Issue with read() and flush()
Sebastian Huber
Fri Mar 3 06:48:30 UTC 2023
Hello Jeff,
On 02.03.23 22:57, jeff.hatton at L3Harris.com wrote:
> I am working on a project that uses the RTEMS OS on a Leon3 processor. I
> am trying to read/write from a UART that is connected up through the
> termios interface. It works for the most part but I am running into an
> issue with flushing and reading from the UART. It seems if I read a
> small portion of the data use read() then flush then read again there is
> still data returned. Is this expected behavior? If so is there any way
> to clear out whatever is cached in read?
> Pseudo Code
> Open UART with open("/dev/console_b", O_RDWR | O_NONBLOCK); setup
> terminal into raw mode with cfmakeraw() and tcsetattr(fd,
> TCSADRAIN,term)
> Setup the UART into loop back mode so its TX data is looped back into
> its RX Write data into UART with write(fd, "TEST",4) Read a single
> character with read(fd, buff, 1); buff will contain "T" here flush
> buffers with tcflush(fd, TCIOFLUSH) Read a more from UART with read(fd,
> buff, 3); Would expect nothing is returned here but "EST" will be returned.
this could be a limitation of the current Termios implementation. It
doesn't flush device buffers:
static void
flushInput (struct rtems_termios_tty *tty)
rtems_termios_device_context *ctx = tty->device_context;
rtems_interrupt_lock_context lock_context;
rtems_termios_device_lock_acquire (ctx, &lock_context);
tty->rawInBuf.Tail = 0;
tty->rawInBuf.Head = 0;
rtems_termios_device_lock_release (ctx, &lock_context);
If the characters are still in the UART FIFO, then they are not flushed.
This could be fixed by calling the device ioctl handler in this function
and additional device-specific handling.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
