Networking examples
Vijay Kumar Banerjee vijay at rtems.org
Tue Aug 15 18:53:02 UTC 2023
On Tue, Aug 15, 2023, 13:10 Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Aug 15, 2023 at 11:57 AM Brett Sterling <
> brett.sterling at odysseysr.com> wrote:
>> Hello all!
>> To get this out of the way prior to all of the requested debugging
>> information - I don't need the legacy stack, any networking stack will do.
>> I started with legacy because that was what was shown on the RTEMS
>> documentation pages.  We're trying to integrate RTEMS into our system and I
>> considered adding the networking stack that had some documentation a big
>> enough effort without perhaps trying to integrate another network stack.
>> But I'm absolutely glad to go with any suggestion.
>> Now, onto the requested build failure information.
>> Following
>> https://docs.rtems.org/branches/master/legacy-networking/quick_start.html
>> ../source-builder/sb-set-builder --prefix=$HOME/src/rtems-net-build
>> 6/rtems-net-legacy --host=sparc-rtems6 --with-rtems-bsp=sparc
>> RTEMS Source Builder - Set Builder, 6 (8e568b2ca348 modified)
>> warning: exe: absolute exe found in path: (__cmake) /usr/bin/cmake
>> Build Set: 6/rtems-net-legacy
>> config: tools/rtems-net-legacy-6.cfg
>> error: config error: rtems-bsp.cfg:104: RTEMS tools not found
>> (sparc-rtems6-gcc) found; Please check the --with-tools option or --prefix.
>> Build FAILED
>> Build Set: Time 0:00:00.012407
>> Build FAILED
>> The error information implies that '--prefix' should specify where the
>> 'sparc-rtems6-gcc' should be located, so I tried something different
>> (specifying where the build tools are located).
> The prefix is where it will be installed. Normally${prefix}/bin/ will
> contain your cross tools.
> --rtems-tools path     : Path to an install RTEMS tool set
> And your --with-rtems-bsp is just the architecture. It would need to be
> something like sparc/leon3.
> Have you built the tools? Is sparc-rtems6-gcc in your $PATH? Can you run
> hello world?
> And --host normally denotes the host os where you are building. You
> usually want --target.
> @Vijay should be able to confirm that for sure. I don't think I have built
> the legacy stack this way recently.
I agree with the suggestions above. I am able to reproduce this error with
wrong prefix. The following command works for me for a different board:
`../source-builder/sb-set-builder --prefix=$PATH_TO_DIR_WITH_BIN
--with-rtems-bsp=powerpc/mvme2700 6/rtems-net-legacy`
I have the rtems toolset installed in this prefix path.
>> prefix=$HOME/src/Toolchains/osr_rtems_6_sparc 6/rtems-net-legacy
>> error: config error: rtems-bsp.cfg:131: RTEMS BSP not found
>> (sparc-rtems6-sparc.pc); Please check the --with-rtems option or --prefix.
> You have to build RTEMS and install it.  The dot pc file has a pattern
> like this for the powerpc/psim BSP I had installed
> /home/joel/rtems-work/tools/6/bsp-install/lib/pkgconfig/powerpc-rtems6-psim.pc
> prefix to RTEMS
> configure/install: /home/joel/rtems-work/tools/6/bsp-install/
> Note that yours would be something like sparc-rtems6-leon3.pc.
+1
Build FAILED
>> Build Set: Time 0:00:00.014283
>> Build FAILED
>> What I'm guessing is that the networking build still relies on everything
>> being in the correct location, but the documentation doesn't indicate where
>> the networking repository should be put and how the networking build fits
>> in with the tools build and the application builds.  This is probably the
>> information I'm currently lacking.  Then again, I may be missing something
>> in the documentation that I erroneously overlooked.  If so, just let me
>> know.
>> The "Hello World" failure is documented in this ticket:
>> https://devel.rtems.org/ticket/4927
> OK. I dhave added Chris who I think wrote that section.
> Can you build the rtems-examples from that repository?
> --joel
>> Thanks again in advance!
>> Brett
>> *From:* Joel Sherrill <joel at rtems.org>
>> *Sent:* Tuesday, August 15, 2023 9:57 AM
>> *To:* Brett Sterling <brett.sterling at odysseysr.com>
>> *Cc:* users at rtems.org <users at rtems.org>; Vijay Kumar Banerjee <
>> vijay at rtems.org>
>> *Subject:* Re: Networking examples
>> CAUTION: This email originated from outside of the organization. Do not
>> click links or open attachments unless you recognize the sender and know
>> the content is safe.
>> I add Vijay since he has been working with this.
>> On Tue, Aug 15, 2023 at 9:27 AM Brett Sterling <
>> Hello all,
>> My goal is to integrate networking into our RTEMS solution, so I started
>> here: https://docs.rtems.org/branches/master/legacy-networking/index.html
>> <https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Fdocs.rtems.org%2Fbranches%2Fmaster%2Flegacy-networking%2Findex.html&data=05%7C01%7C%7Ca986447e0b18401e8d8108db9da85b8c%7Cd761ffacf6be45b88f6f288a59577095%7C0%7C0%7C638277118637201789%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=O7Cl3JjG1IGmeX5TzhEdb65bNPtvrK%2BF4Zzqtlw5Zhk%3D&reserved=0>
>> But, as soon as I had started, I hit a failure.  I tried the 'quick
>> start' (
>> <https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Fdocs.rtems.org%2Fbranches%2Fmaster%2Flegacy-networking%2Fquick_start.html&data=05%7C01%7C%7Ca986447e0b18401e8d8108db9da85b8c%7Cd761ffacf6be45b88f6f288a59577095%7C0%7C0%7C638277118637358041%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=gCplMFshN695pxIZnLZlIxdIjfO9mkjZXsOzmm8R45s%3D&reserved=0>),
>> but regardless of which way I tried to build, the build failed.
>> Please post about that. This shouldn't happen.
>> And Vijay has recent experience testing the legacy stack.
>> Based on the failure of the 'quick-start' for the RTEMS "Hello World"
>> example coupled with this failure, I'm starting to consider moving back to
>> an older RTEMS version (I've seen networking information for both RTEMS 4 &
>> 5), but first wanted to reach out to the user community to get input.
>> Let's see how this failed.
>> Optimally, I would like to find an RTEMS example (any version) *WITH
>> NETWORKING* that runs on either an RTEMS simulator, or on a commercially
>> available development board so that I can see networking working and then
>> evolve it into my system.
>> Do you really want the legacy stack or just a network stack?
>> Less optimally, I would like to find an RTEMS example (any version) *WITH
>> NETWORKING* that at least completely builds.
>> If no one has examples of these, I would be glad to try different things
>> to get the networking stuff building.  Especially if someone else can show
>> that they can build with networking.
>> Thanks in advance!
>> Brett
>> users mailing list
>> users at rtems.org
>> <https://usg02.safelinks.protection.office365.us/?url=http%3A%2F%2Flists.rtems.org%2Fmailman%2Flistinfo%2Fusers&data=05%7C01%7C%7Ca986447e0b18401e8d8108db9da85b8c%7Cd761ffacf6be45b88f6f288a59577095%7C0%7C0%7C638277118637358041%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=emkBfMPRDD5Ncf8xS7x%2BOB3hQwBUEpkMKEh9lK38Mx4%3D&reserved=0>
URL: <http://lists.rtems.org/pipermail/users/attachments/20230815/99993a6b/attachment-0001.htm>
