How can I use --with-rtems-bspopts properly?
Y. HB sprhawk at gmail.com
Fri Sep 16 09:45:05 UTC 2022
Hello,
I am working on tms570 bsp
I want to change some bspopts , but I cannot get the default value
overridden via --with-rtems-bspopts, what correct way should I do?
I used following command to configure RTEMS bsp
../../rtems-master/configure  OTHER-OPTIONS
--with-rtems-bspopts="TMS570_USE_HWINIT_STARTUP=1 ARM_TMS570LC4357=1
BSP_MINIMUM_TASK_STACK_SIZE=2048"
But the generated bspopts.h is not changed with above values.
URL: <http://lists.rtems.org/pipermail/users/attachments/20220916/0a6d8406/attachment.htm>
