Problem using sphinx to build documentation
Andrew.Butterfield at scss.tcd.ie
Wed Jun 7 12:07:12 UTC 2023
Hello Frank,
I installed 6.2.1 and it works fine - thanks!
Andrew
Andrew Butterfield Tel: +353-1-896-2517 Fax: +353-1-677-2204
Lero at TCD, Head of Software Foundations & Verification Research Group
School of Computer Science and Statistics,
Room G.39, O'Reilly Institute, Trinity College, University of Dublin
http://www.scss.tcd.ie/Andrew.Butterfield/ <http://www.scss.tcd.ie/Andrew.Butterfield/>
On 06/06/2023, 22:47, "Frank Kühndel" <frank.kuehndel at embedded-brains.de <mailto:frank.kuehndel at embedded-brains.de>> wrote:
Hello Andrew,
I run into the same error message just today (albeit in a different
context). The Problem seems to be Sphinx 7. For me Sphinx 6.2.1 and
5.3.0 worked.
Greetings
Frank
On 6/6/23 19:22, Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie> wrote:
> Subject:
> Re: Problem using sphinx to build documentation
> From:
> "Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>" <Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>>
> Date:
> 6/6/23, 19:22
> To:
> "joel at rtems.org <mailto:joel at rtems.org>" <joel at rtems.org <mailto:joel at rtems.org>>, "Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>"
> CC:
> "users at rtems.org <mailto:users at rtems.org>" <users at rtems.org <mailto:users at rtems.org>>
>> Which sphinx version got installed?
> It think its 7.0.1
> I tried to re-install it and saw
> ab-rtems-docs% . ./sphinx/bin/activate
> (sphinx) ab-rtems-docs% pip3 install sphinx
> Requirement already satisfied: sphinx in ./sphinx/lib/python3.10/site-packages (7.0.1)
> Requirement already satisfied: sphinxcontrib-qthelp in ./sphinx/lib/python3.10/site-packages (from sphinx) (1.0.3)
> Requirement already satisfied: sphinxcontrib-applehelp in ./sphinx/lib/python3.10/site-packages (from sphinx) (1.0.4)
> Andrew
> From: Joel Sherrill<joel at rtems.org <mailto:joel at rtems.org>>
> Reply to:"joel at rtems.org <mailto:joel at rtems.org>" <joel at rtems.org <mailto:joel at rtems.org>>
> Date: Tuesday 6 June 2023 at 17:51
> To:"Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>" <Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>>
> Cc:"users at rtems.org <mailto:users at rtems.org>" <users at rtems.org <mailto:users at rtems.org>>
> Subject: Re: Problem using sphinx to build documentation
> On Tue, Jun 6, 2023 at 4:11 AMAndrew.Butterfield at scss.tcd.ie <mailto:AMAndrew.Butterfield at scss.tcd.ie><mailto:Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>> <Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie><mailto:Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>>> wrote:
> I am trying to install sphinx on an Apple Silicon OSX machine.
> I've already done this successfully on a similar machine.
> This time, after following steps in the rtems-docs README.txt,
> I do ./waf , it does some stuff and then:
> [ 7/10] Compiling common/_static/favicon.ico
> [ 8/10] Compiling common/_static/my-styles.css
> [ 9/10] Compiling common/_static/logo.png
> [10/10] Compiling common/_static/style.css
> Theme error:
> An error happened in rendering the page bld/index.
> Reason: UndefinedError("'style' is undefined")
> I have not seen this error before - any thoughts?
> I'm using pip 22.2.1 and Python 3.10.6
> Regards, Andrew
> http://www.scss.tcd.ie/Andrew.Butterfield/ <http://www.scss.tcd.ie/Andrew.Butterfield/> <http://www.scss.tcd.ie/Andrew.Butterfield/ <http://www.scss.tcd.ie/Andrew.Butterfield/>>
> users mailing list
> users at rtems.org <mailto:users at rtems.org><mailto:users at rtems.org <mailto:users at rtems.org>>
> http://lists.rtems.org/mailman/listinfo/users <http://lists.rtems.org/mailman/listinfo/users>
> users mailing list
embedded brains GmbH & Co. KG
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de <mailto:frank.kuehndel at embedded-brains.de>
phone: +49-89-18 94 741 - 23
mobile: +49-176-15 22 06 - 11
Registernummer: HRA 117265
https://embedded-brains.de/datenschutzerklaerung/ <https://embedded-brains.de/datenschutzerklaerung/>
