arm bsps: changing the float-abi to softfp
Chris Johns
chrisj at rtems.org
Wed Apr 5 05:25:29 UTC 2023
On 5/4/2023 4:11 am, Sebastian Huber wrote:
> If you really need such a multilib, then you can patch gcc/config/arm/t-rtems. I
> don't know if you can add custom patches to the RTEMS Source Builder.
There is a means if someone wants to update gcc-common-1.cfg to allow user macro
maps.
1. User patch or source macro map
Create a user macro map. Examples can be found here:
https://git.rtems.org/rtems-source-builder/tree/rtems/config/snapshots
2. Update gcc-common-1.cfg to select user macro maps
Update:
https://git.rtems.org/rtems-source-builder/tree/source-builder/config/gcc-common-1.cfg
with suitable selects. For example:
https://git.rtems.org/rtems-source-builder/tree/source-builder/config/gcc-4.7-1.cfg
I suggest:
%select gcc-user
%select newlib-user
3. Provide your macros to the set builder command using --macros.
You can also set the environment variable `RSB_MACROS` or create a file called
$HOME/.rsb_macros.
It has been many years since I have used and tested this.
