rtems6 master on darwin-x86_64 fails building: arm-rtems6-gcc-814ec21-newlib-fbc5496-x86_64-apple-darwin22.6.0-1
Heinz Junkes
junkes at fhi-berlin.mpg.de
Tue Oct 17 19:52:59 UTC 2023
Hi,
unfortunately i can't build RTEMS6 on the Intel-Mac (darwin-x86_64) at the moment.
it fails here:
downloading: patches/fix-mac-arm64-mpc-config.patch - 347.0 bytes of 347.0 bytes (100%)
download: https://www.mpfr.org/mpfr-4.2.0/mpfr-4.2.0.tar.bz2 -> sources/mpfr-4.2.0.tar.bz2
downloading: sources/mpfr-4.2.0.tar.bz2 - 1.6MB of 1.6MB (100%)
error: building arm-rtems6-gcc-814ec21-newlib-fbc5496-x86_64-apple-darwin22.6.0-1
Build FAILED
See error report: rsb-report-arm-rtems6-gcc-814ec21-newlib-fbc5496-x86_64-apple-darwin22.6.0-1.txt
Note: In some cases the error appears only in
the complete build log (see --log option)
Build Set: Time 0:31:04.275488
Build Set: Time 0:31:04.299122
Build FAILED
with
../../../../gnu-mirror-gcc-814ec21/libgcc/libgcc2.c: In function '__divdc3':
../../../../gnu-mirror-gcc-814ec21/libgcc/libgcc2.c:2063:7: internal compiler error: Segmentation fault: 11
2063 | if (FABS (d) >= RBIG)
Please submit a full bug report, with preprocessed source (by using -freport-bug).
/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-814ec21-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/./gcc/xgcc -B/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-814ec21-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/./gcc/ -nostdinc -B/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-814ec21-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/newlib/ -isystem /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-814ec21-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/newlib/targ-include -isystem /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-814ec21-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/gnu-mirror-gcc-814ec21/newlib/libc/include -B/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rtems/6/arm-rtems6/bin/ -B/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rtems/6/arm-rtems6/lib/ -isystem /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rtems/6/arm-rtems6/include -isystem /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rtems/6/arm-rtems6/sys-include -g -O2 -mthumb -O2 -I../../../../gnu-mirror-gcc-814ec21/libgcc/../newlib/libc/sys/rtems/include -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wstrict-prototypes -Wmissing-prototypes -Wold-style-definition -isystem ./include -fno-inline -g -DIN_LIBGCC2 -fbuilding-libgcc -fno-stack-protector -Dinhibit_libc -fno-inline -I. -I. -I../../.././gcc -I../../../../gnu-mirror-gcc-814ec21/libgcc -I../../../../gnu-mirror-gcc-814ec21/libgcc/. -I../../../../gnu-mirror-gcc-814ec21/libgcc/../gcc -I../../../../gnu-mirror-gcc-814ec21/libgcc/../include -DHAVE_CC_TLS -o _divtc3.o -MT _divtc3.o -MD -MP -MF _divtc3.dep -DL_divtc3 -c ../../../../gnu-mirror-gcc-814ec21/libgcc/libgcc2.c -fvisibility=hidden -DHIDE_EXPORTS
See <https://gcc.gnu.org/bugs/> for instructions.
make[4]: *** [_divdc3.o] Error 1
make[4]: *** Waiting for unfinished jobs....
make[4]: Leaving directory `/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-814ec21-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/thumb/libgcc'
make[3]: *** [multi-do] Error 1
make[3]: Leaving directory `/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-814ec21-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libgcc'
make[2]: *** [all-multi] Error 2
make[2]: Leaving directory `/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-814ec21-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libgcc'
make[1]: *** [all-target-libgcc] Error 2
make[1]: Leaving directory `/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-814ec21-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build'
make: *** [all] Error 2
make: Leaving directory `/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-814ec21-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build'
shell cmd failed: /bin/sh -ex /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-814ec21-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/do-build
error: building arm-rtems6-gcc-814ec21-newlib-fbc5496-x86_64-apple-darwin22.6.0-1[junkes at h XILINX_ZYNQ_A9_QEMU]$
Heinz
