[EXTERNAL] Re: Error using rtems network legacy on MVME3100
Zainab Olalekan zolaleka at uccs.edu
Fri Jun 23 20:22:45 UTC 2023
Increasing the size of the allocated memory worked. Thank you!
On Jun 23, 2023 08:20, Joel Sherrill <joel at rtems.org> wrote:
Hi
The message "sec1: (tsec ethernet) Your application has not enough mbuf clusters configured for this driver." would normally indicate that you don't have enough mbuf memory configured. See
https://git.rtems.org/network-demos/tree/networkconfig-mpc8313erdb.h
around line 88 for the parameters you likely need to increase.
If there is a minimum, it is in the network driver itself somewhere. Should be under ./bsps/powerpc/mvme3100/
If this is a GigE interface, it is sometimes surprising how much buffering you need.
--joel
On Thu, Jun 22, 2023 at 4:21 PM Zainab Olalekan <zolaleka at uccs.edu<mailto:zolaleka at uccs.edu>> wrote:
Hi everyone,
I am having issues running rtems network legacy on the MVME3100 board. The configuration setup and output are below.  Could you advise on how to resolve this problem? Thank you.
NET_CFG_IFACE =tse1
NET_CFG_BOOT_PROT = dhcp
NET_CFG_SELF_IP = xx.xx.xx.xx
NET_CFG_NETMASK = 255.xx.xx.xx
NET_CFG_MAC_ADDR = xx:xx:xx:xx:xx:xx
NET_CFG_GATEWAY_IP = 0.0.0.0
NET_CFG_DOMAINNAME = localnet
Welcome to rtems-6.0.0 (PowerPC/Generic (no FPU)/mvme3100)
BSP: mvme3100, CVS Release ($Name$)
CPU 0x8020 - rev 0x20
Additionnal boot options are H
Initial system stack at 117070
Going to start PCI buses scanning and initialization
Board Type: MVME3100-1152 (S/N E1726C0)
External (=PCI Bus) Clock Freq   :   66666666 Hz
Core Complex Bus (CCB) Clock Freq:  333333330 Hz
CPU Clock Freq:                     133333332 Hz
Ethernet 0                  EC:9E:CD:19:B3:53
Ethernet 1                  EC:9E:CD:19:B3:54
Ethernet 2                  EC:9E:CD:19:B3:55
Number of PCI buses found is : 2
BUS:SLOT:FUN  VENDOR-DEV_ID: COMMAND STATUS BASE_ADDR0 BASE_ADDR1 IRQ_PIN -> IRQ_LINE
  0:0x00:0    0x1057-0x0008:  0x0006 0x20b0 0x80000000 0x00000000       0 ->   0 (=0x00)
  0:0x11:0    0x10e3-0x0148:  0x0146 0x02b0 0x80100004 0x00000000       1 ->   0 (=0x00)
  0:0x12:0    0x10b5-0x6520:  0x0147 0x02b0 0x00000000 0x00000000       0 ->   0 (=0x00)
  0:0x14:0    0x1095-0x3124:  0x01c7 0x02b0 0x80300004 0x00000000       1 ->   2 (=0x02)
Memory:                             268435456 bytes
Cleared PCI errors: pci_stat was 0x20b0
OpenPIC Version 1.2 (1 CPUs and 56 IRQ sources) at 0x3775135744
OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 0
OpenPIC timer frequency is 41666666 Hz
MSR is 0x00001000, TCR 0x04000000
Exit from bspstart
Tundra Tsi148 PCI-VME bridge detected at 0x80100000, IRQ 0
Tsi148 Outbound Ports:
Port  VME-Addr   Size       PCI-Adrs   Mode:
0:    0x20000000 0x0e000000 0xc0000000 A32, SUP, D32, SCT
1:    0x00000000 0x00ff0000 0xcf000000 A24, SUP, D32, SCT
2:    0x00000000 0x00010000 0xcfff0000 A16, SUP, D32, SCT
7:    0x00000000 0x01000000 0xce000000 CSR, SUP, D32, SCT
Tsi148 Inbound Ports:
0:    0xc0000000 0x10000000 0x00000000 A32, PGM, DAT, SUP, USR, MBLT, BLT
vmeTsi148 IRQ manager: looking for registers on VME...
Trying to find CSR on VME...
vmeTsi148 - IRQ manager using VME CSR to flush FIFO
libi2c: Claiming driver slot failed (rtems status code 5)
Initializing I2C library failed
Registering /dev/console as minor 0 (==/dev/ttyS0)
*** BEGIN OF TEST TELNETD 2 ***
*** TEST VERSION: 6.0.0.b2967081e5daa673141d714a2e53280898dce566
*** TEST STATE: EXPECTED_PASS
*** TEST BUILD: RTEMS_POSIX_API
*** TEST TOOLS: 12.2.1 20230425 (RTEMS 6, RSB 3c8c2ce38a8fe0a622f88fb3422d1f8fa609609b, Newlib 9ae9eef)
tsec1: (tsec ethernet) Your application has not enough mbuf clusters
Can't bring tse1 up: No such device or address
 an't set default route: Network is
 unr[e aRchTaEblMe
c./.S. /stehsutsuittdeso/wtelnent d02]/init.
 : 6R3T rv E=M= 0S
 version: 6.0.0.b2967081e5daa673141d714a2e53280898dce566
RTEMS tools: 12.2.1 20230425 (RTEMS 6, RSB 3c8c2ce38a8fe0a622f88fb3422d1f8fa609609b, Newlib 9ae9eef)
executing thread ID: 0x0a010001
executing thread name: UI1
Best Regards,
Zainab Olalekan
users mailing list
users at rtems.org<mailto:users at rtems.org>
http://lists.rtems.org/mailman/listinfo/users
Hi
--joel
Hi everyone,
NET_CFG_IFACE =tse1
Exit from bspstart
 unr[e aRchTaEblMe
 : 6R3T rv E=M= 0S
Best Regards,
Zainab Olalekan
users mailing list
Hi
--joel
Hi everyone,
NET_CFG_IFACE =tse1
Exit from bspstart
 unr[e aRchTaEblMe
 : 6R3T rv E=M= 0S
Best Regards,
Zainab Olalekan
users mailing list
URL: <http://lists.rtems.org/pipermail/users/attachments/20230623/ca225633/attachment-0001.htm>
