Problem using sphinx to build documentation
Andrew.Butterfield at scss.tcd.ie
Tue Jun 6 17:22:32 UTC 2023
> Which sphinx version got installed?
It think its 7.0.1
I tried to re-install it and saw
ab-rtems-docs% . ./sphinx/bin/activate
(sphinx) ab-rtems-docs% pip3 install sphinx
Requirement already satisfied: sphinx in ./sphinx/lib/python3.10/site-packages (7.0.1)
Requirement already satisfied: sphinxcontrib-qthelp in ./sphinx/lib/python3.10/site-packages (from sphinx) (1.0.3)
Requirement already satisfied: sphinxcontrib-applehelp in ./sphinx/lib/python3.10/site-packages (from sphinx) (1.0.4)
Andrew
Andrew Butterfield Tel: +353-1-896-2517 Fax: +353-1-677-2204
Lero at TCD, Head of Software Foundations & Verification Research Group
School of Computer Science and Statistics,
Room G.39, O'Reilly Institute, Trinity College, University of Dublin
http://www.scss.tcd.ie/Andrew.Butterfield/
Reply to: "joel at rtems.org" <joel at rtems.org>
Date: Tuesday 6 June 2023 at 17:51
To: "Andrew.Butterfield at scss.tcd.ie" <Andrew.Butterfield at scss.tcd.ie>
Cc: "users at rtems.org" <users at rtems.org>
Subject: Re: Problem using sphinx to build documentation
On Tue, Jun 6, 2023 at 4:11 AM Andrew.Butterfield at scss.tcd.ie<mailto:Andrew.Butterfield at scss.tcd.ie> <Andrew.Butterfield at scss.tcd.ie<mailto:Andrew.Butterfield at scss.tcd.ie>> wrote:
I am trying to install sphinx on an Apple Silicon OSX machine.
I've already done this successfully on a similar machine.
This time, after following steps in the rtems-docs README.txt,
I do ./waf , it does some stuff and then:
[ 7/10] Compiling common/_static/favicon.ico
[ 8/10] Compiling common/_static/my-styles.css
[ 9/10] Compiling common/_static/logo.png
[10/10] Compiling common/_static/style.css
Theme error:
An error happened in rendering the page bld/index.
Reason: UndefinedError("'style' is undefined")
I have not seen this error before - any thoughts?
I'm using pip 22.2.1 and Python 3.10.6
Regards, Andrew
http://www.scss.tcd.ie/Andrew.Butterfield/ <http://www.scss.tcd.ie/Andrew.Butterfield/>
users mailing list
users at rtems.org<mailto:users at rtems.org>
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20230606/3bfd442c/attachment-0001.htm>
