt_sha512_r()
] salt: $6$saltstring
] expected:
$6$saltstring$svn8UoSVapNtMuq1ukKS4tPQd8iKwSMHWjl/O817G3uBnIFNjnQJuesI68u4OTLiBFdcbYEdFCoEOfaS35inz1
] actual:
] salt: $6$rounds=10000$saltstringsaltstring
] expected:
$6$rounds=10000$saltstringsaltst$OW1/O6BYHV6BcXZu8QVeXbDWra3Oeqh0sbHbbMCVNSnCM/UrjmM0Dp8vOuZeHBy/YTBmSK6H9qs/y3RnOaw5v.
] actual:
] salt: $6$rounds=5000$toolongsaltstring
] expected:
$6$rounds=5000$toolongsaltstrin$lQ8jolhgVRVhY4b5pZKaysCLi0QBxGoNeKQzQ3glMhwllF7oGDZxUhx1yxdYcz/e1JSbq3y6JMxxl8audkUEm0
] actual:
] salt: $6$rounds=1400$anotherlongsaltstring
] expected:
$6$rounds=1400$anotherlongsalts$POfYwTEok97VWcjxIiSOjiykti.o/pQs.wPvMxQ6Fm7I6IoYN3CmLs66x9t0oSwbtEW7o7UmJEiDwGqd8p4ur1
] actual:
] salt: $6$rounds=77777$short
] expected:
$6$rounds=77777$short$WuQyW2YR.hBNpjjRhpYD/ifIw05xdfeEyQoMxIXbkvr0gge1a1x3yRULJ5CCaUeOxFmtlcGZelFl5CxtgfiAc0
] actual:
] Time-out limit reached
Interrupt!
] Stopped at time 8400000001 (600000.000 ms)
[310/593] p:286 f:0 u:5 e:2 I:0 B:3 t:0 L:0 i:0 W:0 |
sparc/erc32: minimum.exe
[461/593] p:436 f:1 u:6 e:2 I:0 B:3 t:0 L:0 i:0 W:0 |
sparc/erc32: spintrcritical20.exe
Result: failed
Time: 0:00:04.260444 spintrcritical20.exe
build/sparc/erc32/testsuites/sptests/spintrcritical20.exe
2020
] Loaded build/sparc/erc32/testsuites/sptests/spintrcritical20.exe,
entry 0x02000000
=> test start: SPINTRCRITICAL 20
] *** BEGIN OF TEST SPINTRCRITICAL 20 ***
] *** TEST BUILD:
] A:SPINTRCRITICAL 20
] S:Platform:RTEMS
] S:Compiler:12.1.1 20220622 (RTEMS 6, RSB
] S:Version:6.0.0.00f39770cae43db5b2f96cf9b6b1f8573cc694b7
] S:BSP:erc32
] S:BuildLabel:DEFAULT
] S:TargetHash:SHA256:aQM5D84izENqUHf5JXZtqffaL5bD4qBjf9HOSNfAMBY=
] S:RTEMS_DEBUG:0
] S:RTEMS_MULTIPROCESSING:0
] S:RTEMS_POSIX_API:0
] S:RTEMS_PROFILING:0
] S:RTEMS_SMP:0
] B:SemaphoreObtainTimeoutInterrupt
] P:0:0:UI1:init.c:172
] P:1:0:UI1:init.c:182
] P:2:0:UI1:init.c:189
] F:3:0:UI1:init.c:192:8 == 4
] F:4:0:UI1:init.c:194
] F:5:0:UI1:init.c:195
] P:6:0:UI1:init.c:196
] P:7:0:UI1:init.c:199
] P:8:0:UI1:init.c:202
] E:SemaphoreObtainTimeoutInterrupt:N:9:F:3:D:20.046650
] Z:SPINTRCRITICAL 20:C:1:N:9:F:3:D:20.049377
] Y:ReportHash:SHA256:rPZewsTyrlv5XdkPl0IqopH3hkbQ-rl8YyFFaIapo0g=
] [ RTEMS shutdown ]
] RTEMS version: 6.0.0.00f39770cae43db5b2f96cf9b6b1f8573cc694b7
] RTEMS tools: 12.1.1 20220622 (RTEMS 6, RSB
] executing thread ID: 0x08a010001
] executing thread name: UI1
] cpu 0 in error mode (tt = 0x101)
] 200897745 02008d80: 91d02000 ta 0x0
Passed: 579
Failed: 3
User Input: 6
Expected Fail: 2
Indeterminate: 0
Benchmark: 3
Timeout: 0
Test too long: 0
Invalid: 0
Wrong Version: 0
Wrong Build: 0
Wrong Tools: 0
Wrong Header: 0
Total: 593
Failures:
crypt01.exe
minimum.exe
User Input:
capture.exe
dl10.exe
top.exe
fileio.exe
termios.exe
monitor.exe
Expected Fail:
dl06.exe
psxfenv01.exe
Benchmark:
linpack.exe
dhrystone.exe
whetstone.exe
Average test time: 0:00:00.179477
Testing time : 0:01:46.430381
If you can help me I thank you and for your reading.
Wishing you a good day and a good continuation,
Aymeric PLOTON
.-. Master 2 : Distributed Systems and Applications (S.A.R.)
oo| Sorbonne University Sciences : Campus Pierre et Marie Curie
/`'\ Intern: LTCI Laboratory - INFRES - Télécom-Paris
(\_;/) E-mail : aymeric.ploton at telecom-paris.fr
RTEMS Tools Project - Source Builder Error Report
Build: error: building sparc-rtems6-kernel-erc32-1
Command Line: ../source-builder/sb-set-builder --prefix=/home/play/dev/quick-start/rtems/6 --target=sparc-rtems6 --with-rtems-bsp=erc32 --with-rtems-tests=yes 6/rtems-kernel
git://git.rtems.org/rtems-source-builder.git/origin/6c2351ce6158617afbdc3b2d74facb8dec3f0e62
Linux frea 5.18.2-051802-generic #202206060740 SMP PREEMPT_DYNAMIC Mon Jun 6 07:46:45 UTC 2022 x86_64
Tail of the build log:
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spsyslock01/
-rw-rw-r-- root/root 19447 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spsyslock01/init.c
-rw-rw-r-- root/root 1159 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spsyslock01/spsyslock01.doc
-rw-rw-r-- root/root 66 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spsyslock01/spsyslock01.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err01/
-rw-rw-r-- root/root 1503 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err01/init.c
-rw-rw-r-- root/root 748 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err01/sptask_err01.doc
-rw-rw-r-- root/root 319 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err01/sptask_err01.scn
-rw-rw-r-- root/root 1386 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err01/system.h
-rw-rw-r-- root/root 684 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err01/task2.c
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err02/
-rw-rw-r-- root/root 3098 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err02/init.c
-rw-rw-r-- root/root 757 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err02/sptask_err02.doc
-rw-rw-r-- root/root 667 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err02/sptask_err02.scn
-rw-rw-r-- root/root 809 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err02/system.h
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err03/
-rw-rw-r-- root/root 6246 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err03/init.c
-rw-rw-r-- root/root 776 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err03/sptask_err03.doc
-rw-rw-r-- root/root 891 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err03/sptask_err03.scn
-rw-rw-r-- root/root 1341 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err03/system.h
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err04/
-rw-rw-r-- root/root 2035 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err04/init.c
-rw-rw-r-- root/root 803 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err04/sptask_err04.doc
-rw-rw-r-- root/root 821 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err04/sptask_err04.scn
-rw-rw-r-- root/root 1014 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err04/system.h
-rw-rw-r-- root/root 5310 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptask_err04/task1.c
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptasknopreempt01/
-rw-rw-r-- root/root 2032 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptasknopreempt01/init.c
-rw-rw-r-- root/root 252 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptasknopreempt01/sptasknopreempt01.doc
-rw-rw-r-- root/root 77 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptasknopreempt01/sptasknopreempt01.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spthread01/
-rw-rw-r-- root/root 7232 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spthread01/init.c
-rw-rw-r-- root/root 215 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spthread01/spthread01.doc
-rw-rw-r-- root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spthread01/spthread01.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spthreadlife01/
-rw-rw-r-- root/root 10645 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spthreadlife01/init.c
-rw-rw-r-- root/root 403 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spthreadlife01/spthreadlife01.doc
-rw-rw-r-- root/root 72 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spthreadlife01/spthreadlife01.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spthreadq01/
-rw-rw-r-- root/root 6776 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spthreadq01/init.c
-rw-rw-r-- root/root 785 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spthreadq01/spthreadq01.doc
-rw-rw-r-- root/root 295 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spthreadq01/spthreadq01.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimecounter01/
-rw-rw-r-- root/root 5527 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimecounter01/init.c
-rw-rw-r-- root/root 655 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimecounter01/sptimecounter01.doc
-rw-rw-r-- root/root 74 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimecounter01/sptimecounter01.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimecounter02/
-rw-rw-r-- root/root 5866 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimecounter02/init.c
-rw-rw-r-- root/root 328 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimecounter02/sptimecounter02.doc
-rwxrwxr-x root/root 949 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimecounter02/sptimecounter02.py
-rw-rw-r-- root/root 47469 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimecounter02/sptimecounter02.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimecounter03/
-rw-rw-r-- root/root 2141 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimecounter03/init.c
-rw-rw-r-- root/root 227 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimecounter03/sptimecounter03.doc
-rw-rw-r-- root/root 74 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimecounter03/sptimecounter03.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimecounter04/
-rw-rw-r-- root/root 2141 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimecounter04/init.c
-rw-rw-r-- root/root 267 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimecounter04/sptimecounter04.doc
-rw-rw-r-- root/root 74 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimecounter04/sptimecounter04.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimer_err01/
-rw-rw-r-- root/root 7220 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimer_err01/init.c
-rw-rw-r-- root/root 675 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimer_err01/sptimer_err01.doc
-rw-rw-r-- root/root 1149 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimer_err01/sptimer_err01.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimer_err02/
-rw-rw-r-- root/root 6157 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimer_err02/init.c
-rw-rw-r-- root/root 588 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimer_err02/sptimer_err02.doc
-rw-rw-r-- root/root 961 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimer_err02/sptimer_err02.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimerserver01/
-rw-rw-r-- root/root 2893 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimerserver01/init.c
-rw-rw-r-- root/root 244 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimerserver01/sptimerserver01.doc
-rw-rw-r-- root/root 74 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimerserver01/sptimerserver01.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimespec01/
-rw-rw-r-- root/root 8105 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimespec01/init.c
-rw-rw-r-- root/root 729 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimespec01/sptimespec01.doc
-rw-rw-r-- root/root 475 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptimespec01/sptimespec01.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptls01/
-rw-rw-r-- root/root 2287 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptls01/init.c
-rw-rw-r-- root/root 353 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptls01/sptls01.doc
-rw-rw-r-- root/root 92 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptls01/sptls01.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptls02/
-rw-rw-r-- root/root 6179 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptls02/init.cc
-rw-rw-r-- root/root 269 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptls02/sptls02.doc
-rw-rw-r-- root/root 1540 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptls02/sptls02.h
-rw-rw-r-- root/root 104 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptls02/sptls02.scn
-rw-rw-r-- root/root 1493 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptls02/var.cc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptls03/
-rw-rw-r-- root/root 1277 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptls03/init.c
-rw-rw-r-- root/root 376 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptls03/sptls03.doc
-rw-rw-r-- root/root 49 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptls03/sptls03.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptls04/
-rw-rw-r-- root/root 1359 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptls04/init.c
-rw-rw-r-- root/root 284 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptls04/sptls04.doc
-rw-rw-r-- root/root 288 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/sptls04/sptls04.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spversion01/
-rw-rw-r-- root/root 1340 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spversion01/init.c
-rw-rw-r-- root/root 768 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spversion01/spversion01.doc
-rw-rw-r-- root/root 431 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spversion01/spversion01.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spwatchdog/
-rw-rw-r-- root/root 774 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spwatchdog/delay.c
-rw-rw-r-- root/root 8717 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spwatchdog/init.c
-rw-rw-r-- root/root 747 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spwatchdog/prtime.c
-rw-rw-r-- root/root 471 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spwatchdog/spwatchdog.doc
-rw-rw-r-- root/root 615 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spwatchdog/spwatchdog.scn
-rw-rw-r-- root/root 1479 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spwatchdog/system.h
-rw-rw-r-- root/root 2130 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spwatchdog/task1.c
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spwkspace/
-rw-rw-r-- root/root 3483 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spwkspace/init.c
-rw-rw-r-- root/root 923 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spwkspace/spwkspace.doc
-rw-rw-r-- root/root 460 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/sptests/spwkspace/spwkspace.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/support/
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/support/include/
-rw-rw-r-- root/root 348 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/support/include/buffer_test_io.h
-rw-rw-r-- root/root 532 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/support/include/primode.h
-rw-rw-r-- root/root 532 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/support/include/pritime.h
-rw-rw-r-- root/root 2186 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/support/include/test_support.h
-rw-rw-r-- root/root 8333 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/support/include/tmacros.h
-rw-rw-r-- root/root 573 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/support/include/tmtests_empty_function.h
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/support/src/
-rw-rw-r-- root/root 2315 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/support/src/locked_print.c
-rw-rw-r-- root/root 902 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/support/src/spin.c
-rw-rw-r-- root/root 827 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/support/src/test_support.c
-rw-rw-r-- root/root 647 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/support/src/tmtests_empty_function.c
-rw-rw-r-- root/root 1145 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/support/src/tmtests_support.c
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/testdata/
-rw-rw-r-- root/root 131 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/testdata/disable-iconv-tests.tcfg
-rw-rw-r-- root/root 752 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/testdata/disable-intrcritical-tests.tcfg
-rw-rw-r-- root/root 291 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/testdata/disable-jffs2-tests.tcfg
-rw-rw-r-- root/root 287 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/testdata/disable-libdl-tests.tcfg
-rw-rw-r-- root/root 294 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/testdata/disable-mrfs-tests.tcfg
-rw-rw-r-- root/root 2111 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/testdata/require-tick-isr.tcfg
-rw-rw-r-- root/root 657 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/testdata/rtems.tcfg
-rw-rw-r-- root/root 447 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/testdata/small-memory-testsuite.tcfg
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/
-rw-rw-r-- root/root 949 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/README
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/include/
-rw-rw-r-- root/root 1804 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/include/timesys.h
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm01/
-rw-rw-r-- root/root 961 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm01/system.h
-rw-rw-r-- root/root 4677 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm01/task1.c
-rw-rw-r-- root/root 502 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm01/tm01.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm02/
-rw-rw-r-- root/root 844 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm02/system.h
-rw-rw-r-- root/root 35 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm02/task1.c
-rw-rw-r-- root/root 465 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm02/tm02.doc
-rw-rw-r-- root/root 4056 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm02/tm02impl.h
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm03/
-rw-rw-r-- root/root 844 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm03/system.h
-rw-rw-r-- root/root 35 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm03/task1.c
-rw-rw-r-- root/root 428 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm03/tm03.doc
-rw-rw-r-- root/root 4083 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm03/tm03impl.h
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm04/
-rw-rw-r-- root/root 844 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm04/system.h
-rw-rw-r-- root/root 9121 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm04/task1.c
-rw-rw-r-- root/root 509 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm04/tm04.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm05/
-rw-rw-r-- root/root 797 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm05/system.h
-rw-rw-r-- root/root 2633 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm05/task1.c
-rw-rw-r-- root/root 438 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm05/tm05.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm06/
-rw-rw-r-- root/root 797 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm06/system.h
-rw-rw-r-- root/root 3384 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm06/task1.c
-rw-rw-r-- root/root 483 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm06/tm06.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm07/
-rw-rw-r-- root/root 797 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm07/system.h
-rw-rw-r-- root/root 2624 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm07/task1.c
-rw-rw-r-- root/root 416 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm07/tm07.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm08/
-rw-rw-r-- root/root 777 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm08/system.h
-rw-rw-r-- root/root 5151 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm08/task1.c
-rw-rw-r-- root/root 486 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm08/tm08.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm09/
-rw-rw-r-- root/root 1120 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm09/system.h
-rw-rw-r-- root/root 5402 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm09/task1.c
-rw-rw-r-- root/root 577 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm09/tm09.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm10/
-rw-rw-r-- root/root 945 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm10/system.h
-rw-rw-r-- root/root 3545 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm10/task1.c
-rw-rw-r-- root/root 425 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm10/tm10.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm11/
-rw-rw-r-- root/root 844 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm11/system.h
-rw-rw-r-- root/root 3518 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm11/task1.c
-rw-rw-r-- root/root 422 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm11/tm11.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm12/
-rw-rw-r-- root/root 844 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm12/system.h
-rw-rw-r-- root/root 3359 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm12/task1.c
-rw-rw-r-- root/root 422 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm12/tm12.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm13/
-rw-rw-r-- root/root 844 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm13/system.h
-rw-rw-r-- root/root 3532 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm13/task1.c
-rw-rw-r-- root/root 424 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm13/tm13.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm14/
-rw-rw-r-- root/root 844 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm14/system.h
-rw-rw-r-- root/root 3353 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm14/task1.c
-rw-rw-r-- root/root 424 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm14/tm14.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm15/
-rw-rw-r-- root/root 865 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm15/system.h
-rw-rw-r-- root/root 4692 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm15/task1.c
-rw-rw-r-- root/root 438 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm15/tm15.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm16/
-rw-rw-r-- root/root 865 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm16/system.h
-rw-rw-r-- root/root 3429 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm16/task1.c
-rw-rw-r-- root/root 414 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm16/tm16.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm17/
-rw-rw-r-- root/root 865 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm17/system.h
-rw-rw-r-- root/root 2830 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm17/task1.c
-rw-rw-r-- root/root 421 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm17/tm17.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm18/
-rw-rw-r-- root/root 797 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm18/system.h
-rw-rw-r-- root/root 2096 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm18/task1.c
-rw-rw-r-- root/root 415 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm18/tm18.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm19/
-rw-rw-r-- root/root 845 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm19/system.h
-rw-rw-r-- root/root 4268 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm19/task1.c
-rw-rw-r-- root/root 455 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm19/tm19.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm20/
-rw-rw-r-- root/root 987 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm20/system.h
-rw-rw-r-- root/root 10201 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm20/task1.c
-rw-rw-r-- root/root 849 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm20/tm20.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm21/
-rw-rw-r-- root/root 1377 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm21/system.h
-rw-rw-r-- root/root 5486 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm21/task1.c
-rw-rw-r-- root/root 593 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm21/tm21.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm22/
-rw-rw-r-- root/root 966 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm22/system.h
-rw-rw-r-- root/root 4142 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm22/task1.c
-rw-rw-r-- root/root 427 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm22/tm22.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm23/
-rw-rw-r-- root/root 858 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm23/system.h
-rw-rw-r-- root/root 7087 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm23/task1.c
-rw-rw-r-- root/root 562 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm23/tm23.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm24/
-rw-rw-r-- root/root 797 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm24/system.h
-rw-rw-r-- root/root 2672 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm24/task1.c
-rw-rw-r-- root/root 419 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm24/tm24.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm25/
-rw-rw-r-- root/root 844 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm25/system.h
-rw-rw-r-- root/root 2327 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm25/task1.c
-rw-rw-r-- root/root 414 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm25/tm25.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm26/
-rw-rw-r-- root/root 4730 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm26/fptest.h
-rw-rw-r-- root/root 948 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm26/system.h
-rw-rw-r-- root/root 16662 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm26/task1.c
-rw-rw-r-- root/root 679 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm26/tm26.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm27/
-rw-rw-r-- root/root 883 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm27/system.h
-rw-rw-r-- root/root 7259 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm27/task1.c
-rw-rw-r-- root/root 242 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm27/tm27.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm28/
-rw-rw-r-- root/root 892 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm28/system.h
-rw-rw-r-- root/root 2866 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm28/task1.c
-rw-rw-r-- root/root 509 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm28/tm28.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm29/
-rw-rw-r-- root/root 931 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm29/system.h
-rw-rw-r-- root/root 4537 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm29/task1.c
-rw-rw-r-- root/root 521 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm29/tm29.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm30/
-rw-rw-r-- root/root 2243 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm30/init.c
-rw-rw-r-- root/root 467 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm30/tm30.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm31/
-rw-rw-r-- root/root 43 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm31/task1.c
-rw-rw-r-- root/root 431 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm31/tm31.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm32/
-rw-rw-r-- root/root 43 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm32/task1.c
-rw-rw-r-- root/root 432 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm32/tm32.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm33/
-rw-rw-r-- root/root 43 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm33/task1.c
-rw-rw-r-- root/root 425 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm33/tm33.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm34/
-rw-rw-r-- root/root 43 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm34/task1.c
-rw-rw-r-- root/root 426 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm34/tm34.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm35/
-rw-rw-r-- root/root 43 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm35/task1.c
-rw-rw-r-- root/root 429 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm35/tm35.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm36/
-rw-rw-r-- root/root 43 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm36/task1.c
-rw-rw-r-- root/root 430 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tm36/tm36.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmck/
-rw-rw-r-- root/root 847 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmck/system.h
-rw-rw-r-- root/root 3749 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmck/task1.c
-rw-rw-r-- root/root 455 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmck/tmck.doc
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmcontext01/
-rw-rw-r-- root/root 5828 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmcontext01/init.c
-rw-rw-r-- root/root 1341 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmcontext01/plot.py
-rw-rw-r-- root/root 244 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmcontext01/tmcontext01.doc
-rw-rw-r-- root/root 14864 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmcontext01/tmcontext01.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmfine01/
-rw-rw-r-- root/root 18449 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmfine01/init.c
-rw-rw-r-- root/root 703 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmfine01/tmfine01.doc
-rw-rw-r-- root/root 1637 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmfine01/tmfine01.py
-rw-rw-r-- root/root 167066 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmfine01/tmfine01.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmonetoone/
-rw-rw-r-- root/root 7029 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmonetoone/init.c
-rw-rw-r-- root/root 376 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmonetoone/tmonetoone.doc
-rw-rw-r-- root/root 490 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmonetoone/tmonetoone.scn
-rw-rw-r-- root/root 7810 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmtests_plan.csv
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmtimer01/
-rw-rw-r-- root/root 4348 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmtimer01/init.c
-rw-rw-r-- root/root 730 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmtimer01/plot.py
-rw-rw-r-- root/root 255 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmtimer01/tmtimer01.doc
-rw-rw-r-- root/root 6692 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/tmtests/tmtimer01/tmtimer01.scn
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/
-rw-rw-r-- root/root 19872 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-barrier-create.c
-rw-rw-r-- root/root 11504 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-barrier-delete.c
-rw-rw-r-- root/root 14119 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-barrier-release.c
-rw-rw-r-- root/root 15236 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-barrier-wait.c
-rw-rw-r-- root/root 15289 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-intr-clear.c
-rw-rw-r-- root/root 41550 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-intr-entry-install.c
-rw-rw-r-- root/root 41455 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-intr-entry-remove.c
-rw-rw-r-- root/root 19684 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-intr-get-affinity.c
-rw-rw-r-- root/root 12893 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-intr-get-attributes.c
-rw-rw-r-- root/root 17429 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-intr-handler-iterate.c
-rw-rw-r-- root/root 17023 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-intr-is-pending.c
-rw-rw-r-- root/root 18891 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-intr-raise-on.c
-rw-rw-r-- root/root 15018 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-intr-raise.c
-rw-rw-r-- root/root 18825 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-intr-set-affinity.c
-rw-rw-r-- root/root 17438 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-intr-vector-disable.c
-rw-rw-r-- root/root 17348 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-intr-vector-enable.c
-rw-rw-r-- root/root 17357 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-intr-vector-is-enabled.c
-rw-rw-r-- root/root 28302 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-message-construct-errors.c
-rw-rw-r-- root/root 4902 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-object.c
-rw-rw-r-- root/root 10778 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-part-performance.c
-rw-rw-r-- root/root 25078 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-signal-catch.c
-rw-rw-r-- root/root 23359 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-signal-send.c
-rw-rw-r-- root/root 35351 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-task-construct-errors.c
-rw-rw-r-- root/root 27051 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tc-task-create-errors.c
-rw-rw-r-- root/root 6291 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/ts-default.h
-rw-rw-r-- root/root 2736 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/ts-performance-0.c
-rw-rw-r-- root/root 2722 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/ts-validation-0.c
-rw-rw-r-- root/root 2639 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/ts-validation-1.c
-rw-rw-r-- root/root 3942 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tx-call-within-isr.c
-rw-rw-r-- root/root 4059 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tx-interrupt.c
-rw-rw-r-- root/root 4244 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tx-support.c
-rw-rw-r-- root/root 3525 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/testsuites/validation/tx-support.h
-rwxrwxr-x root/root 104725 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/waf
-rwxrwxr-x root/root 51859 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/wscript
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/
-rw-rw-r-- root/root 1101 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/LICENSE
-rw-rw-r-- root/root 1781 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/PKG-INFO
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/yaml/
-rw-rw-r-- root/root 13340 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/yaml/__init__.py
-rw-rw-r-- root/root 4923 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/yaml/composer.py
-rw-rw-r-- root/root 28797 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/yaml/constructor.py
-rw-rw-r-- root/root 3842 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/yaml/cyaml.py
-rw-rw-r-- root/root 2833 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/yaml/dumper.py
-rw-rw-r-- root/root 43407 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/yaml/emitter.py
-rw-rw-r-- root/root 2559 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/yaml/error.py
-rw-rw-r-- root/root 2445 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/yaml/events.py
-rw-rw-r-- root/root 2055 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/yaml/loader.py
-rw-rw-r-- root/root 1440 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/yaml/nodes.py
-rw-rw-r-- root/root 25542 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/yaml/parser.py
-rw-rw-r-- root/root 6913 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/yaml/reader.py
-rw-rw-r-- root/root 17787 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/yaml/representer.py
-rw-rw-r-- root/root 9122 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/yaml/resolver.py
-rw-rw-r-- root/root 52027 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/yaml/scanner.py
-rw-rw-r-- root/root 4171 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/yaml/serializer.py
-rw-rw-r-- root/root 2573 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib/yaml/tokens.py
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/
drwxrwxr-x root/root 0 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/yaml/
-rw-rw-r-- root/root 13170 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/yaml/__init__.py
-rw-rw-r-- root/root 4883 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/yaml/composer.py
-rw-rw-r-- root/root 28627 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/yaml/constructor.py
-rw-rw-r-- root/root 3846 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/yaml/cyaml.py
-rw-rw-r-- root/root 2837 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/yaml/dumper.py
-rw-rw-r-- root/root 43006 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/yaml/emitter.py
-rw-rw-r-- root/root 2533 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/yaml/error.py
-rw-rw-r-- root/root 2445 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/yaml/events.py
-rw-rw-r-- root/root 2061 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/yaml/loader.py
-rw-rw-r-- root/root 1440 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/yaml/nodes.py
-rw-rw-r-- root/root 25495 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/yaml/parser.py
-rw-rw-r-- root/root 6794 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/yaml/reader.py
-rw-rw-r-- root/root 14184 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/yaml/representer.py
-rw-rw-r-- root/root 8970 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/yaml/resolver.py
-rw-rw-r-- root/root 51277 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/yaml/scanner.py
-rw-rw-r-- root/root 4165 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/yaml/serializer.py
-rw-rw-r-- root/root 2573 2021-10-06 10:41 rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/yaml/lib3/yaml/tokens.py
+ tar_exit=0
+ /bin/chmod -R a+rX,g-w,o-w .
+ cd rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3
==> clean %{buildroot}: /home/play/dev/quick-start/src/rsb/6/rtems/build/tmp/sparc-rtems6-kernel-erc32-1-1000
+ export PATH=/home/play/dev/quick-start/src/rsb/6/rtems/build/tmp/sb-1000/home/play/dev/quick-start/rtems/6/bin:/home/play/dev/quick-start/rtems/6/bin:/home/play/dev/quick-start/src/rsb/6/source-builder:/home/play/dev/quick-start/src/rsb/6/rtems/build/tmp/sb-1000-cxc/6/rtems-kernel/home/play/dev/quick-start/rtems/6/bin:/home/play/dev/quick-start/src/rsb/6/rtems/build/tmp/sb-1000/6/rtems-kernel/home/play/dev/quick-start/rtems/6/bin:/home/play/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/home/play/dev/quick-start/rtems/6/bin
+ cd ..
+ SB_CXC=no
+ echo ==> clean %{buildroot}: /home/play/dev/quick-start/src/rsb/6/rtems/build/tmp/sparc-rtems6-kernel-erc32-1-1000
+ /bin/rm -rf /home/play/dev/quick-start/src/rsb/6/rtems/build/tmp/sparc-rtems6-kernel-erc32-1-1000
+ /bin/mkdir -p /home/play/dev/quick-start/src/rsb/6/rtems/build/tmp/sparc-rtems6-kernel-erc32-1-1000
+ echo ==> %build:
==> %build:
+ test x86_64-linux-gnu != x86_64-linux-gnu
+ build_dir=build
+ mkdir -p build
+ ./waf configure --rtems-bsps=sparc-rtems6/erc32 --prefix=/home/play/dev/quick-start/rtems/6 --bindir=/home/play/dev/quick-start/rtems/6/bin --rtems-config=config-sparc-rtems6-erc32.ini
Setting top to : /home/play/dev/quick-start/src/rsb/6/rtems/build/sparc-rtems6-kernel-erc32-1/sparc-rtems6-kernel-erc32-1-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3
Setting out to : /home/play/dev/quick-start/src/rsb/6/rtems/build/sparc-rtems6-kernel-erc32-1/sparc-rtems6-kernel-erc32-1-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/build
Regenerate build specification cache (needs a couple of seconds)...
Option file 'config-sparc-rtems6-erc32.ini' was not readable
(complete log in /home/play/dev/quick-start/src/rsb/6/rtems/build/sparc-rtems6-kernel-erc32-1/sparc-rtems6-kernel-erc32-1-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/rtems-3bb97a30b17b6c138dead3e3a6b329c3b301cdb3/build/config.log)
shell cmd failed: /bin/sh -ex /home/play/dev/quick-start/src/rsb/6/rtems/build/sparc-rtems6-kernel-erc32-1/do-build
