rsb gdb build on aarch64 (OS-X M2)
Heinz Junkes junkes at fhi-berlin.mpg.de
Wed Sep 27 20:28:51 UTC 2023
It was a mess with homebrew and python versions on my system.
Rsb works well ;-)
Heinz
> On 27. Sep 2023, at 20:26, Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
> Hallo,
> I'm trying to build RTEMS on a MAC (M2) and I'm getting the following error:
> config: tools/rtems-gdb-13.2.cfg
> error: config error: gdb-common-1.cfg:127: "gdb: python: library file not found: libpython3.11.*, please install"
> Build FAILED
> Build Set: Time 0:02:09.754310
> Build Set: Time 0:02:09.758390
> Build FAILED
> building failed
> Danke Heinz
> Complete output:
> ... building tool set for  arm
> RTEMS Source Builder - Set Builder, 6 (35c73203df1e)
> Build Set: 6/rtems-arm
> Build Set: tools/rtems-default-tools.bset
> config: devel/dtc-1.6.1-1.cfg
> package: dtc-1.6.1-arm64-apple-darwin23.0.0-1
> Creating source directory: sources
> download: https://www.kernel.org/pub/software/utils/dtc/dtc-1.6.1.tar.gz -> sources/dtc-1.6.1.tar.gz
> redirect: https://mirrors.edge.kernel.org/pub/software/utils/dtc/dtc-1.6.1.tar.gz
> downloading: sources/dtc-1.6.1.tar.gz - 199.0kB of 199.0kB (100%)
> Creating source directory: patches
> download: https://devel.rtems.org/raw-attachment/ticket/4783/0001-checks.c-Ensure-argument-is-an...<see log> -> patches/0001-checks.c-Ensure-argument-is-an-integer-v2.patch
> downloading: patches/0001-checks.c-Ensure-argument-is-an-integer-v2.patch - 773.0 bytes of 773.0 bytes (100%)
> building: dtc-1.6.1-arm64-apple-darwin23.0.0-1
> sizes: dtc-1.6.1-arm64-apple-darwin23.0.0-1: 3.038MB (installed: 712.910KB)
> cleaning: dtc-1.6.1-arm64-apple-darwin23.0.0-1
> reporting: devel/dtc-1.6.1-1.cfg -> dtc-1.6.1-arm64-apple-darwin23.0.0-1.txt
> reporting: devel/dtc-1.6.1-1.cfg -> dtc-1.6.1-arm64-apple-darwin23.0.0-1.xml
> config: devel/expat-2.5.0-1.cfg
> package: expat-2.5.0-arm64-apple-darwin23.0.0-1
> download: https://github.com/libexpat/libexpat/releases/download/R_2_5_0/expat-2.5.0.tar.gz -> sources/expat-2.5.0.tar.gz
> redirect: https://objects.githubusercontent.com/github-production-release-asset-2e65be/80314213/...<see log>
> downloading: sources/expat-2.5.0.tar.gz - 702.4kB of 702.4kB (100%)
> building: expat-2.5.0-arm64-apple-darwin23.0.0-1
> sizes: expat-2.5.0-arm64-apple-darwin23.0.0-1: 7.537MB (installed: 886.030KB)
> cleaning: expat-2.5.0-arm64-apple-darwin23.0.0-1
> reporting: devel/expat-2.5.0-1.cfg -> expat-2.5.0-arm64-apple-darwin23.0.0-1.txt
> reporting: devel/expat-2.5.0-1.cfg -> expat-2.5.0-arm64-apple-darwin23.0.0-1.xml
> config: devel/gmp-6.2.1.cfg
> package: gmp-6.2.1-arm64-apple-darwin23.0.0-1
> download: https://gcc.gnu.org/pub/gcc/infrastructure/gmp-6.2.1.tar.bz2 -> sources/gmp-6.2.1.tar.bz2
> downloading: sources/gmp-6.2.1.tar.bz2 - 2.4MB of 2.4MB (100%)
> building: gmp-6.2.1-arm64-apple-darwin23.0.0-1
> sizes: gmp-6.2.1-arm64-apple-darwin23.0.0-1: 21.584MB (installed: 1.428MB)
> cleaning: gmp-6.2.1-arm64-apple-darwin23.0.0-1
> reporting: devel/gmp-6.2.1.cfg -> gmp-6.2.1-arm64-apple-darwin23.0.0-1.txt
> reporting: devel/gmp-6.2.1.cfg -> gmp-6.2.1-arm64-apple-darwin23.0.0-1.xml
> Build Set: textproc/gsed-internal.bset
> config: textproc/gsed.cfg
> package: gsed-4.9-arm64-apple-darwin23.0.0-1
> download: https://ftp.gnu.org/gnu/sed/sed-4.9.tar.gz -> sources/sed-4.9.tar.gz
> downloading: sources/sed-4.9.tar.gz - 2.2MB of 2.2MB (100%)
> building: gsed-4.9-arm64-apple-darwin23.0.0-1
> sizes: gsed-4.9-arm64-apple-darwin23.0.0-1: 18.014MB (installed: 0.000B)
> cleaning: gsed-4.9-arm64-apple-darwin23.0.0-1
> Build Set: Time 0:00:41.529142
> Build Set: print/texinfo-internal.bset
> config: print/texinfo.cfg
> package: texinfo-7.0.3-arm64-apple-darwin23.0.0-1
> download: https://ftp.gnu.org/gnu/texinfo/texinfo-7.0.3.tar.gz -> sources/texinfo-7.0.3.tar.gz
> downloading: sources/texinfo-7.0.3.tar.gz - 10.3MB of 10.3MB (100%)
> building: texinfo-7.0.3-arm64-apple-darwin23.0.0-1
> sizes: texinfo-7.0.3-arm64-apple-darwin23.0.0-1: 88.097MB (installed: 0.000B)
> cleaning: texinfo-7.0.3-arm64-apple-darwin23.0.0-1
> Build Set: Time 0:00:49.355165
> Build FAILED
> Build FAILED
> building failed_______________________________________________
> users mailing list
> users at rtems.org
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20230927/92a995e3/attachment.bin>
