Hello world fails
Joel Sherrill
joel at rtems.org
Wed Jul 12 22:14:10 UTC 2023
On Wed, Jul 12, 2023 at 9:10 AM Brett Sterling <brett.sterling at odysseysr.com>
wrote:
> Thank you for pointing out my error. My apologies - as I said, this is my
> first time working with RTEMS so I'm sorry I mis-stated.
> In the example, the "RTEMS tools suite prefix" is
> '$HOME/quick-start/rtems/6'.
> When I was running through the example, my "RTEMS tools suite prefix" is
> '$HOME/src/rtems/quick-start/rtems/6' (as shown in what I typed :-) ).
> The reason I started this thread is because I'm not the only one having
> problems with https://docs.rtems.org/branches/master/user/start/app.html -
> a co-worker was also unable to follow these instructions (because it
> appears that the 'waf' execution is looking for the wrong directory).
If the directories in the instructions are inconsistent, please file a
ticket. Have another new experience. :)
When I teach the Open Class, I use this structure:
HOME
rtems-class
tools
6
rtems, rtems-source-builder, rtems-libbsd, rtems-examples and other
source repositories at the same level
prefix building RTEMS tools and RTEMS itself is ${HOME}/rtems-class/tools/6
You usually end up adding ${HOME}/rtems-class/tools/6/bin to your PATH.
There is no required naming/paths but you do need to be consistent. There
is a place for source and a PREFIX for installing.
Confusing things more the BSP and RTEMS Tools do NOT have to use the same
PREFIX. :)
> I'm open to suggestions of things to try, but in order to clear up any
> confusion, I'm going to redo the "Quick Start" following it verbatim so
> that there is less confusion as to what problem I'm having 🙂
If verbatim from that doesn't work, then we need to figure out what's wrong
in the instructions. Hopefully my alternative version above is correct and
gives you another view of the paths/prefixes.
> Thanks to everyone for the help, and my apologies for the 'noob' errors.
> Brett
> *From:* Gedare Bloom <gedare at rtems.org>
> *Sent:* Tuesday, July 11, 2023 12:29 PM
> *To:* Brett Sterling <brett.sterling at odysseysr.com>
> *Cc:* joel at rtems.org <joel at rtems.org>; users at rtems.org <users at rtems.org>
> *Subject:* Re: Hello world fails
> On Tue, Jul 11, 2023 at 9:54 AM Brett Sterling
> <brett.sterling at odysseysr.com> wrote:
> > Thanks for the response. However, I think I need a little clarification.
> > In
> https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Fdocs.rtems.org%2Fbranches%2Fmaster%2Fuser%2Fstart%2Fapp.html&data=05%7C01%7C%7C925117adb0434c535d4108db823cc082%7Cd761ffacf6be45b88f6f288a59577095%7C0%7C0%7C638246969685266444%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=rmj7IwfhREwodmwv8WSXXcFUa3KCvXgTW5GBKZ%2Fh2ic%3D&reserved=0,
> it says:
> > ./waf configure --rtems=$HOME/quick-start/rtems/6 --rtems-bsp=sparc/erc32
> > My prefix is: '$HOME/src/rtems', so I used ' ./waf configure
> --rtems=$HOME/src/rtems/quick-start/rtems/6 --rtems-bsp=sparc/erc32'.
> If your prefix is '${HOME}/src/rtems' then your rtems should be
> '${HOME}/src/rtems'
> There is no extra magic that appends "quick-start/rtems/6" to your
> prefix during the installation. Since you chose $HOME/src/rtems as
> your prefix, then everywhere that the original prefix of
> $HOME/quick-start/rtems/6 gets used you should replace with
> $HOME/src/rtems.
> > I believe this is equivalent to what you suggested, except that you have
> '--rtems-bsps' instead of '--rtems-bsp' (I think mine is the correct
> syntax).
> > As for "pointing to the share directory', I didn't do that - that was
> the error message printed when I tried to configure.
> > I'm not sure what you mean by pointing to the wrong directories - I
> followed the web page directions specifically. However, I also admit I may
> have done something incorrectly, so if you could point to the thing I
> should change, I'm glad to do so :-)
> > Thanks again,
> > Brett
> > ________________________________
> > From: Joel Sherrill <joel at rtems.org>
> > Sent: Tuesday, July 11, 2023 9:24 AM
> > To: Brett Sterling <brett.sterling at odysseysr.com>
> > Cc: users at rtems.org <users at rtems.org>
> > Subject: Re: Hello world fails
> > CAUTION: This email originated from outside of the organization. Do not
> click links or open attachments unless you recognize the sender and know
> the content is safe.
> > On Tue, Jul 11, 2023 at 8:35 AM Brett Sterling <
> > I've been working my way through the 'Quick Start' and everything was
> going pretty well until
> > I get to the point where I'm supposed to 'configure', and I get the
> following:
> > ~/src/rtems/quick-start/app/hello$ ./waf configure
> > Setting top to :
> /home/bsterling/src/rtems/quick-start/app/hello
> > Setting out to :
> /home/bsterling/src/rtems/quick-start/app/hello/build
> > RTEMS path is not valid,
> "/home/bsterling/src/rtems/quick-start/rtems/6/share/rtems6" not found.
> > (complete log in
> /home/bsterling/src/rtems/quick-start/app/hello/build/config.log)
> > I have this in my handy scripts for building rtems-examples:
> > CPU=powerpc
> > BSP=psim
> > ./waf configure --rtems=${HOME}/rtems-work/tools/6/bsp-install \
> > --rtems-tools=${HOME}/rtems-work/tools/6 \
> > --rtems-bsps=${CPU}/${BSP}
> > That --rtems points to the --prefix directory you used when you built
> and installed RTEMS.
> > This is from my install:
> > $ pwd
> > /home/joel/rtems-work/tools/6/bsp-install/sparc-rtems6/leon3
> > $ ls
> > lib make Makefile.inc
> > --rtems-tools directory should have a bin/TARGET-gcc under it.
> > --rtems-bsps looks OK
> > I think you have just pointed to the wrong directories. It should be
> similar to
> > how I build rtems-examples.
> > --joel
> > I have verified that all of the source files contain only what is
> described on that page.
> > When I look in the rtems/6/share directory, I have the following:
> > ~/src/rtems/quick-start/rtems/6/share$ ls -l
> > total 32
> > drwxr-xr-x 3 bsterling osr 4096 Jul 10 14:39 doc
> > drwxr-xr-x 3 bsterling osr 4096 Jul 10 15:00 gcc-12.3.1
> > drwxr-xr-x 5 bsterling osr 4096 Jul 10 15:02 gdb
> > drwxr-xr-x 2 bsterling osr 4096 Jul 10 15:01 iconv_data
> > drwxr-xr-x 2 bsterling osr 4096 Jul 10 15:02 info
> > drwxr-xr-x 2 bsterling osr 4096 Jul 10 14:43 locale
> > drwxr-xr-x 5 bsterling osr 4096 Jul 10 15:00 man
> > drwxr-xr-x 9 bsterling osr 4096 Jul 10 15:02 rtems
> > Normally you don't point all the way down to share directory
> > I tried renaming 'rtems' to 'rtems6', but that resulted in the following
> errors:
> > Setting top to :
> > Setting out to :
> > Traceback (most recent call last):
> > File
> "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Scripting.py",
> line 119, in waf_entry_point
> > run_commands()
> > File
> line 182, in run_commands
> > ctx=run_command(cmd_name)
> > File
> line 173, in run_command
> > ctx.execute()
> > File
> "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Configure.py",
> line 85, in execute
> > super(ConfigurationContext,self).execute()
> > File
> "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Context.py",
> line 92, in execute
> > self.recurse([os.path.dirname(g_module.root_path)])
> > File
> line 133, in recurse
> > user_function(self)
> > File "/home/bsterling/src/rtems/quick-start/app/hello/wscript", line
> 26, in configure
> > rtems.configure(conf, bsp_configure = bsp_configure)
> > File
> "/home/bsterling/src/rtems/quick-start/app/hello/rtems_waf/rtems.py", line
> 190, in configure
> > check_options(conf,
> > File
> 496, in check_options
> > arch_bsps = _check_arch_bsps(rtems_bsps, rtems_config, rtems_path,
> > File
> 851, in _check_arch_bsps
> > installed = _find_installed_arch_bsps(config, path, archs, version)
> > File
> 823, in _find_installed_arch_bsps
> > if _arch_from_arch_bsp(f[:-3]) in archs:
> > File
> 862, in _arch_from_arch_bsp
> > rtems_field_index = next(i for i, field in enumerate(fields) if
> field.startswith('rtems'))
> > StopIteration
> > Please note that I started with rtems 6 because when I tried to use the
> released rtems 5 'Getting Started', I couldn't get past the first few
> steps. That being said, I'm glad to go back to any other version if
> necessary, as I'm just trying to get to the point where I can work with
> RTEMS.
> > Thanks in advance for any help!
> > I'm using Ubuntu 22.04.2 LTS, and have followed the instructions in the
> 'Host Machine' setup section (as I mentioned, everything was working great
> up until this step). The only way I was able to get things working was to
> clone the git repositories. I'm on the 'master' branch.
> > users mailing list
> > users at rtems.org
> https://usg02.safelinks.protection.office365.us/?url=http%3A%2F%2Flists.rtems.org%2Fmailman%2Flistinfo%2Fusers&data=05%7C01%7C%7C925117adb0434c535d4108db823cc082%7Cd761ffacf6be45b88f6f288a59577095%7C0%7C0%7C638246969685266444%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=Va5M9b%2BjcpRnlfqEVSfDMH%2FhbVAstaeRD2t74nFeVYM%3D&reserved=0
> > users mailing list
> > users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20230712/5ec83b6f/attachment-0001.htm>
