RSB build fails on M1 Macbook Pro
Karel Gardas
karel.gardas at centrum.cz
Tue Sep 20 13:00:52 UTC 2022
JFYI: 2 months ago I pushed patches in order to make M1 working at least
for arm target. As devil is in the detail you will also need to provide
rsb-report-sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1.txt for
investigation.
Karel
On 9/20/22 14:55, Andrew.Butterfield at scss.tcd.ie wrote:
> Dear all,
> I tried to follow the Quickstart on my new M1 Macbook Pro (Apple Silicon),
> which one of my students is also trying to do.
> It fails with the following error
> downloading: sources/gdb-11.2.tar.xz - 21.0MB of 21.0MB (100%)
> building: sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1
> error: building sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1
> Build FAILED
> See error report: rsb-report-sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1.txt
> Build Set: Time 0:06:26.055237
> Build Set: Time 0:06:26.058387
> Build FAILED
> python maps to /usr/local/bin/python - it's a Mach-O 64-bit executable x86_64
> python --version is 3.6.8
> There is a homebrew python3 but it's an arm64 executable, so seems not to be implicated.
> The full terminal transcript is attached
> Regards,
> Andrew
> Andrew Butterfield Tel: +353-1-896-2517 Fax: +353-1-677-2204
> Lero at TCD, Head of Software Foundations & Verification Research Group
> School of Computer Science and Statistics,
> Room G.39, O'Reilly Institute, Trinity College, University of Dublin
> http://www.scss.tcd.ie/Andrew.Butterfield/
> users mailing list
> users at rtems.org
