Running two RTEMS instances on two RISC-V harts
Mon Oct 24 13:19:36 UTC 2022
The leon3 BSP also supported something similar at one point.
If the two applications do not need to communicate, then it should
not be an issue. If the do need to communicate, then this might be
a case where the original distributed multiprocessing in RTEMS makes
sense. It isn't used much but is still there. Or you could just reserve some
RAM for a shared communications area and manage it yourself.
The key is going to be keeping the two really separate and making
sure you can load two images.
--joel
On Mon, Oct 24, 2022 at 8:03 AM Sebastian Huber <
> Hello Jens,
> in general, such a setups works. We used it some time ago on the NXP
> P1020 before the SMP support was available. You just have to provide two
> MEMORY definitions for the linker. You also have to make sure that you
> don't accidentally share hardware modules between the two RTEMS
> instances without synchronization.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20221024/12d92a49/attachment.htm>
