Suspending Tasks before they are finished
Mon Mar 14 13:12:15 UTC 2022
On Mon, Mar 14, 2022 at 6:44 AM Jerzy J <yuralogplus at gmail.com> wrote:
> Hi,
> I've been developing some tests and observed some task behaviour that i
> can't understand and couldn't find any documentation about it.
> I have tests where I create 2 extra tasks (Workers) and then those tasks
> are blocked and unlocked using semaphores and barriers. However, whenever
> main task (Runner) is about to get blocked, the test crashes (just finishes
> instantly). In some configurations is seems to "deadlock" on a semaphore
> instead, while it should be able to move forward.
> I realised that if I suspend the Worker tasks before they are about to
> finish, with for e.g:
> `rtems_event_receive( RTEMS_ALL_EVENTS, RTEMS_DEFAULT_OPTIONS, 0, &events
> line at the very end of worker execution, it all works as expected.
If these are Classic API tasks (e.g. rtems_task_create) and they are
falling off
the bottom of the function that is the task body, that's a fatal error. If
it is a POSIX
thread, it silently goes away.
> Do you maybe know what is the reason for such behaviour? I'm also not sure
> in which state is the task after it finishes it's execution but before it
> is deleted, is it 'blocked' or is it 'dormant'?
Depends on the API and attributes on a pthread.
--joel
> Thanks and all the best,
> Jerzy
> users mailing list
> users at rtems.org
