CPU Usage
mbenson at windhoverlabs.com
Sat Jan 14 02:17:55 UTC 2023
I basically just copied and renamed the existing function that prints to the console, but changed it to return a struct. I couldn’t personally give it back. I thought my customer at the time would roll it back in. Looks like that never happened. Sorry.
> On Jan 13, 2023, at 17:05, Joel Sherrill <joel at rtems.org> wrote:
> That's the right answer Karel.
> I will add that we have been open to the addition of an API to obtain this information if someone could propose one. <hint>
> This is an area where not knowing what users would like to have has been a hurdle.
>> On Fri, Jan 13, 2023 at 3:42 PM Karel Gardas <karel.gardas at centrum.cz> wrote:
>> I would guess it is, but judge yourself by going to the RTEMS source
>> code[*] and grepping for "rtems_cpu_usage".
>> Cheers,
>> Karel
>> [*] used few months old trunk here.
>> On 1/13/23 21:48, Molock, Dwaine S. (GSFC-5820) wrote:
>> > Hello,
>> > Is there a RTEMS API available to obtain the current CPU usage or
>> > anything similar to the “/proc/stat” file in Linux that can be read to
>> > obtain this information?
>> > Thanks,
>> > Dwaine
>> > _______________________________________________
>> > users mailing list
>> > users at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/users
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20230113/a213d3c4/attachment-0001.htm>
