RTEMS 5 on mcp750 fails
Sat May 21 17:06:27 UTC 2022
On Sat, May 21, 2022, 11:02 AM Miroslaw Dach <miroslaw.dach at gmail.com>
wrote:
> Hi Hainz,
> Thanks for the indication. I have exactly found this setting and am going
> to reduce
> CONFIGURE_EXTRA_TASK_STACKS which is currently setup by default in EPICS
> to 32MB.
> The mcp750 has just 32MB so it is no wonder that it does not work.
If it is configured for unified workspace, you wouldn't specify extra
stacks and this wouldn't have been tripped.
Unified and unlimited can avoid some issues.
--joel
> I will test the new configuration next week.
> Have a nice weekend
> Best Regards
> Mirek
> sob., 21 maj 2022 o 05:39 Heinz Junkes <junkes at fhi-berlin.mpg.de>
> napisał(a):
>> Hi Mirek,
>> You can find the configuration of the RTEMS at EPICS here:
>> epics-base/modules/libcom/RTEMS/posix/rtems_config.c
>> There for example
>> #define CONFIGURE_EXTRA_TASK_STACKS         (4000 *
>> RTEMS_MINIMUM_STACK_SIZE)
>> #define CONFIGURE_UNLIMITED_ALLOCATION_SIZE 32
>> #define CONFIGURE_UNLIMITED_OBJECTS
>> #define CONFIGURE_UNIFIED_WORK_AREAS
>> best regards,
>> Heinz
>> > On 21. May 2022, at 00:21, Joel Sherrill <joel at rtems.org> wrote:
>> > On Fri, May 20, 2022 at 3:55 PM Miroslaw Dach <miroslaw.dach at gmail.com>
>> > wrote:
>> >> Hi Chris,
>> >> Thank you very much for your expertise and attached links which are
>> very
>> >> helpful.
>> >> As regards the INTERNAL_ERROR_TOO_LITTLE_WORKSPACE error message:
>> >> Is it possible to determine with some debug information what is the
>> >> foreseen by RTEMS WORKSPACE size?
>> > This CONFIGURE_MEMORY_OVERHEAD is there as a mechanism to toss
>> > extra memory at the workspace in case confdefs.h makes a mistake. I
>> think
>> > this
>> > is more likely to be something else like a misconfigured system. But
>> adding
>> > this
>> > to your RTEMS configuration with some chunk of memory like 128K might
>> > allow this to proceed. But if it is a memory allocation error in the BSP
>> > like
>> > not assigning memory right to RTEMS, this won't fix it. See:
>> https://docs.rtems.org/branches/master/c-user/config/general.html#configure-memory-overhead
>> > Chris has touched one of the boards in the motorola_powerpc family
>> > more recently than I have. I would think this would work unless
>> something
>> > is off in the EPICS configuration of RTEMS. There was a discussion of
>> the
>> > EPICS RTEMS configuration with Till recently on tech-talk and I thought
>> > it looked ok.
>> > --joel
>> >> Best Regards
>> >> Mirek
>> >> śr., 18 maj 2022 o 00:53 Chris Johns <chrisj at rtems.org> napisał(a):
>> >>> On 18/5/2022 9:36 am, Miroslaw Dach wrote:
>> >>>> Dear RTEMS Users and Developers,
>> >>>> I have built RTEMS 5 with EPICS 7 and tried to boot my application on
>> >>>> mcp750 cPCI board.
>> >>>> The first thing that I have encountered is that the boot file is in
>> the
>> >>> elf
>> >>>> format so I have
>> >>>> converted it to the binary one.:
>> >>>> powerpc-rtems5-objcopy -I elf32-powerpc -O binary myApp.boot
>> >>> myApp.boot.bin
>> >>> We removed the various post-link hooks.
>> >>>> So far so good
>> >>>> Next, I booted the system with my app and it fails in the *bsp_early*
>> >>>> function in
>> >>>> bsps/powerpc/motorola_powerpc/start/bspstart.c
>> >>>> The boot sequence:
>> >>>> Network Boot File load in progress... To abort hit <BREAK>
>> >>>> Bytes Received =&1270208, Bytes Loaded =&1270208
>> >>>> Bytes/Second =&635104, Elapsed Time =2 Second(s)
>> >>>> Residual-Data Located at: $01F88000
>> >>>> Model: (e2)
>> >>>> Serial: MOT0000000
>> >>>> Processor/Bus frequencies (Hz): 366680480/66671508
>> >>>> Time Base Divisor: 4000
>> >>>> Memory Size: 2000000
>> >>>> Residual: 1f88000 (length 27148)
>> >>>> PCI: Probing PCI hardware
>> >>>> RTEMS 5.0.0/PPC load:
>> >>>> Uncompressing the kernel...
>> >>>> done
>> >>>> Now booting...
>> >>>> Welcome to rtems-5.0.0 (PowerPC/Generic (classic FPU)/mcp750) on
>> >> Mesquite
>> >>>> cPCI (MCP750)
>> >>>> idreg 0 = 0x1208029271
>> >>>> OpenPIC found at 0xc1000000.
>> >>>> pci : Configuring interrupt routing for 'Mesquite cPCI (MCP750)'
>> >>>> pci : No bridge from bus 0 towards root found
>> >>>> pci : Device 1:0x0b:0 routed to interrupt_line 27
>> >>>> pci : Device 1:0x0d:0 routed to interrupt_line 25
>> >>>> Cleared PCI errors: pci_stat was 0x2280
>> >>>> OpenPIC Version ? (2 CPUs and 16 IRQ sources) at 0x3238002688
>> >>>> OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 2
>> >>>> OpenPIC timer frequency is 8333848 Hz
>> >>> This all looks OK.
>> >>>> *** FATAL ***
>> >>>> fatal source: 0 (INTERNAL_ERROR_CORE)
>> >>>> fatal code: 2 (INTERNAL_ERROR_TOO_LITTLE_WORKSPACE)
>> >>>> RTEMS version:
>> 5.0.0.fc89cc76804499eba3f3bc4097b795a84f07571a-modified
>> >>>> RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5 (6225eadda1de), Newlib
>> >>> 7947581)
>> >>>> executing thread is NULL
>> >>>> My application in the binary format uncompressed with stripped
>> symbols
>> >>> is a
>> >>>> 2.3M + 501K bootloader so I do not think that it
>> >>>> is an issue with the WORKSPACE? The mcp750 has 32MB of RAM.
>> >>>> How to detect what is the real cause of
>> >>>> Would it be the problem with the linker script ppcboot.lds?
>> >>> I do not think so. I suggest you check the Classic API Guide here:
>> https://ftp.rtems.org/pub/rtems/releases/5/5.1/docs/html/c-user/config/intro.html#sizing-the-rtems-workspace
>> >>> The accounting of memory is better and this means the extra space
>> needed
>> >>> may
>> >>> need to be adjusted. I am not sure where in EPCIS this is controlled
>> and
>> >>> if it
>> >>> can be overridden in your local configuration.
>> >>> RTEMS 5 has a unified workspace and heap. This means the heap and
>> >>> workspace can
>> >>> use memory until it is all used. The benefit is not need to manage the
>> >>> workspace
>> >>> size statically:
>> https://ftp.rtems.org/pub/rtems/releases/5/5.1/docs/html/c-user/config/general.html#configure-unified-work-areas
>> >>> Chris
>> >> _______________________________________________
>> >> users mailing list
>> >> users at rtems.org
>> >> http://lists.rtems.org/mailman/listinfo/users
>> > users mailing list
>> > users at rtems.org
