RTEMS5 for arm on macOS 12.3. Or how Apple blew up RTEMS.
Mr. Andrei Chichak
groups at chichak.ca
Fri Mar 25 21:44:59 UTC 2022
Good day. It must be Friday afternoon, because my RTEMS5 install has been messed up. Yes, this install worked until now.
RTEMS5, stm32f4 BSP, macOS
I recently updated macOS to 12.3 (Monterey) and a “feature" of 12.3 is the removal of python 2.7. This caused arm-rtems5-gdb to fail with:
dyld[12480]: Library not loaded: /System/Library/Frameworks/Python.framework/Versions/2.7/Python
Referenced from: /Users/andreichichak/RTEMS5/rtems/5/bin/arm-rtems5-gdb
Reason: tried: '/System/Library/Frameworks/Python.framework/Versions/2.7/Python' (no such file), '/Library/Frameworks/Python.framework/Versions/2.7/Python' (no such file)
Abort trap: 6
I went back to my install scripts, grabbed the latest RSB blob, then
../source-builder/sb-set-builder —prefix=$HOME/RTEMS5/rtems/5 5/rtems-arm
goes well for a while then fails setting up to build gdb with:
config: tools/rtems-gdb-9.1-1.cfg
error: config error: gdb-common-1.cfg:99: "gdb: python: header file not found: python3.8/Python.h, please install”
I had python 3.9 installed, so I used brew and installed 3.8, uninstalled 3.9, reinstalled 3.8, rebooted, but I get the same rsb failure.
I’m not sure how python is supposed to be configured. Maybe this is a clue:
python —version
-bash: python: command not found
python3 —version
Python 3.8.9
I seem to have a couple of instances of Python.h in an appropriately named directory:
/usr/local/Cellar/python at 3.8/3.8.13/Frameworks/Python.framework/Versions/3.8/include/python3.8/Python.h
/System/Volumes/Data/usr/local/Cellar/python at 3.8/3.8.13/Frameworks/Python.framework/Versions/3.8/include/python3.8/Python.h
But something doesn’t seem to be pointing at one of those folders so the rsb script can find it.
Any hints?
Thanks,
Andrei
Andrei Chichak
Systems Developer
CBF Systems Inc.
225 College Plaza
8215 112 Street.
EDMONTON, ALBERTA
T6G 2C8
CANADA
Phone: 780-628-2072
Skype: andrei.chichak
