Can't get qemu to run aarch64/xilinx_zynqmp_lp64_qemu example app
Kinsey Moore kinsey.moore at oarcorp.com
Mon Apr 10 15:00:51 UTC 2023
Hi Jens,
You're using the QEMU command line from the A53 QEMU BSP, not the ZynqMP LP64 QEMU BSP. The flag "-machine virt,gic-version=3" should instead be "-machine xlnx-zcu102".
This change should get you up and running. The details for the ZynqMP BSP family can be found further down the page you linked:
https://docs.rtems.org/branches/master/user/bsps/bsps-aarch64.html?highlight=qemu#qemu-xilinx-zynqmp
Kinsey
-----Original Message-----
From: users <users-bounces at rtems.org> On Behalf Of Jens Schweikhardt
Sent: Sunday, April 9, 2023 3:46 PM
To: users <users at rtems.org>
Subject: Can't get qemu to run aarch64/xilinx_zynqmp_lp64_qemu example app
Hello world,
I've installed an aarch64 toolchain and the xilinx_zynqmp_lp64_qemu BSP
from current sources with waf (on FreeBSD 14).
The docs on https://docs.rtems.org/branches/master/user/bsps/bsps-aarch64.html?highlight=qemu#aarch64-aarch64
tell me to run
qemu-system-aarch64 -no-reboot -nographic -serial mon:stdio \
 -machine virt,gic-version=3 -cpu cortex-a53 -m 4096 \
 -kernel build/aarch64-rtems6-xilinx_zynqmp_lp64_qemu/kernel.exe
which just sits there with no output (I expect a repeated greeting).
Here are my hello.c, init.c, wscript:
   * Hello world example
  rtems_task Init(rtems_task_argument ignored) {
      for (;;) {
          puts("Hello World\n");
          rtems_task_wake_after(100);
---------------init.c:
   * Simple RTEMS configuration
  #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
  #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
  #define CONFIGURE_UNLIMITED_OBJECTS
  #define CONFIGURE_UNIFIED_WORK_AREAS
  #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
  #define CONFIGURE_INIT
  #define CONFIGURE_INIT_TASK_STACK_SIZE 65536
  #define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
--------wscript:
# Hello world Waf script
from __future__ import print_function
rtems_version = "6"
try:
    import rtems_waf.rtems as rtems
except:
    print('error: no rtems_waf git submodule')
    import sys
    sys.exit(1)
def init(ctx):
    rtems.init(ctx, version = rtems_version, long_commands = True)
def bsp_configure(conf, arch_bsp):
    # Add BSP specific configuration checks
    pass
def options(opt):
    rtems.options(opt)
def configure(conf):
    rtems.configure(conf, bsp_configure = bsp_configure)
def build(bld):
    rtems.build(bld)
    bld(features = 'c cprogram',
        target = 'kernel.exe',
        cflags = '-g -O2',
        source = ['hello.c',
                  'init.c'])
I've tried many variations on the qemu options but never got any output.
This is with
# qemu-system-aarch64 --version
QEMU emulator version 7.2.50
What am I doing wrong? Has anyone else gotten the example in the RTEMS docs to work
with the described procedure?
Regards,
        Jens
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
