OS X Build Problems tag 5.2 ->Invalid configuration `arm64-apple-darwin22.3.0': machine `arm64-apple' not recognized
Heinz Junkes junkes at fhi-berlin.mpg.de
Wed Mar 29 16:06:19 UTC 2023
Hi,
I have, once again, a problem with building RTEMS on OS X.
It works fine with rtems6/master
with clang 10.0.0 , python 3.8.5 on
Darwin Judiciary-Pag.fritz.box 22.2.0 Darwin Kernel Version 22.2.0: Fri Nov 11 02:04:44 PST 2022; root:xnu-8792.61.2~4/RELEASE_ARM64_T8103 arm64
python shows:
(base) Judiciary-Pag:rtems-libbsd heinz$ python
Python 3.8.5 (default, Sep  4 2020, 02:22:02)
[Clang 10.0.0 ] :: Anaconda, Inc. on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import sysconfig
>>> sysconfig.get_config_vars()['HOST_GNU_TYPE']
'x86_64-apple-darwin13.4.0'
and clang 14.0.0 with python 3.11.2 on
mac07:VE_RTEMS_INST hjunkes$ uname -a
Darwin mac07.pse.bht-berlin.de 22.3.0 Darwin Kernel Version 22.3.0: Mon Jan 30 20:39:35 PST 2023; root:xnu-8792.81.3~2/RELEASE_ARM64_T8103 arm64
python shows:
mac07:VE_RTEMS_INST hjunkes$ python
Python 3.11.2 (main, Feb 16 2023, 02:55:59) [Clang 14.0.0 (clang-1400.0.29.202)] on darwin
>>> import sysconfig
'aarch64-apple-darwin22.3.0'
on CLANG 14.0.0 and python 3.11.2
OK with rtems 6 / master
  git clone https://github.com/RTEMS/rtems-source-builder.git rsb
RTEMS Source Builder - Set Builder, 6 (f0e34eab8bf3 modified)
 Command Line: ../source-builder/sb-set-builder --jobs=2 --prefix=/Users/hjunkes/RTEMS_RASPI_RUN/rtems/6 6/rtems-arm
 Python: 3.11.2 (main, Feb 16 2023, 02:55:59) [Clang 14.0.0 (clang-1400.0.29.202)]
warning: exe: absolute exe found in path: (__install_info) /usr/bin/install-info
warning: exe: absolute exe found in path: (__makeinfo) /usr/bin/makeinfo
Build Set: 6/rtems-arm
Build Set: tools/rtems-default-tools.bset
Build Set: textproc/gsed-internal.bset
config: textproc/gsed.cfg
package: gsed-4.8-arm64-apple-darwin22.3.0-1
script:  1: #!/bin/sh
Failed with rtems 5.2
cd rsb
git checkout tags/5.2
RTEMS Tools Project - Source Builder Error Report
 Build: error: building autoconf-2.69-arm64-apple-darwin22.3.0-1
 Command Line: ../source-builder/sb-set-builder --jobs=2 --prefix=/Users/hjunkes/VE_RTEMS_RUN/rtems/5 5/rtems-arm
 https://github.com/RTEMS/rtems-source-builder.git/origin/1116c5f85fb5dceca4a57c1b69195b6e9215b084-modified
Tail of the build log:
+ ac_prefix=/Users/hjunkes/VE_RTEMS_INST/rsb/rtems/build/tmp/sb-659039/Users/hjunkes/VE_RTEMS_RUN/rtems/5
+ test arm64-apple-darwin22.3.0 '!=' arm64-apple-darwin22.3.0
+ export CFLAGS CFLAGS_FOR_BUILD CC
+ CFLAGS='-O2 -pipe -fbracket-depth=1024 -I/Users/hjunkes/VE_RTEMS_INST/rsb/rtems/build/tmp/sb-659039/5/rtems-autotools-internal/Users/hjunkes/VE_RTEMS_RUN/rtems/5/include '
+ ./configure --build=arm64-apple-darwin22.3.0 --host=arm64-apple-darwin22.3.0 --verbose --disable-nls --without-included-gettext --prefix=/Users/hjunkes/VE_RTEMS_INST/rsb/rtems/build/tmp/sb-659039/Users/hjunkes/VE_RTEMS_RUN/rtems/5
configure: WARNING: unrecognized options: --disable-nls, --without-included-gettext
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... build-aux/install-sh -c -d
checking for gawk... no
checking for mawk... no
checking for nawk... no
checking for awk... awk
checking whether make sets $(MAKE)... yes
configure: error: /bin/sh build-aux/config.sub arm64-apple-darwin22.3.0 failed
checking build system type...
shell cmd failed: /bin/sh -ex  /Users/hjunkes/VE_RTEMS_INST/rsb/rtems/build/autoconf-2.69-arm64-apple-darwin22.3.0-1/do-build
on CLANG 10.0.0 and python 3.8.5
Ok with RTEMS 5.2 (and rtems6)
RTEMS Source Builder - Set Builder, 5 (1116c5f85fb5 modified)
 Command Line: ../source-builder/sb-set-builder --jobs=2 --prefix=/Users/heinz/VE_RTEMS_RUN/rtems/5 5/rtems-arm
 Python: 3.8.5 (default, Sep  4 2020, 02:22:02) [Clang 10.0.0 ]
Build Set: 5/rtems-arm
Build Set: 5/rtems-autotools.bset
Build Set: 5/rtems-autotools-internal.bset
config: tools/rtems-autoconf-2.69-1.cfg
package: autoconf-2.69-x86_64-apple-darwin22.2.0-1
Danke Heinz
