arm bsps: changing the float-abi to softfp
Steinbach, Ingolf
Ingolf.Steinbach at jena-optronik.de
Wed Apr 5 05:59:01 UTC 2023
Hi Sebastian.
> Why would you use
> this instead of -mfloat-abi=hard? For a statically linked executable
> this makes little sense.
My goal is to link with a 3rd party object file which had been compiled with -mfloat-abi=softfp and which cannot be recompiled. In fact, there are also other flags which might cause a conflict with the current flags used by RTEMS and which might cause even more headache (-mfpu comes to my mind).
> If you really need such a multilib, then you can patch
> gcc/config/arm/t-rtems. I don't know if you can add custom patches to
> the RTEMS Source Builder.
I assume that I could add them to the corresponding config/tools/*.cfg.
Kind regards
Ingolf
