build failed
Siddons, David siddons at bnl.gov
Mon Jul 24 22:00:03 UTC 2023
Hi Frank,
  I switched to 6, and started working through the quick-start recipe. All went well until I tried to build the hello app:
peter at peter-HP:~/quick-start/app/hello$ ./waf configure --rtems=$HOME/quick-start/rtems/6 --rtems-bsp=arm/xilinx_zynq_zc702
Setting top to                           : /home/peter/quick-start/app/hello
Setting out to                           : /home/peter/quick-start/app/hello/build
Traceback (most recent call last):
  File "/home/peter/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Scripting.py", line 119, in waf_entry_point
    run_commands()
  File "/home/peter/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Scripting.py", line 182, in run_commands
    ctx=run_command(cmd_name)
  File "/home/peter/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Scripting.py", line 173, in run_command
    ctx.execute()
  File "/home/peter/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Configure.py", line 85, in execute
    super(ConfigurationContext,self).execute()
  File "/home/peter/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Context.py", line 92, in execute
    self.recurse([os.path.dirname(g_module.root_path)])
  File "/home/peter/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Context.py", line 133, in recurse
    user_function(self)
  File "/home/peter/quick-start/app/hello/wscript", line 26, in configure
    rtems.configure(conf, bsp_configure = bsp_configure)
  File "/home/peter/quick-start/app/hello/rtems_waf/rtems.py", line 190, in configure
    check_options(conf,
  File "/home/peter/quick-start/app/hello/rtems_waf/rtems.py", line 496, in check_options
    arch_bsps = _check_arch_bsps(rtems_bsps, rtems_config, rtems_path,
  File "/home/peter/quick-start/app/hello/rtems_waf/rtems.py", line 851, in _check_arch_bsps
    installed = _find_installed_arch_bsps(config, path, archs, version)
  File "/home/peter/quick-start/app/hello/rtems_waf/rtems.py", line 823, in _find_installed_arch_bsps
    if _arch_from_arch_bsp(f[:-3]) in archs:
  File "/home/peter/quick-start/app/hello/rtems_waf/rtems.py", line 862, in _arch_from_arch_bsp
    rtems_field_index = next(i for i, field in enumerate(fields) if field.startswith('rtems'))
StopIteration
Not sure what I did wrong.
I have attached the files I generated for the app
Pete.
________________________________
Sent: Saturday, July 22, 2023 9:46 AM
To: Frank Kühndel <frank.kuehndel at embedded-brains.de>; rtems-users at rtems.org <users at rtems.org>
Cc: Chris Johns <chrisj at rtems.org>
Subject: Re: build failed
Hi Frank,
THanks for responding. The output is:
peter at peter-HP:~/quick-start/src/rsb/rtems$ /usr/bin/python3-config --ldflags
-L/usr/lib/python3.10/config-3.10-x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu  -lcrypt -ldl  -lm -lm
peter at peter-HP:~/quick-start/src/rsb/rtems$ /usr/bin/python3-config --ldflags --embed
-L/usr/lib/python3.10/config-3.10-x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -lpython3.10 -lcrypt -ldl  -lm -lm
So I guess you are right.
I am starting pretty much from scratch, so I chose 5 as the most recent released version. Would I be better off switching to 6?
Pete.
From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
Sent: Saturday, July 22, 2023 2:25 AM
To: Siddons, David <siddons at bnl.gov>; rtems-users at rtems.org <users at rtems.org>
Hi Pete,
this looks like bug https://urldefense.com/v3/__https://devel.rtems.org/ticket/4631__;!!P4SdNyxKAPE!AC1ZvL2wAQCQ7iQRpVCcyO-eP2P-xD3OJxSxyVv2nG86THYXD4jA0AyeoYw8zCGRzOtFZCoiACmEEpE5mKYzHi9gMHKQBlqzPA$
It was fixed for RTEMS 6 but may be not for RTEMS 5?
I am adding Chris Johns to CC as he fixed this bug in RTEMS 6.
If it is this bug, the cause is that on newer OS the command
`/usr/bin/python3-config --ldflags` needs an additional `--embed` option
while on older OS it does not even understand it. I am not using RTEMS 5
so maybe someone else can provide you advice.
Pete, which version of Python are you using?
What is the output of the following commands on your machine?
Greetings
Frank
On 7/21/23 18:00, Siddons, David wrote:
> Subject:
> build failed
> From:
> "Siddons, David" <siddons at bnl.gov>
> Date:
> 7/21/23, 18:00
> To:
> "rtems-users at rtems.org" <users at rtems.org>
> I'm following the quick-start guide, substituting arm for sparc, and at this step:
> https://urldefense.com/v3/__https://docs.rtems.org/branches/master/user/start/tools.html__;!!P4SdNyxKAPE!AC1ZvL2wAQCQ7iQRpVCcyO-eP2P-xD3OJxSxyVv2nG86THYXD4jA0AyeoYw8zCGRzOtFZCoiACmEEpE5mKYzHi9gMHIWgY02Jw$
> cd $HOME/quick-start/src/rsb/rtems
> ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5 5/rtems-arm
> Eventually I get this:
> config: tools/rtems-gdb-9.1-1.cfg
> error: shell macro failed: /home/peter/quick-start/src/rsb/source-builder/sb/rtems-build-dep -c gcc  -l : 2: error: no library (-l) provided
> Build FAILED
> Build Set: Time 0:00:23.976088
> Build FAILED
> What did I do wrong?
> Pete.
embedded brains GmbH & Co. KG
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
phone:  +49-89-18 94 741 - 23
mobile: +49-176-15 22 06 - 11
Registernummer: HRA 117265
https://urldefense.com/v3/__https://embedded-brains.de/datenschutzerklaerung/__;!!P4SdNyxKAPE!AC1ZvL2wAQCQ7iQRpVCcyO-eP2P-xD3OJxSxyVv2nG86THYXD4jA0AyeoYw8zCGRzOtFZCoiACmEEpE5mKYzHi9gMHL-lRS8Ew$
URL: <http://lists.rtems.org/pipermail/users/attachments/20230724/0ccb5e11/attachment-0001.htm>
Desc: wscript
URL: <http://lists.rtems.org/pipermail/users/attachments/20230724/0ccb5e11/attachment-0001.obj>
Type: text/x-csrc
Desc: init.c
URL: <http://lists.rtems.org/pipermail/users/attachments/20230724/0ccb5e11/attachment-0002.bin>
Type: text/x-csrc
Desc: hello.c
URL: <http://lists.rtems.org/pipermail/users/attachments/20230724/0ccb5e11/attachment-0003.bin>
