Hello world fails
Brett Sterling
brett.sterling at odysseysr.com
Tue Jul 11 13:35:07 UTC 2023
I've been working my way through the 'Quick Start' and everything was going pretty well until https://docs.rtems.org/branches/master/user/start/app.html.
I get to the point where I'm supposed to 'configure', and I get the following:
~/src/rtems/quick-start/app/hello$ ./waf configure --rtems=$HOME/src/rtems/quick-start/rtems/6 --rtems-bsp=sparc/erc32
Setting top to : /home/bsterling/src/rtems/quick-start/app/hello
Setting out to : /home/bsterling/src/rtems/quick-start/app/hello/build
RTEMS path is not valid, "/home/bsterling/src/rtems/quick-start/rtems/6/share/rtems6" not found.
(complete log in /home/bsterling/src/rtems/quick-start/app/hello/build/config.log)
I have verified that all of the source files contain only what is described on that page.
When I look in the rtems/6/share directory, I have the following:
~/src/rtems/quick-start/rtems/6/share$ ls -l
total 32
drwxr-xr-x 3 bsterling osr 4096 Jul 10 14:39 doc
drwxr-xr-x 3 bsterling osr 4096 Jul 10 15:00 gcc-12.3.1
drwxr-xr-x 5 bsterling osr 4096 Jul 10 15:02 gdb
drwxr-xr-x 2 bsterling osr 4096 Jul 10 15:01 iconv_data
drwxr-xr-x 2 bsterling osr 4096 Jul 10 15:02 info
drwxr-xr-x 2 bsterling osr 4096 Jul 10 14:43 locale
drwxr-xr-x 5 bsterling osr 4096 Jul 10 15:00 man
drwxr-xr-x 9 bsterling osr 4096 Jul 10 15:02 rtems
I tried renaming 'rtems' to 'rtems6', but that resulted in the following errors:
Traceback (most recent call last):
File "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Scripting.py", line 119, in waf_entry_point
run_commands()
File "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Scripting.py", line 182, in run_commands
ctx=run_command(cmd_name)
File "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Scripting.py", line 173, in run_command
ctx.execute()
File "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Configure.py", line 85, in execute
super(ConfigurationContext,self).execute()
File "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Context.py", line 92, in execute
self.recurse([os.path.dirname(g_module.root_path)])
File "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Context.py", line 133, in recurse
user_function(self)
File "/home/bsterling/src/rtems/quick-start/app/hello/wscript", line 26, in configure
rtems.configure(conf, bsp_configure = bsp_configure)
File "/home/bsterling/src/rtems/quick-start/app/hello/rtems_waf/rtems.py", line 190, in configure
check_options(conf,
File "/home/bsterling/src/rtems/quick-start/app/hello/rtems_waf/rtems.py", line 496, in check_options
arch_bsps = _check_arch_bsps(rtems_bsps, rtems_config, rtems_path,
File "/home/bsterling/src/rtems/quick-start/app/hello/rtems_waf/rtems.py", line 851, in _check_arch_bsps
installed = _find_installed_arch_bsps(config, path, archs, version)
File "/home/bsterling/src/rtems/quick-start/app/hello/rtems_waf/rtems.py", line 823, in _find_installed_arch_bsps
if _arch_from_arch_bsp(f[:-3]) in archs:
File "/home/bsterling/src/rtems/quick-start/app/hello/rtems_waf/rtems.py", line 862, in _arch_from_arch_bsp
rtems_field_index = next(i for i, field in enumerate(fields) if field.startswith('rtems'))
StopIteration
Please note that I started with rtems 6 because when I tried to use the released rtems 5 'Getting Started', I couldn't get past the first few steps. That being said, I'm glad to go back to any other version if necessary, as I'm just trying to get to the point where I can work with RTEMS.
Thanks in advance for any help!
I'm using Ubuntu 22.04.2 LTS, and have followed the instructions in the 'Host Machine' setup section (as I mentioned, everything was working great up until this step). The only way I was able to get things working was to clone the git repositories. I'm on the 'master' branch.
URL: <http://lists.rtems.org/pipermail/users/attachments/20230711/c31e41c6/attachment.htm>
