waf breakage was Re: Hello world fails
Joel Sherrill
joel at rtems.org
Thu Jul 13 20:05:57 UTC 2023
Chris... added you so you can see what's going on.
Brett was kind enough to file this ticket for you. :)
https://devel.rtems.org/ticket/4927
--joel
On Thu, Jul 13, 2023 at 8:29 AM Ben Leone <bleone at ast-science.com> wrote:
> I ran into this issue as well with the hello world and building other
> applications using waf when starting a new project. It looks like the cause
> of the issue was changes made to rtems_waf in this commit here:
> https://git.rtems.org/rtems_waf/commit/?id=c721249146a510a6746b37e7d731cb1467f91f48
> For a quick fix, I just reverted the changes back to what they were before
> and the hello world and building applications seemed to work again. Still
> new to RTEMS myself but for long term, this probably isn't the correct
> solution so if someone has a detailed way to use the bsp_configure function
> in the wscript to avoid causing the arch_bsp iteration issue, that would be
> helpful!
> *Ben*
> *From:* users <users-bounces at rtems.org> on behalf of Joel Sherrill <
> joel at rtems.org>
> *Sent:* Wednesday, July 12, 2023 6:14 PM
> *To:* Brett Sterling <brett.sterling at odysseysr.com>
> *Cc:* users at rtems.org <users at rtems.org>
> *Subject:* Re: Hello world fails
> You don't often get email from joel at rtems.org. Learn why this is important
> <https://aka.ms/LearnAboutSenderIdentification>
> On Wed, Jul 12, 2023 at 9:10 AM Brett Sterling <
> brett.sterling at odysseysr.com> wrote:
> Thank you for pointing out my error. My apologies - as I said, this is my
> first time working with RTEMS so I'm sorry I mis-stated.
> In the example, the "RTEMS tools suite prefix" is
> '$HOME/quick-start/rtems/6'.
> When I was running through the example, my "RTEMS tools suite prefix" is
> '$HOME/src/rtems/quick-start/rtems/6' (as shown in what I typed :-) ).
> The reason I started this thread is because I'm not the only one having
> problems with https://docs.rtems.org/branches/master/user/start/app.html -
> a co-worker was also unable to follow these instructions (because it
> appears that the 'waf' execution is looking for the wrong directory).
> If the directories in the instructions are inconsistent, please file a
> ticket. Have another new experience. :)
> When I teach the Open Class, I use this structure:
> HOME
> rtems-class
> tools
> 6
> rtems, rtems-source-builder, rtems-libbsd, rtems-examples and other
> source repositories at the same level
> prefix building RTEMS tools and RTEMS itself is ${HOME}/rtems-class/tools/6
> You usually end up adding ${HOME}/rtems-class/tools/6/bin to your PATH.
> There is no required naming/paths but you do need to be consistent. There
> is a place for source and a PREFIX for installing.
> Confusing things more the BSP and RTEMS Tools do NOT have to use the same
> PREFIX. :)
> I'm open to suggestions of things to try, but in order to clear up any
> confusion, I'm going to redo the "Quick Start" following it verbatim so
> that there is less confusion as to what problem I'm having 🙂
> If verbatim from that doesn't work, then we need to figure out what's
> wrong in the instructions. Hopefully my alternative version above is
> correct and gives you another view of the paths/prefixes.
> Thanks to everyone for the help, and my apologies for the 'noob' errors.
> Brett
> *From:* Gedare Bloom <gedare at rtems.org>
> *Sent:* Tuesday, July 11, 2023 12:29 PM
> *Cc:* joel at rtems.org <joel at rtems.org>; users at rtems.org <users at rtems.org>
> On Tue, Jul 11, 2023 at 9:54 AM Brett Sterling
> <brett.sterling at odysseysr.com> wrote:
> > Thanks for the response. However, I think I need a little clarification.
> > In
> https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Fdocs.rtems.org%2Fbranches%2Fmaster%2Fuser%2Fstart%2Fapp.html&data=05%7C01%7C%7C925117adb0434c535d4108db823cc082%7Cd761ffacf6be45b88f6f288a59577095%7C0%7C0%7C638246969685266444%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=rmj7IwfhREwodmwv8WSXXcFUa3KCvXgTW5GBKZ%2Fh2ic%3D&reserved=0
> <https://docs.rtems.org/branches/master/user/start/app.html>, it says:
> > ./waf configure --rtems=$HOME/quick-start/rtems/6 --rtems-bsp=sparc/erc32
> > My prefix is: '$HOME/src/rtems', so I used ' ./waf configure
> --rtems=$HOME/src/rtems/quick-start/rtems/6 --rtems-bsp=sparc/erc32'.
> If your prefix is '${HOME}/src/rtems' then your rtems should be
> '${HOME}/src/rtems'
> There is no extra magic that appends "quick-start/rtems/6" to your
> prefix during the installation. Since you chose $HOME/src/rtems as
> your prefix, then everywhere that the original prefix of
> $HOME/quick-start/rtems/6 gets used you should replace with
> $HOME/src/rtems.
> > I believe this is equivalent to what you suggested, except that you have
> '--rtems-bsps' instead of '--rtems-bsp' (I think mine is the correct
> syntax).
> > As for "pointing to the share directory', I didn't do that - that was
> the error message printed when I tried to configure.
> > I'm not sure what you mean by pointing to the wrong directories - I
> followed the web page directions specifically. However, I also admit I may
> have done something incorrectly, so if you could point to the thing I
> should change, I'm glad to do so :-)
> > Thanks again,
> > Brett
> > ________________________________
> > From: Joel Sherrill <joel at rtems.org>
> > Sent: Tuesday, July 11, 2023 9:24 AM
> > To: Brett Sterling <brett.sterling at odysseysr.com>
> > Cc: users at rtems.org <users at rtems.org>
> > Subject: Re: Hello world fails
> > CAUTION: This email originated from outside of the organization. Do not
> click links or open attachments unless you recognize the sender and know
> the content is safe.
> > On Tue, Jul 11, 2023 at 8:35 AM Brett Sterling <
> > I've been working my way through the 'Quick Start' and everything was
> going pretty well until
> <https://docs.rtems.org/branches/master/user/start/app.html>.
> > I get to the point where I'm supposed to 'configure', and I get the
> following:
> > ~/src/rtems/quick-start/app/hello$ ./waf configure
> > Setting top to :
> /home/bsterling/src/rtems/quick-start/app/hello
> > Setting out to :
> /home/bsterling/src/rtems/quick-start/app/hello/build
> > RTEMS path is not valid,
> "/home/bsterling/src/rtems/quick-start/rtems/6/share/rtems6" not found.
> > (complete log in
> /home/bsterling/src/rtems/quick-start/app/hello/build/config.log)
> > I have this in my handy scripts for building rtems-examples:
> > CPU=powerpc
> > BSP=psim
> > ./waf configure --rtems=${HOME}/rtems-work/tools/6/bsp-install \
> > --rtems-tools=${HOME}/rtems-work/tools/6 \
> > --rtems-bsps=${CPU}/${BSP}
> > That --rtems points to the --prefix directory you used when you built
> and installed RTEMS.
> > This is from my install:
> > $ pwd
> > /home/joel/rtems-work/tools/6/bsp-install/sparc-rtems6/leon3
> > $ ls
> > lib make Makefile.inc
> > --rtems-tools directory should have a bin/TARGET-gcc under it.
> > --rtems-bsps looks OK
> > I think you have just pointed to the wrong directories. It should be
> similar to
> > how I build rtems-examples.
> > --joel
> > I have verified that all of the source files contain only what is
> described on that page.
> > When I look in the rtems/6/share directory, I have the following:
> > ~/src/rtems/quick-start/rtems/6/share$ ls -l
> > total 32
> > drwxr-xr-x 3 bsterling osr 4096 Jul 10 14:39 doc
> > drwxr-xr-x 3 bsterling osr 4096 Jul 10 15:00 gcc-12.3.1
> > drwxr-xr-x 5 bsterling osr 4096 Jul 10 15:02 gdb
> > drwxr-xr-x 2 bsterling osr 4096 Jul 10 15:01 iconv_data
> > drwxr-xr-x 2 bsterling osr 4096 Jul 10 15:02 info
> > drwxr-xr-x 2 bsterling osr 4096 Jul 10 14:43 locale
> > drwxr-xr-x 5 bsterling osr 4096 Jul 10 15:00 man
> > drwxr-xr-x 9 bsterling osr 4096 Jul 10 15:02 rtems
> > Normally you don't point all the way down to share directory
> > I tried renaming 'rtems' to 'rtems6', but that resulted in the following
> errors:
> > Setting top to :
> > Setting out to :
> > Traceback (most recent call last):
> > File
> "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Scripting.py",
> line 119, in waf_entry_point
> > run_commands()
> > File
> line 182, in run_commands
> > ctx=run_command(cmd_name)
> > File
> line 173, in run_command
> > ctx.execute()
> > File
> "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Configure.py",
> line 85, in execute
> > super(ConfigurationContext,self).execute()
> > File
> "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Context.py",
> line 92, in execute
> > self.recurse([os.path.dirname(g_module.root_path)])
> > File
> line 133, in recurse
> > user_function(self)
> > File "/home/bsterling/src/rtems/quick-start/app/hello/wscript", line
> 26, in configure
> > rtems.configure(conf, bsp_configure = bsp_configure)
> > File
> "/home/bsterling/src/rtems/quick-start/app/hello/rtems_waf/rtems.py", line
> 190, in configure
> > check_options(conf,
> > File
> 496, in check_options
> > arch_bsps = _check_arch_bsps(rtems_bsps, rtems_config, rtems_path,
> > File
> 851, in _check_arch_bsps
> > installed = _find_installed_arch_bsps(config, path, archs, version)
> > File
> 823, in _find_installed_arch_bsps
> > if _arch_from_arch_bsp(f[:-3]) in archs:
> > File
> 862, in _arch_from_arch_bsp
> > rtems_field_index = next(i for i, field in enumerate(fields) if
> field.startswith('rtems'))
> > StopIteration
> > Please note that I started with rtems 6 because when I tried to use the
> released rtems 5 'Getting Started', I couldn't get past the first few
> steps. That being said, I'm glad to go back to any other version if
> necessary, as I'm just trying to get to the point where I can work with
> RTEMS.
> > Thanks in advance for any help!
> > I'm using Ubuntu 22.04.2 LTS, and have followed the instructions in the
> 'Host Machine' setup section (as I mentioned, everything was working great
> up until this step). The only way I was able to get things working was to
> clone the git repositories. I'm on the 'master' branch.
> > users mailing list
> > users at rtems.org
> https://usg02.safelinks.protection.office365.us/?url=http%3A%2F%2Flists.rtems.org%2Fmailman%2Flistinfo%2Fusers&data=05%7C01%7C%7C925117adb0434c535d4108db823cc082%7Cd761ffacf6be45b88f6f288a59577095%7C0%7C0%7C638246969685266444%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=Va5M9b%2BjcpRnlfqEVSfDMH%2FhbVAstaeRD2t74nFeVYM%3D&reserved=0
> <http://lists.rtems.org/mailman/listinfo/users>
> > users mailing list
> > users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20230713/a43dddd0/attachment-0001.htm>
