Path issue Filesystem mounted with NFS(v4?)
Heinz Junkes
junkes at fhi-berlin.mpg.de
Thu Jul 13 12:29:53 UTC 2023
I see exact the same behavior as in the ticket 4273.
Thanks for looking into….
Heinz
> On 13. Jul 2023, at 09:33, Chris Johns <chrisj at rtems.org> wrote:
> On 11/7/2023 7:32 pm, Heinz Junkes wrote:
>> Hallo,
>> I am observing a strange problem with an NFS(v4) mounted filesystem and path usage.
>> I have mounted a filesystem via NFSv4 (/Volumes):
>> loc = 0x00820a20
>> node_access = 0x007c2378, node_access_2 = 0x00000000, handler = 0x005c3474
>> type = nfs, mounted, read-write, target = /Volumes, dev = 141.14.131.192, root loc = 0x00913468
>> In the shell I can change there into a directory:
>> SHLL [/] # cd /Volumes/Epics/LogDir/Database
>> SHLL [/Volumes/Epics/LogDir/Database] # pwd
>> SHLL [/Volumes/Epics/LogDir/Database] # ls -l
>> total 20
>> -rw-r--r-- 1 1001 1001 10694 Mar 23 2021 iocvmeIOC3.dbhcr
>> -rw-r--r-- 1 1001 1001 0 Mar 23 2021 iocvmeIOC3.dbior
>> -rw-r--r-- 1 1001 1001 5451 Mar 23 2021 iocvmeIOC3.dbl
>> I can now copy a file to here:
>> SHLL [/Volumes/Epics/LogDir/Database] # cp /etc/passwd .
>> total 24
>> -rwxrwxrwt 1 65534 65534 14 Jul 11 11:28 passwd
>> SHLL [/Volumes/Epics/LogDir/Database] # cat passwd
>> root::0:0::::
>> SHLL [/Volumes/Epics/LogDir/Database] # rm passwd
>> total 20
>> If I now specify the path instead of “.”, the file appears one dir up ????
>> SHLL [/Volumes/Epics/LogDir/Database] # cp /etc/passwd /Volumes/Epics/LogDir/Database/passwd
>> total 20
>> SHLL [/Volumes/Epics/LogDir/Database] # ls -l ..
>> total 40
>> drwxrwxrwx 2 65534 65534 4096 Jul 11 11:29 Database
>> -rwxrwxrwt 1 65534 65534 9980 Jul 10 11:52 iocvmeIOC1.dbhcr
>> -rwsrwsrwt 1 65534 65534 0 Jul 10 11:52 iocvmeIOC1.dbior
>> -rwxrwxrwt 1 65534 65534 4713 Jul 10 11:59 iocvmeIOC1.dbl
>> drwxrwxrwx 3 65534 65534 4096 Mar 23 2021 log
>> -rwxrwxrwt 1 65534 65534 14 Jul 11 11:30 passwd
>> SHLL [/Volumes/Epics/LogDir/Database] # cat ../passwd
>> root::0:0::::
>> Any Idea what might go wrong? Any fix?
> Is it related to https://devel.rtems.org/ticket/4723?
> I was planning to look into this in the next couple of weeks.
> Chris
